Looking for MOTHERBOARD MANUAL MS5191
  • sam67
    • 256
    Any one have this old manual ,cannot find it on the msi site..
    This is a fully working mobo and has a bloated cap ...just need manual to look at jumper settings and what not.
    Cheers.
  • Sudum Gumudu
    • Sep 2005
    • 97
    Re: Looking for MOTHERBOARD MANUAL MS5191
    How about here: http://www.motherboards.org/mobot/manuals/MSI/MS-5191/
    • sam67
      • 256
      Thanks for the link..for some reason i went to this site but obviously i did not look hard enough lol.
      Thank you
      • sam67
        • 256
        Can anyone tell me what are the right settings to try this 0ld mobo (it's just for practicing on ) but not sure what the settings on the SW1 should be and the jv1 setting..the cpu is a AMD-K6-2/500 AFX
        Just need to check all settings before powering on ,so if some one can give me an insight it would be appreciated.The manual can be found on the above link but i am struggling to add it as an attachment as i am running ubuntu and and just getting my head around using this
        Thanks in advance p.s not sure what the right settings i should use from the above manual.
        • sam67
          • 256
          here is a link to the old cpu
          http://www.oldcpu.cz/CPU/AMD/K6-2/AMD-K6-2-500-AFX
          • pfrcom
            Oldbie
            • Jun 2006
            • 1230
            According to the manual:
            SW1 is used to adjust CPU clock frequency
            K6-2/500 should be 100mhz Front Side Bus, with 5 multiplier, so for SW1:
            4, 5 & 6 should be all set to Off, for 100mhz
            1, 2 & 3 to Off, On, On for 5 multiplier
            JV1 is the important one, controlling Vcore to the chip - not automatic with this generation, so a mistake could be fatal to the chip
            A K6-2/500 is probably 2.2v - necessary Vcore will be marked on the processor's metal cover
            Assuming it is 2.2v, you want a jumper only on position 2 of JV1
            Triple check this advice, the manual, and your settings of JV1 - no responsibility if you fry your chip !
            better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
            • sam67
              • 256
              Thanks for that got it working
              • glovecaps
                by glovecaps
                11-25-2024, 04:23 PM
              • Docus
                Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
                by Docus
                Hi everyone 😀,
                I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
                To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
                Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
                1. I already own the exact same model, but its plastic chassis is badly damaged.
                06-10-2025, 04:24 PM
              • Archimedes
                HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
                by Archimedes
                Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
                Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
                Fans are spinning. Blindly could install windows11 and got the device manager...
                07-30-2024, 05:14 PM
                ASUS P5GC-MX motherboard recap
                by momaka
                Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                So here is what the motherboard looked like with its original caps:
                CPU VRM area up close…...
                01-27-2021, 11:59 PM
              • dragon3x
                by dragon3x
                power on.
                Here are some examples :
                switching supply area).
                than 6.3 V.)
                03-21-2025, 02:46 PM
