ASUS Zen AiO ZN240IC REV1.4 Black Screen. Bios
  • paskelovanis
    Amperas
    • Oct 2020
    • 14
    • Lithuania
    Fan spinning normally, power LED turns on and goes off almost instantly, computer remains on, has no internal/external display output.
    S/N: G7PTTSIR000W
    Model: ZN240IC
    Make: Z2401CGT
    Motherboard: Z240IC REV 1.4
    BIOS dump attached.
  • hoaca388
    Badcaps
    • Jan 2022
    • 12392
    Zen AiO ZN240IC
    • paskelovanis
      Amperas
      • Oct 2020
      • 14
      • Lithuania
      Originally posted by hoaca388
      Zen AiO ZN240IC
      Thank you, but issue is not solved.
      With this BIOS PC fan does not spin, power LED always off. Screen backlight turns on for 0.5 second and turns off, looping.
      • paskelovanis
        Amperas
        • Oct 2020
        • 14
        • Lithuania
        bump
        • hoaca388
          Badcaps
          • Jan 2022
          • 12392
          Originally posted by paskelovanis
          bump
          Check the hardware again, the above file is already the original file.
          • rachidell
            • Aug 2016
            • 140
            • algeria
            S/N: SC61M1001A0
            Model: ZN240IC
            I tryed with
            Zen AiO ZN240IC
            but not working
            BIOS dump attached.
            • hoaca388
              Badcaps
              • Jan 2022
              • 12392
              S/N: SC61M1001A0
              Model: ZN240IC
              I tryed with but not working
              BIOS dump attached.
              This is the oldest bios version on Asus homepage, if it doesn't work it means you have an unresolved hardware problem.
              • rachidell
                • Aug 2016
                • 140
                • algeria
                thanks
                • Technodoc
                  ASUS G614JZ G634J-PMV-VGT Rog Strix need some bios help, laptop black screen
                  by Technodoc
                  Asus laptop G614JZ-N3012W Rog Strix with i7
                  Mainboard G634J-PMV-VGT
                  6050A3441302-MB-A01
                  2023-02-10
                  Power button works okay....power light goes on
                  Red "bottom" leds go on
                  Charging led works
                  Fans do not spin, capslock key does nothing, screen stays black
                  I would like to program the bios again, to rule out a corrupted bios.
                  However I run into a size error
                  The bios chip is a Winbond 25R256JVEN
                  Used my Xgecu T-48 to read the bioschip (using select chip as type XM25QH256B @WSON8, read somewhere...
                  02-24-2025, 04:46 AM
                • razor_amd
                  by razor_amd
                  12-15-2020, 07:07 PM
                • grimacelord
                  by grimacelord
                  07-10-2025, 02:52 PM
                • mitchw
                  HP 14s-fq1010nm Black screen after BIOS update - cannot downgrade
                  by mitchw
                  Just had a customer bring in a HP 14s-fq1010nm to do some maintenance.
                  After updating the BIOS to the latest (F.35) I get black screen (no backlight turning on). However the backlight turns on if I connect an external display to HDMI, but when booting to Windows, both displays remain black.
                  After disconnecting internal LCD, and plugging in external display via HDMI, it works on external.
                  I tried downgrading it using official method - using an USB drive with older BIOS version, but it fails, saying that the BIOS files are corrupted. I used about 5 different older BIOS versions...
                  04-29-2025, 03:45 PM
                • jbonavita
                  by jbonavita
                  Some issues
                  Things I tried
                  04-29-2025, 09:38 PM
