Hello everybody, this board I recieved time ago and didnt know what to do to it, I had already recapped the 1000/6.3 cheapo teapo for some others, mostly SANYO and SMG but it showed no POST after that, the only time it showed something it got stuck at the mem check with only one DIMM installed halfway with memory error, i changed DIMM and had no post since then, not a single one.
this pics is how I got the board:
https://www.badcaps.net/forum/attach...id=16715&stc=1
https://www.badcaps.net/forum/attach...id=16716&stc=1
https://www.badcaps.net/forum/attach...id=16717&stc=1
this is after cleaning:
https://www.badcaps.net/forum/attach...id=16724&stc=1
https://www.badcaps.net/forum/attach...id=16718&stc=1
since after recap I got no results -but the one i mentioned-, I applied the technique of heating up the CPU socket with some flux and hot air,
this is after the procedure getting ready to test:
https://www.badcaps.net/forum/attach...id=16719&stc=1
https://www.badcaps.net/forum/attach...id=16720&stc=1
https://www.badcaps.net/forum/attach...id=16721&stc=1
https://www.badcaps.net/forum/attach...id=16722&stc=1
after the procedura, it began working all afternoon, i thought it was gonna be a success, so I left it all night running mtest+ and when I came back this morning it was stuck with the following screen:
https://www.badcaps.net/forum/attach...id=16723&stc=1
I was wondering: if someone has an idea of what kind of failure this could be? do you think after 3+ hours (pic doesnt show the complete walltime) and 12 complete passes with no errors it could be blamed on the DIMMs? do you think I should re apply the hot air method but higher intensity? or I should recap other caps around the board?.
I already am planning on recapping the two 1500/6.3 Ltec I recapped right besides the DIMM slots since the past board I recapped those for the 1800/6.3 [M] brand caps -originally the board has 1500 in there, cheapo- and the small GSC in between XIMM2 and 3.
As always, Any idea, suggestion, tip, link, doc, any is always welcome.
Thanks.
Thanks.
