Dell xps 8940 bios
  • stevetaylor
    • Sep 2015
    • 42
    • romania
    Dell xps 8940 bios
    hello everyone , I need your help,
    I have a pc, xps 8940 does not work with cpu gen11 only with gen10.
    I tried to update the bios but nothing changed.
    I found bios bin on the internet which I programmed.
    it works with it, but every time it starts,
    the TPM not found error appears and the service tag is not saved in the bios.
    after restart service tag window remaing clear. i attach original bios dump.
    thank you. here some pics.
  • hardware1
    • Sep 2021
    • 2939
    • N/A
    Re: Dell xps 8940 bios
    Write your Service Tag.
    all donations are welcome,
    • stevetaylor
      • Sep 2015
      • 42
      • romania
      Jjfsmh3
      • hardware1
        • Sep 2021
        • 2939
        • N/A
        There is something wrong with your dump file, upload the other file that works but gives you TPM and Service Tag error.
        • stevetaylor
          • Sep 2015
          • 42
          • romania
          ok, on Monday I will read the original bios again, that one wich working correct with 10-th proccesor. Once again, my intention is to upgrade cpu from 10-th gen. to 11-th gen. When i install a new cpu not give me any errors, but no show image. What I noticed after the new processor is installed, the bios content is not the same. In a hex editor the differences are major. With this bios attached below, it gives me an image but the service tag is not saved and it starts with the TPM module not found error
          • hardware1
            • Sep 2021
            • 2939
            • N/A
            Here is your New BIOS, try it and let me know.
            In the first boot you can go to BIOS Menu and insert your Service Tag.
            • stevetaylor
              • Sep 2015
              • 42
              • romania
              thank you sir, in this moment am away, but monday
              the first thing i will do
              • stevetaylor
                • Sep 2015
                • 42
                • romania
                good morning sir, one step forward, in this moment the sistem work whit 11th gen. no tpm error, but service tag no memorize.
                • stevetaylor
                  • Sep 2015
                  • 42
                  • romania
                  this happen on every start
                  • hardware1
                    • Sep 2021
                    • 2939
                    • N/A
                    As I said in Post #6 "In the first boot you can go to BIOS Menu and insert your Service Tag." After that you can Press ALT+F to exit Manufacturing Mode.
                    • stevetaylor
                      • Sep 2015
                      • 42
                      • romania
                      I followed your advice, the service tag is not saved
                      • stevetaylor
                        • Sep 2015
                        • 42
                        • romania
                        thank you for your effort
                        • hardware1
                          • Sep 2021
                          • 2939
                          • N/A
                          You must insert the Service Tag first then press ALT+F. I think you already pressed ALT+F before writing your Service Tag, so you need to re-programmer the chip, go to BIOS Menu, insert your Service Tag, save and Exit, then press ALT+F.
                          • stevetaylor
                            • Sep 2015
                            • 42
                            • romania
                            for this I need to rewrite the bios again or not?
                            so.
                            -rewrite-
                            -programming service tag
                            -saving
                            after restart
                            -alt+F
                            right?
                            • hardware1
                              • Sep 2021
                              • 2939
                              • N/A
                              Yes, you need to re-flash the BIOS.
                              -rewrite-
                              -saving
                              after restart
                              -alt+F
                              right?
                              Your steps is fine.
                              • stevetaylor
                                • Sep 2015
                                • 42
                                • romania
                                In left corner apear this error BAC6D992
                                otherwise nothing has changed, service tag remain empty. and (manufacturing mode active) still apears on every start. It bypasses these errors but it is annoying for the buyer.
                                maybe SIO is programmable?MEC1515-Z2 and not write over the old content? I do not know
                                • stevetaylor
                                  • Sep 2015
                                  • 42
                                  • romania
                                  is possible to insert a service tag direct into bios?
                                  • hardware1
                                    • Sep 2021
                                    • 2939
                                    • N/A
                                    Try this one. If the problem still present, you can try to update the BIOS from Dell website.
                                    • stevetaylor
                                      • Sep 2015
                                      • 42
                                      • romania
                                      yes, the problem stii present , I updated the bios in two ways via windows and via .rcv, the ussue is still present.
                                      now showing service tag , but only on self diagnostic tool
                                      • stevetaylor
                                        • Sep 2015
                                        • 42
                                        • romania
                                        in my research i found somebody with the same issue , who talk about in this case is necessary to pach the bios . i dont know it's true. the pach cost is about 30$. Your opinion?
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • mikeybass
                                          by mikeybass
                                          04-23-2025, 04:30 PM
                                        • jhanra
                                          by jhanra
                                          in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
                                          11-02-2024, 04:19 AM
                                        • gizaha
                                          by gizaha
                                          02-13-2024, 07:18 AM
                                        • mrrubik
                                          Dell Optiplex 7010 micro bad BIOS flash?
                                          by mrrubik
                                          Hi folks,
                                          I got a Dell Optiplex 7010 micro PC (Exact Model) with 8FC8 BIOS and locked out admin password. I attempted to remove the password by patching the BIOS via info from this thread: https://www.badcaps.net/forum/troubl...ssword-patcher
                                          After flashing the patched the BIOS, the PC is unresponsive with a solid AMBER power LED (not documented in manual anywhere)
                                          Steps I took:
                                          1. Read BIOS with CH341a, verified hash twice
                                          2. Patched
                                          12-23-2024, 04:11 PM
