LC6685 based LED drivers
  • pavithra
    • Apr 2023
    • Sri Lanka
    I have 50 Chinese constant current isolated LED drivers based on LC6685 IC. 35 drivers are working fine, but there is a slight flickering in the rest of the drivers.
    I have checked the output with oscilloscope and found that there is a slight random voltage fluctuation.
    Is it possible to get the datasheet of LC6685 IC?
    Also highly appreciate if you could let me know what could go wrong.
    • 31277
    show a picture of the chip
    • japlytic
      DRIVER_PNP_WATCHDOG error re. old drivers in Windows 11 install image
      by japlytic
      In a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
      Tried (only with keyboard/mouse connected):
      • BIOS + database update
      • Using latest Windows 11 image built with official image creation tool
      • Previous setup version for Windows 11 installer
      • Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
      • TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
      • Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
      06-19-2025, 04:59 PM
    • Geeker007
      Please review my ESP based WLED controller board for WS2815 12V LED Strips - New to electronics.
      by Geeker007
      I'm designing an ESP-based WLED controller board for WS2815 12V LED strips, with a primary focus on energy efficiency.
      To minimize power consumption, my goal is to completely shut down the system when the LED strip is turned off.
      However, the current buck converter powering the ESP module draws about 8 watts even when the LEDs are idle, making it unsuitable for low-power operation.
      I am using below components:
      • Buck Converter: TPS562201 (12V → 5V regulated)
      • Microcontroller: XIAO ESP32-C3 (with built-in USB-C)
      • LED Strip: WS2815 (12V digital LED strip)
      • Switching
      06-29-2025, 05:20 PM
    • kuba2102
      Alienware m15 R4 CPU or CPU drivers issue
      by kuba2102
      Hi. I had a problem with this laptop that under a load it would crash the system, meaning the screen would go black and unresponsive. I have noticed that CPU drivers surrounding area of PCB has changed colour due to high temperature. I have tried to reball the Drivers, but after it laptop wouldn't turn on at all and it would trigger over current protection in the PSU. I ordered and replaced 3 of of 5 Drivers (3 CPU, 2 IGPU?), and it started producing 1.2V again but just for a second. I get led flashing out the CPU failure code. Now I'm not sure whether there is still a problem with the drivers...
      01-04-2023, 09:05 AM
    • kotel studios
      Intel D865PERL - no Vcore after replacing MOSFETs and MOSFET drivers
      by kotel studios
      Finally got time to fix this board up.
      At first it didn't give any POST codes. Turns out it was an unsupported Celeron D cpu. After dropping in an Celery 2.6gHz the CPU came out of reset with clock signal, but still no post codes. For a while it did work when I applied pressure to the ADP3168 chip, but on next reboot the MOSFETs started to burn. Then I left it as is for months.
      Now I came back prepared. Replaced the bad MOSFETs and the ADPxx18k drivers. Now I don't get any MOSFETs blowing up issues anymore. But sadly, the Vcore is missing. The whole VRM isn't...
      04-22-2025, 05:08 AM
    • Rickkap
      Macbook Pro 14 2021 - A2442 - 820-02098-A not turning on 5v fluctuation
      by Rickkap
      I would like some help with this MacBook if possible. It came in with not turning on and the Magsafe light was off. After inspecting the logicboard i cannot find any liquid damage and also no burnt or shorted components.
      took some measurement and i can see i have fluctuation on PP3V3_S2 and also PP5V_S2_MAIN amongst other rails. Using the thermal camera RC282 & RC283 were pulsing, but after removing these it was still the same.
      I then did some investigation into why the rails were pulsing and noticed that P5VS2_PWR_EN (comes from U8100) is also doing the same thing.....
      11-18-2024, 03:36 AM
