Hi! Please help to find mosfet driver name. Laptop is Asus UX535L. CPU PWM - NCP81215D, Mosfets on CPU - fdpc5030sg. Driver - DYU or DYP, cannot find it on google.
Asus UX535L.Help to find name of mosfet driver
by BlastsailI have a coffee damaged asus laptop with shorted mosfet for vram. Trying to find replacement but I am struggling to. Markings are M3966M and I have attached image of mosfet. Schematics are available which say chip is a QM3966M6 but i am unable to find this chip no matter what combination of letters i put in. I can see there exists an m3966m3 chip but this appears to be the wrong size and markings are different.
I have attached schematic as well to help, mosfet is on page 44 of pdf. I do not know where to start to find a compatible mosfet so any help will be greatly appreciated.... -
Hey guys,
i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
Now i thought something... -
by ScotchmistI have an Asus GA502D, it had a blown mosfet which I replaced and the laptop booted into windows, a few mins later it shut off, the same mosfet was blown. I thought maybe just a bad mosfet but same thing happened again, a few mins in windows and shuts off.
I have removed the mosfet and can run the laptop no problem
The MOSFET is FDPC5018SG
Can anyone point me in the direction of what could be the cause of this, could it be the controller rt3663bc?
Thanks -
by vienzenHelp me find the value of this mosfet from a Laptop Asus FX506L
Board code is: DABKXDMB8E0 REV. E Thank you... -
by MicroSMD LabThe board number is GU502DU. I repaired this a couple weeks ago and it came back with the same issue, same mosfet failed (PQH9201). I'm hoping that the GPU was spared this time.
I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the... - Loading...
