Gigabyte MX31-BS1 bios problem (BMC initialize error)
  • ASB
    • Dec 2020
    • 133
    • Pakistan
    Bios corrupted after a failed bios update attempt. I searched on the net but didn't find any update/ support for MX31-BS1. I tried MX31-BS0 bios from gigabyte and it worked but now the board is giving the following error. It repeats two times and after the restart, goes to bios setup showing the recovery page. If I shut down/ restart then the error appears again. Kindly provide the original bios of Gigabyte MX31-BS1 or help to solve this issue. Thanks.
  • Rem1210
    • Jun 2023
    • Indonesia
    Re: Gigabyte MX31-BS1 bios problem (BMC initialize error)
    is the problem solved? can you tell me the bios. i had the same problem
      • 21968
      Try to update the BMC firmware
      https://vmexplorer.com/2017/03/22/gi...d-motherboard/
      https://www.gigabyte.com/Enterprise/...pport-Firmware
      • Rem1210
        • Jun 2023
        • Indonesia
        Thanks, I'll give it a try
        • lucaszmn
          by lucaszmn
          Problem:
          Initial Findings:
          • I concluded that the
          08-12-2025, 03:01 PM
        • AquaMan Ua
          by AquaMan Ua
          05-17-2025, 09:40 AM
        • pkslowk
          Debug Card Error Code and Solution
          by pkslowk
          Sr. Motherboard Debug Error Code Solution
          1 Intel 845 E9 Bios Related Problem
          2 Intel 845 D4 CPU Socket Related problem
          3 Intel 845 37 Bios Related Problem
          4 Intel 845 7C Bios Related Problem
          5 Intel 945GCPE 34 Bios Related Problem
          6 Gigabyte 845 2 Ram Related Problem
          7 IBM Server A6 A7 Ram Mismatch Problem
          8 Asus 845 29 CPU Related Problem
          9 Lenovo I946 97 C-Mos Jumper related
          10 Gigabyte 845 A0 CPU Related Problem
          11 Asrock G31M-VS D7 Bios Related Problem
          12 Compaq 845 BD-70G B0 CPU Socket Related problem...
          01-28-2021, 12:51 PM
        • traxformania
          TONGFANG "GM7TG7P" Bios Password Problem?
          by traxformania
          I tried :
          -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
          11-15-2023, 07:32 AM
        • macabook
          by macabook
          🧩 Initial Issue
          07-24-2025, 02:17 PM
