MS-6334 need help!!!!!
    Hi all!
    Mainboard MSI MS-6334 bad cap EC4, EC5, EC11->19.
    I desolded for long time and now I don't know which value for each one.
    Pls check and show me value!!!!!
    Re: MS-6334 need help!!!!!
    Originally posted by kids
    Hi all!
    Are you sure about that board number? I've been to MSI's website, and they don't list that as a product. There was, however, a MS-6330, MS-6337, and MS-6339.
      An old 815 board, couldnt find any pics with any detail
        why dont you show a pic of the board showing the locations of the caps. it must be similar to other 815 boards like ms-6337 and bx master
          Re: MS-6334 need help!!!!! -Pics
          Here my Pics but it's so bad!!!
            the ms-6337 which is also an 815 chipset board used 8 x 1500uf 10V in region of the cpu and 10 x 1000uf 6.3V in other places. Here is a pic. The rest of the caps were very small
              so if you dont get better assistance on this board then i would say to recap all caps between the CPU and the ports with 1500uf 10V and the rest with 1000 6.3V.
              there would probably have been a few caps near the cpu which were actually 1000uf 6.3 but it is safer to replace them with 1500uf 10v because we are not sure of their positions. there would be no problem with the higher values.
              check the below diagram for an example using the ms-6337
              post a pic of your board like that for final checking
                Thanks for your help!!! I'm trying. Hope it's working.
                Here my way:
                EC11->EC19 : caps 1000uF-10V (10x20mm)
                EC4, EC5: 1500UF-10V (8X23mm)
                OK???
                  Here my way:
                  OK???
                  Do you still have the parts that you removed? If so, is that consistent with what you installed (nine 1000uF, 2 1500uF)? You want all the parts you install to have equal or better ratings than what you removed. So, if any parts were originally 16v, they are probably on the +12v line, and installing 10v parts will result in very short lifetimes.
                    815 PIII has 12V?
                      It comes on to the board via the ATX power connector. Whether it is used on the board or not really doesn't matter; if it is, it would more than likely be for some peripheral. If there are any caps on that line, filtering it relative to ground, they need to be 16V or higher (25V would be preferable). In fact, the line would probably be at a higher voltage if it is loaded lightly or not at all, due to no load to pull it down, making properly rated capacitors all the more important.
