Need Asus prime B550m-k bios .bin dump
  • aboumohamed
    • Dec 2018
    • 258
    • algeria
    Need dump for motherboard Asus prime B550m-k R1.01
    THANKS
    • 21828
    Re: Need Asus prime B550m-k bios .bin dump
    THANKS
    Get the bios from Asus support, remove the 4KB CAP header using UEFITool ,just choose "Extract Body" .
    • aboumohamed
      • Dec 2018
      • 258
      • algeria
      thank you for the answer.
      I used this method but no display.
      all voltages are correct.
      • tmks2
        • Oct 2020
        • 12
        • EU
        hello can you do this for me? i need this bios bin urgently.
        • hoaca388
          Badcaps
          • Jan 2022
          • 12313
          Urgently
          ​https://www.badcaps.net/donate
          • tmks2
            • Oct 2020
            • 12
            • EU
            Originally posted by hoaca388
            Urgently
            the motherboard came alive. Thank you very much!
            • andrewcc
              • Nov 2022
              • australia
              Urgently
              thanks. It works for my Asus B550M-K 1.02 . my motherboard after shut down , always need clear CMOS to boot correctly
              • huzo
                • Sep 2014
                • 187
                • CROATIA
                People ,my board died yesterday after bios update...it wen't from 3002 to 4001 version ,and after reset it never started up again, just blank screen altough i waited for like 5 minutes......But ok, i extracted the dump from .cap file ,and i tried flashing it and i tried the dump from this "urgently" post adn it doesn't work...the board worked perfectly until yesterday...CHAT GPT says that maybe the flash descriptor and PSP ,NVRAM should be flashed from the former bios...But i think something else is wrong....
                • danito
                  • Jun 2016
                  • 1091
                  • Romania
                  try
                  • huzo
                    • Sep 2014
                    • 187
                    • CROATIA
                    Originally posted by danito
                    try
                    tnx friend, but it doesn't work...here is my dump after it decided not to work, so it's the 4001 from the chip after it didn't boot. i do not have the original 3002 unfortunately...If you can fix it?
                    • DynaxSC
                      by DynaxSC
                      06-14-2024, 03:49 PM
                    • mkdj
                      by mkdj
                      Dear all,
                      10-19-2025, 04:41 AM
                    • razor_amd
                      by razor_amd
                      12-15-2020, 07:07 PM
                    • reset1986
                      Asus prime b550m-a bios dump
                      by reset1986
                      Hi guys, I have this PC that does not display an image, video card and GPU and RAM are working, tested on another PC, I suspect the BIOS is damaged, I attach the original dump, I need a working BIOS, thanks...
                      06-22-2025, 04:17 AM
                    • Ahari
                      by Ahari
                      I...
                      08-13-2025, 06:12 AM
