GTX 970 GPU crashes when loading drivers?
  • whc14765
    • Mar 2022
    • 28
    • United Kingdom
    Hey,
    I got a MSI GeForce GTX 970 which had a 2.5ohm short on the PCIE 6pin. I replaced one of the VCORE MOSFETs and the short was gone.
    The card boots up now. I got it booted into Windows, started downloading drivers (didn't install yet) and it just black screened - I assume Windows by that time had started loading its own GPU drivers onto mine.
    After that, everytime the PC would start booting Windows, I would get a a black screen.
    I went into Safe Mode (Worked fine) and installed the drivers. But I get the same issue went booting into normal Windows now. Any ideas on what is wrong?
  • whc14765
    • Mar 2022
    • 28
    • United Kingdom
    Re: GPU crashes when loading drivers?
    UPDATE:
    I managed to get it to boot into normal Windows, started up Heaven benchmark and it immediately went black screen.
    Not sure if I messed up the soldering on that 1 phase or if its an actual VRAM issue.
    • ribcage
      • Sep 2020
      • 45
      • Earth
      Do you have artifacts?
      • candan55
        • Mar 2022
        • 5
        • Turkey
        Re: GTX 970 GPU crashes when loading drivers?
        When the driver is installed, the gpu draws more current, so the mosfets are loaded more. One or more of the phases is not working try changing the other mosfets and make sure they all work.
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3577
          • slovakia
          it can be bad ram. check with MATS. u will find bad chip/s. Bad ram is when u can boot to windows and work without driver normally. when driver is loaded or little load on hi res and ir crash
          OR
          one or more power phase is bad, u must check with scope before coil
          • whc14765
            • Mar 2022
            • 28
            • United Kingdom
            Update:
            Turns out that issue is only happening on HDMI. Card itself was running but HDMI would cut out. DVI is working fine. Very strange
            • Traptor
              • Nov 2021
              • 111
              • Magyarország
              Originally posted by whc14765
              Update:
              Did you try the MATS test as ktmmotocross suggested?
              • Ulhmann
                • Mar 2022
                • 3
                • Uruguay
                Hello everyone. Just another idea: did you check the capacitors? Check if they are ok, maybe when you stress the card in Heaven they get hot and their capacitance values drop below the minimum needed so the voltages can no longer be constant to power the core or the vrams. I hope I explained myself and that it helps. It doesn't explain why DVI works well, but you never know. I will be following this thread. Bye
                • ktmmotocross
                  Boardkiller
                  • Feb 2014
                  • 3577
                  • slovakia
                  u can remove 3 of them and nothing changes
                  • Aeisens
                    Samsung UE50RU7170 not booting /no picture
                    by Aeisens
                    Dear all,
                    My issue is the following:
                    Tv suddenly started to make Strange things and went out. After disconnecting power and restarting, it tried to start but failed. After each attempt it got worse and worse. Now only the Stdb light is on and it is not booting.
                    I checked the power supply -> Backlight on when disconnected from mainboard, so I guess Power supply is ok.
                    Additionally the upper right part of the main-board makes some whistling noise -> probably issue there and therefore issues with booting
                    Question 1: Where should I start to...
                    06-24-2025, 03:07 PM
                  • japlytic
                    DRIVER_PNP_WATCHDOG error re. old drivers in Windows 11 install image
                    by japlytic
                    In a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
                    Tried (only with keyboard/mouse connected):
                    • BIOS + database update
                    • Using latest Windows 11 image built with official image creation tool
                    • Previous setup version for Windows 11 installer
                    • Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
                    • TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
                    • Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
                    06-19-2025, 04:59 PM
                  • Daniel Kubica
                    Dell Latitude 5590 i5-8350U LA-F411P kernel panic when booting from USB
                    by Daniel Kubica
                    I got a bare Dell Lattitude 5590 with missing battery, RAM, RTC battery and Storage, I wanted to put some components in it and use it as my home laptop. After adding a FRU 2GB DDR4 2400 SoDIMM RamaxelRAMI've tried booting Linux Mint from USB, I got an error while trying to boot it. I tried reseating the stick, different slot, didn't help.
                    I tried to boot Windows 10 installer, as that was the stock system my model came with, got a BSOD as soon as the installer started booting, different code every time. I've tried switching to AHCI mode, I've tried linux in legacy mode, I've tried compatibility...
                    06-14-2025, 09:24 AM
                  • pavithra
                    LC6685 based LED drivers
                    by pavithra
                    I have 50 Chinese constant current isolated LED drivers based on LC6685 IC. 35 drivers are working fine, but there is a slight flickering in the rest of the drivers.
                    I have checked the output with oscilloscope and found that there is a slight random voltage fluctuation.
                    Is it possible to get the datasheet of LC6685 IC?
                    Also highly appreciate if you could let me know what could go wrong....
                    04-16-2024, 02:46 AM
                  • kuba2102
                    Alienware m15 R4 CPU or CPU drivers issue
                    by kuba2102
                    Hi. I had a problem with this laptop that under a load it would crash the system, meaning the screen would go black and unresponsive. I have noticed that CPU drivers surrounding area of PCB has changed colour due to high temperature. I have tried to reball the Drivers, but after it laptop wouldn't turn on at all and it would trigger over current protection in the PSU. I ordered and replaced 3 of of 5 Drivers (3 CPU, 2 IGPU?), and it started producing 1.2V again but just for a second. I get led flashing out the CPU failure code. Now I'm not sure whether there is still a problem with the drivers...
                    01-04-2023, 09:05 AM
