Need Asus prime B550m-k bios .bin dump
  • aboumohamed
    • Dec 2018
    • 261
    • algeria
    Need dump for motherboard Asus prime B550m-k R1.01
    THANKS
    • 22424
    Re: Need Asus prime B550m-k bios .bin dump
    THANKS
    Get the bios from Asus support, remove the 4KB CAP header using UEFITool ,just choose "Extract Body" .
    • aboumohamed
      • Dec 2018
      • 261
      • algeria
      thank you for the answer.
      I used this method but no display.
      all voltages are correct.
      • tmks2
        • Oct 2020
        • 12
        • EU
        hello can you do this for me? i need this bios bin urgently.
        • hoaca388
          Badcaps
          • Jan 2022
          • 12521
          Urgently
          • tmks2
            • Oct 2020
            • 12
            • EU
            Originally posted by hoaca388
            Urgently
            the motherboard came alive. Thank you very much!
            • andrewcc
              • Nov 2022
              • australia
              Urgently
              thanks. It works for my Asus B550M-K 1.02 . my motherboard after shut down , always need clear CMOS to boot correctly
              • huzo
                • Sep 2014
                • 190
                • CROATIA
                People ,my board died yesterday after bios update...it wen't from 3002 to 4001 version ,and after reset it never started up again, just blank screen altough i waited for like 5 minutes......But ok, i extracted the dump from .cap file ,and i tried flashing it and i tried the dump from this "urgently" post adn it doesn't work...the board worked perfectly until yesterday...CHAT GPT says that maybe the flash descriptor and PSP ,NVRAM should be flashed from the former bios...But i think something else is wrong....
                • danito
                  • Jun 2016
                  • 1303
                  try
                  • huzo
                    • Sep 2014
                    • 190
                    • CROATIA
                    Originally posted by danito
                    try
                    tnx friend, but it doesn't work...here is my dump after it decided not to work, so it's the 4001 from the chip after it didn't boot. i do not have the original 3002 unfortunately...If you can fix it?
                    • DynaxSC
                      by DynaxSC
                      06-14-2024, 03:49 PM
                    • mkdj
                      by mkdj
                      Dear all,
                      10-19-2025, 04:41 AM
                    • razor_amd
                      by razor_amd
                      12-15-2020, 07:07 PM
                    • pirati
                      by pirati
                      10-27-2025, 04:20 PM
                    • ASB
                      Asus Prime B450-Plus Bios Modification (USB Overcurrent)
                      by ASB
                      I have an Asus Prime B450-Plus motherboard with USB overcurrent shutdown problem. All the ports, voltages and resistors are ok. Can someone please help by editing bios to disable this feature? Another member (прямо) has successfully done this and shared the bios in forum but those are for other Asus models....
                      11-12-2025, 06:17 AM
