Interpret Rx5500xt Faulty Ramtest Tserver
  • breid
    • Apr 2022
    • 22
    • Österreich
    I got the gpu RX5500Xt 8GB from my brother to fix it, it always crashes when the drivers load. I've now done a memory test with Tserver, but I'm too stupid to understand it properly if anyone thanks
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3565
    • slovakia
    Re: Interpret Rx5500xt Faulty Ramtest Tserver
    it is just badly formated.
    try less viever
    less report.txt
    u have bad chip on positio B1
    • breid
      • Apr 2022
      • 22
      • Österreich
      thanks
      • jhonn1291
        • Sep 2021
        • mexico
        breid, can you tell me that version of tserver is this please? i have too a rx5500 that no show video
        • breid
          • Apr 2022
          • 22
          • Österreich
          sry for my late anwser you can download it here! https://drive.google.com/file/d/1nRI...ifHrZQvU8/view
          • TgBr4545
            • Mar 2023
            • Parana
            Would it be possible to resend the link?
            • mkdj
              MacBook Air A2337 (820-02016) - 5V, won't turn on - please help me understand why
              by mkdj
              About me, my goal and the equipment I (don't) have:
              I am brand new to this forum, and I am eager to learn about repairing laptops. I have an engineer background although I haven't done electronics for a while. I have watched several Youtube videos in the last two months, trying to understand how to diagnose a faulty motherboard. I have a USB-C Amp meter and a classic multi meter. No DC Power Supply to inject voltage, no soldering iron to replace components.
              About my issue and my goal:
              A friend of mine has a MacBook Air M1 A2337 that does not...
              04-03-2025, 08:28 AM
            • Raymond red (mon)
              Brother J2730-DW stuck on Brother Logo
              by Raymond red (mon)
              hello, I have this Brother J2730-DW printer that was brought to me by a friend, it was supposed to be converted to continues ink but the printer wouldn't turn on completely. The printer powers on and plays a tune but it gets stuck in the brother logo. Upon checking, the printer was infested by many small cockroaches. I do checked the board cleaned and tested some corroded capacitors but all seems to be fine, I couldn't find any short circuit or any missing component on the board. Also checked the power supply and it was working fine.
              please help.
              11-08-2024, 09:19 AM
            • Spudgun
              Why doesn't current just bypass faulty capacitors.
              by Spudgun
              Hello esteemed members. I appreciate that my question will strike some as being somewhat childishly simple, but it genuine perplexes me! I have repaired several laptops before by removing a faulty capacitor that was short-circuiting the motherboard, whereupon the laptop would then work. For me, it begs the question that, if the current can bypass where the capcitor was when it has been removed, why didn't it just bypass it when it was present and faulty,? I can't get my head round the premise that if the other side of the capacitor is connected to ground, then why doesn't the current simply bypass...
              04-01-2025, 10:33 AM
            • smile
              BROTHER MFC-J5340DW dump
              by smile
              Looking for BROTHER MFC-J5340DW BIOS and memory.
              What programmer do I need to read these Brother chip, RT809H?
              12-27-2024, 08:21 AM
            • b-slayer
              Acer A317-53 need help to disable faulty onboard ram
              by b-slayer
              Hello.
              I have an Acer Aspire A317-53 laptop with faulty onboard ram modules, after online searches, I have only found two options to get it working :
              - first one is to modify le bios to disable the onboard ram.
              - second one is to disable the onboard ram by desoldering some components on the mainboard.
              so after some hours google-ing, i have to give-up the modified bios option, main reason is I couldn't find anywhere a such modified Bios, alternate reason is that if windows update makes a bios update, the problem is always here...
              so i found that my motherboard...
              10-12-2024, 03:46 AM
