MSI BX Master
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    MSI BX Master
    well we are really at the bottom of the parts box at the office. this one is a MSI BX Master which is now running a celeron 667 using ms-6905 slocket. it has been recapped using sanyo wg and chemico kzg from a dead board with not much mileage on it and practically new panasonic fc from my only failed recapping.
    the papst fan you can see is another reject, it is too big to fit any heatsink i have so is attached with wire to the heatsink.
    one prob i saw with using salvaged caps is that you have to clean the leads of existing solder. i was using a solder sucker for that job. it takes a long time to do that.
    i should note that it is recommended to use new caps only for various reasons.
    i hope nobody takes a look in the box
  • harp
    Metod for removing glued heatsink from fragile component
    by harp
    I have peltir element glued to heatsink with something thick and sticky like putty... it cant be separate with force or heat without risk of breaking ceramic or damaged semiconductor layers due to force (eg if try twisted, pulled, lifted)... method that I am using is a single thread for needle (thin and firm thread of pure polyester that cant break with bare hands without glowes), and using it like a saw between heatsink and peltir. I holding a heatsink with knee against table. It slowly cut throug putty and release glued parts. It is slow proces, but preserve undamaged component and heatsink....
    06-23-2025, 02:01 PM
  • Ven
    Seeking Advice on Enhancing Heatsink for Main Processor on SAMSUNG TV Motherboard
    by Ven
    I'm looking to upgrade the heatsink on the main processor of my TV's motherboard for better cooling performance.
    The current heatsink is a square-shaped one (2.8cm x 2.8cn) with a basic design, and I believe a more efficient heatsink could help with thermal management and potentially extend the life of the TV.
    I'd appreciate any advice on the best type of heatsink to use, specific product recommendations, and tips for installation.
    If you've done a similar upgrade, I'd love to hear about your experience and any challenges you...
    07-08-2024, 09:32 AM
  • stormanimal83
    Nintendo Switch picofly installed cause parental lock how to get Master Key for restoring OFW
    by stormanimal83
    i bought a use console from ebay fixed it and it has parental lock. seller wasn´t helpful and nintendo either cause they don´t support used devices as they told me per mail. thanks for the bad support here in germany. was totally upset as i read the answer to my mail from 1 week ago.... there was no other way to get rid of that code rather than modding the console cause i didn´t even had the device id as it´s a patched V1 and for getting masterkey on salthax there is the need to type in the device id which was unknown in this case... i did a mistake. after the repair i entered my wlan and...
    08-04-2024, 01:47 AM
  • harp
    can fanless heatsink replace poor original on RX26PG2
    by harp
    I have RX26PG2 graphic card with incomplete original heatsink, only aluminium plate... but in original solution it look like such bad termal design that I asking if is proper fanless heatsink be adequate replacement ot better... what you think? Till powering on, it is propper hot......
    06-25-2025, 10:56 AM
  • The WABBIT
    Dell Inspiron 5559 need BIOS Master PW
    by The WABBIT
    I had recently purchased a used Dell Inspiron 5559 that I had found at a local pawn shop. And of course the system is locked. And I have no idea what the Admin pw is and I have no information for the previous owner.
    After many days of research I have found that this system, like many new system, require a Master PW/Code to unlock it or reprogramming of the BIOS.
    Contacting Dell Support was a waste of time. They won't give me the the Master PW/Code unless I have the information of the Registered owner that they have on file. They even gave me a link to a page on their...
    07-12-2021, 04:20 PM
