HP Prodesk 400 G6 mini admin bios password
  • hoaca388
    Badcaps
    • Jan 2022
    • 11709
    #41
    Originally posted by raffa555
    Please, anyone can help me with a 400 G6 Desktop Mini PC? The BIOS got corrupted during updates (5long+2short beeps, EC firmware is invalid)
    i'm a newbe in such things.. I read the chip and saved the BIN with CH341A (NeoProgrammer 2.1) and it seems to be corrupted.
    Does anyone can fix it?
    Serial: 8CC1345315
    Part: 1C7A3EA#UUZ
    Thanks for the help!
    HP ProDesk 400 G6 Desktop Mini PC
    • raffa555
      • Nov 2024
      • 4
      • italy
      #42
      WOW! how you do the magic? it's OK now, thank you so much!
      • beBoss
        • Mar 2023
        • 19
        Serial: 8CC1345315
        Part: 1C7A3EA#UUZ
        Can you tell me how did you manage to read it, I have been struggling for months with two different CH341A - old one that has voltage problem and the new fixed one, different cables, adapters etc and still cannot dumb it, if you can share what type is your chip - mine for example is 16 pins and which exactly, what software aka where to download it most importantly, that would be helpful, thanks!
        • raffa555
          • Nov 2024
          • 4
          • italy
          #44
          here are the steps that worked for me:
          1- CH341A with SOP8 adapter for the 25series chips(bought on amazon) & SOP16 clip (bought on amazon). Check if the jumper on the CH341A is in "programmer mode" (jumper betweeen pin1-2)
ID:	3521430 Click image for larger version
          2 - Check the pinout of the SOP16 clip with a multimeter to find out the PIN no 1 (set the multimeter in ohm measure or continuity)
          3- Connect the SOP16 clip to the SOP8 adapter (i used dupont wires) to the corresponding pin:
          8 PIN CH341 programmer -> 16 PIN SOP Testing Clip
          1 -> 7 (CS)
          2 -> 8 (MISO)
          3 -> 9 (WP)
          4 -> 10 (VSS)
          5 -> 15 (MOSI)
          6 -> 16 (SCK)
          7 -> 1 (HOLD)
          8 -> 2 (VCC)​
          Connect the SOP8 adapter to the CH341A. The 25 series pins are the 8's closest to the USB connector:
          4 - Download from here https://github.com/YTEC-info/CH341A-Softwares/tree/main Neoprogrammer 2.1 (drivers and software)
          5- Disconnect the power from the 400G6 PC. Connect the SOP16 clip to the GigaDevice chip on the motherboard (matching PIN no1 of the chip to the PIN no1 SOP16 clip. You can find out the PIN no1 of the chip checking the small cirle on the upper surface on it). I've tried with and without the CMOS battery connected with no difference.
          6 - Open Neoprogrammer 2.1, check if the CH341A is selected in the "Hardware" menu. Click "Detect chip" (the button with the "?" icon) . If you got the IC not responding message, check the SOP116 clip positioning. The positioning of the clip is a little bit tricky... you have to try and retry (poistioning-detect clip and repeat)
          7 - When Neoprogrammer find out the chip, after you click detect button, a yellow popup message appears with chip info's (GIGADEVICE GD25Q256....)
          8 - Erase the CHIP (button with X icon). The led on the 400G6 start blinking 5 red- 7 White
          9 - Open the BIN file and click the program button (the one with the blue arrwow icon) with this options: Write - Verify
          10 - Disconnect the SOP16 clip
          If you got error, try to reset CMOS following the HP procedure (disconnect all the power sources, disconnect the CMOS battery, press the power button multiple times and/or press for 25s the CMOSSW50 button on the motherboard)
          If you got error again, try to repeat the erase-write process...
          Hope this can help you!! Let me know if you got success
          • Joel2B
            • Dec 2024
            • México
            #45
            hello everyone
            thank you very much for the steps raffa555, helped me a lot but unfortunately the tweezers did not work for me,
            i buy both versions,the one with all the connections and the 16 to 8, luckily i ordered some mini tweezers as a last resource and it worked, i could extract the bios
            can you help me to remove the password?, i bought without asking if had a password, i already tried rcunlocker but tells me "wrong chip"
            thank you very much for your time
            serial no. 8CC11026R5
            product no. 359P8LS#ABM​
            • hoaca388
              Badcaps
              • Jan 2022
              • 11709
              #46
              Originally posted by Joel2B
              hello everyone
              Serial_8CC11026R5
              Sku_359P8LS#ABM
              Build Id_20WWQ6CT601#SABM#DABM
              Fearture byte_3E3X476J6S6b7B7J7M7Q7T7WaBapaqaubhcAdUdpdqfAfPk8mE.QF
              • Joel2B
                • Dec 2024
                • México
                #47
                Serial_8CC11026R5
                Sku_359P8LS#ABM
                it works!!!
                thank you very much hoaca388​ , after hours of trying to flash it and with errors, was achieved
                I dont know how they do it, but they are the best!!
                • inspirim
                  • May 2013
                  • 282
                  • Italy
                  #48
                  Model: Hp Prodesk 400 G6 SFF
                  Motherboard: L64712 or L49705-001 attach photo
                  Serial: CZC0177FYQ
                  ProductNo: 7PG47EA#ABZ attach photo
                  no power defect, attach bios
                  thanks to all​
                  • peste
                    peste commented
                    Editing a comment
                    post merged..
                • peste
                  • Dec 2016
                  • 12742
                  • ROMANIA
                  #49
                  Serial: CZC0177FYQ
                  thanks to all​
                  post the contents of the bios chip even if it is corrupted..
                  • inspirim
                    • May 2013
                    • 282
                    • Italy
                    #50
                    corrupted bios
                    • danito
                      • Jun 2016
                      • 901
                      • Romania
                      #51
                      corrupted bios
                      Try
                      • vpotechnology
                        • Aug 2023
                        • 7
                        • colombia
                        #52
                        please bios key collaboration​ hp prodesk 400 g6 mini pc seria 8cc1421h64
                        • nafienew
                          • Aug 2014
                          • 90
                          • maroc
                          #53
                          pleas need remove password bios
                          HP Prodesk 400 G6 Desktop Mini Pc
                          serial no 8CC2122QWB
                          DAF91MB16B0 REV B
                          MODEL : F91
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 11709
                            #54
                            DAF91MB16B0 REV B
                            MODEL : F91
                            RC unlocker
                            • mego1974
                              • Feb 2022
                              • 38
                              • Spain
                              #55
                              Hello
                              I need help with password on this bios dump.
                              Any help apreciated.
                              SN 8CC0450DKT
                              Thanks !!
                              • peste
                                • Dec 2016
                                • 12742
                                • ROMANIA
                                #56
                                Originally posted by mego1974
                                Hello
                                SN 8CC0450DKT
                                Thanks !!
                                use RCunlocker
                                • mego1974
                                  • Feb 2022
                                  • 38
                                  • Spain
                                  #57
                                  Originally posted by peste
                                  use RCunlocker
                                  I used and no result .
                                  Password still there!
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 11709
                                    #58
                                    Hello
                                    SN 8CC0450DKT
                                    Thanks !!
                                    Unlocked
                                    • mego1974
                                      • Feb 2022
                                      • 38
                                      • Spain
                                      #59
                                      Unlocked
                                      Thank you !!
                                      I will try and post the result !!!
                                      • mego1974
                                        • Feb 2022
                                        • 38
                                        • Spain
                                        #60
                                        Unlocked
                                        Hello hoaca388
                                        Flashed ,password dissapear , system ID dissapear ,and MPM locked. I can't introduce the system ID ,and all the data .
                                        • beBoss
                                          HP ProDesk 400 G6 mini - BIOS Password attempt to remove it
                                          by beBoss
                                          as noobie to this please excuse my lack of experience.
                                          I am trying to remove a BIOS password from this machine:
                                          HP ProDesk 400 G6 Mini
                                          but so far I still have no success.
                                          I bought CH341 programmer and decided to give it a try.
                                          The programmer came with 8 pin cables and connectors or whatever everything else is called so I had to buy a new 16 pin cable because the chip which I think is the BIOS is with 16 pins..
                                          I connected everything and downloaded AsProgrammer and NeoProgrammer then installed drivers...
                                          05-30-2024, 12:48 PM
                                          HP ProDesk ProDesk 600 G2 Desktop Mini PC ProDesk 600 i5-6500T Specification for Upgrade or Repair
                                          This specification for the HP ProDesk ProDesk 600 G2 Desktop Mini PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk ProDesk 600 G2 Desktop Mini PC boardview and ProDesk ProDesk 600 G2 Desktop Mini PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                          09-12-2024, 03:44 PM
                                          HP ProDesk ProDesk 400 G2 Desktop Mini PC (ENERGY STAR) ProDesk 400 i5-6500T Specification for Upgrade or Repair
                                          This specification for the HP ProDesk ProDesk 400 G2 Desktop Mini PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk ProDesk 400 G2 Desktop Mini PC (ENERGY STAR) boardview and ProDesk ProDesk 400 G2 Desktop Mini PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                          HP ProDesk Desktop Mini ProDesk 600 G2 ProDesk 600 i7-6700T Specification for Upgrade or Repair
                                          This specification for the HP ProDesk Desktop Mini ProDesk 600 G2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk Desktop Mini ProDesk 600 G2 boardview and ProDesk Desktop Mini ProDesk 600 G2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
