Need Asus prime B550m-k bios .bin dump
  • aboumohamed
    • Dec 2018
    • 258
    • algeria
    Need dump for motherboard Asus prime B550m-k R1.01
    THANKS
    • 21037
    Re: Need Asus prime B550m-k bios .bin dump
    THANKS
    Get the bios from Asus support, remove the 4KB CAP header using UEFITool ,just choose "Extract Body" .
    • aboumohamed
      • Dec 2018
      • 258
      • algeria
      thank you for the answer.
      I used this method but no display.
      all voltages are correct.
      • tmks2
        • Oct 2020
        • 12
        • EU
        hello can you do this for me? i need this bios bin urgently.
        • hoaca388
          Badcaps
          • Jan 2022
          • 11815
          Urgently
          • tmks2
            • Oct 2020
            • 12
            • EU
            Originally posted by hoaca388
            Urgently
            the motherboard came alive. Thank you very much!
            • andrewcc
              • Nov 2022
              • australia
              Urgently
              thanks. It works for my Asus B550M-K 1.02 . my motherboard after shut down , always need clear CMOS to boot correctly
              • DynaxSC
                by DynaxSC
                06-14-2024, 03:49 PM
              • razor_amd
                by razor_amd
                12-15-2020, 07:07 PM
              • reset1986
                Asus prime b550m-a bios dump
                by reset1986
                Hi guys, I have this PC that does not display an image, video card and GPU and RAM are working, tested on another PC, I suspect the BIOS is damaged, I attach the original dump, I need a working BIOS, thanks...
                06-22-2025, 04:17 AM
              • Ahari
                by Ahari
                I...
                08-13-2025, 06:12 AM
              • jbonavita
                by jbonavita
                Some issues
                Things I tried
                04-29-2025, 09:38 PM
