XFX RX470 MOSFET driver IC identification *help*
  • lewistech
    • Jan 2022
    • 21
    • United Kingdom
    Hi all
    Trying to identify this mosfet driver ic on my XFX RX470 8gb. I don't have the schematics or boardview to assist. The markings on the IC are AZ1. See picture.
    If anyone has the schematic or board view I would much appreciate it if you shared it! 🤞
    Failing that, is there anyone who can help identify this component?
  • R_J
    • 9606
    Re: XFX RX470 MOSFET driver IC identification *help*
    It might be a NCP5901B ?
      • 21850
      Originally posted by lewistech
      Hi all
      If anyone has the schematic or board view I would much appreciate it if you shared it! ��
      Edit; R_J got it
      It might be an onsemi NCP5901B .Can you put some IPA on the chip and look for the other markings like in the picture https://ae01.alicdn.com/kf/HTB13swaL...ET-Drivers.jpg
      https://www.badcaps.net/forum/showpo...37&postcount=7
      • lewistech
        • Jan 2022
        • 21
        • United Kingdom
        Perfect! Thanks all! ��
        Great link to the code also! ��
        • r12x2
          Mosfet identification on hp pavilion 16-ag0052wm
          by r12x2
          Looking for an exact ID or fully compatible replacement for a dual N‑channel MOSFET used as a synchronous buck pair in a laptop charging stage. The package is the compact ~ 3×3 mm “dual” type where high‑side and low‑side FETs are integrated with a common SW node. The part sits right next to the buck inductor on the charger section. marked as 3840C 35039E. With these thermal pads, it looks like an onsemi NTTFD4D0N04HL or a part from AOS’s AONE family (DFN 3.3×3.3, 8‑pin options such as AONE36132, AONE36182, AONE36196, or AONE38132), but they are not pin‑to‑pin compatible....
          09-25-2025, 04:31 PM
        • Jane
          How do you test MOSFET in laptops ?
          by Jane
          I tried to use this method:
          Testing an N-channel MOSFET:
          Step 1: Discharge the Gate (turn off the MOSFET)
          Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
          Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
          Step 2: Charge the Gate (turn on the MOSFET)
          Now, place the red probe on the Gate (G) and the black probe on the
          09-27-2024, 03:31 AM
        • Oliver111
          Asus UX535L.Help to find name of mosfet driver
          by Oliver111
          Hi! Please help to find mosfet driver name. Laptop is Asus UX535L. CPU PWM - NCP81215D, Mosfets on CPU - fdpc5030sg. Driver - DYU or DYP, cannot find it on google....
          04-08-2024, 07:47 AM
        • sigmeyer
          Mosfet driver trouble replacing 6005A
          by sigmeyer
          So this is not the first time i find a mosfet driver shorted. I am talking about the mains to DC conversion circuits. In this case its a TV , I found a shorted mosfet , shorted safety capacitor and the power resistor was open. I replaced all of those but later found that two of the pins in mosfet driver were shorted aswell. Now this is a big road block for me , as people are no willing to wait for a month for a specific IC to get shipped from china to repair their TV , Is there another solution to fixing this problem? I have some other mosfet drivers laying around and what are the chances of them...
          01-20-2021, 06:18 AM
        • osrex
          LED DRIVER KEEPS DYING
          by osrex
          Hello, this is my first post and im just a beginner, so be easy on me guy. thanks
          i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
          i have no datasheet at all for the LED lights, all i have is its length.
          long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
          as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,...
          05-05-2025, 03:36 PM
