Possibly burnt/damaged component U100 on RX460 - can anyone identify?
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    Hi guys
    Can anyone identify this component U100
    See the video at 38mins 20secs (microscope close-up)
    https://www.youtube.com/watch?v=lgQirxbbov4
    It connects to the SMRESET signal coming in from the PCIe pin 11 and is presumably a logical AND gate or dual transistor/FET
    Rich
    Follow me on YouTube
    Learn Electronics Repair
  • Scotchmist
    • Apr 2019
    • 60
    • United Kingdom
    Re: Possibly burnt/damaged component U100 on RX460 - can anyone identify?
    Dicky,
    I have two of those exact cards, 1 working and 1 dead.
    The resistor does not go across them two pins but goes down instead, see attached image
    If you want me to measure anything or take photos of the area with possible parts missing let me know
    • Scotchmist
      • Apr 2019
      • 60
      • United Kingdom
      Just noticed another resistor missing below the 1st one and u100 has the same markings as the working card so don't think it is a burn/scorch mark
      • dicky96
        Sun Seeker
        • Mar 2017
        • 1825
        • Spain
        Thanks Brian
        Having a god working one in front of you is better than me working out how it should work based on theory alone
        I don't think I did bad though all things considered
        • R_J
          • 9632
          Here is a capture from the video of U100
          • dicky96
            Sun Seeker
            • Mar 2017
            • 1825
            • Spain
            @R_J
            Yes that is the part - anyone know what it is and any advice if it is damaged or not? It's a bit clearer to see on the original video, make sure you select 1080p in Youtube
            @scotchmist
            Yes if you could take some wider field pics of hte whole area, I seem to have several missing components though I did get the GPU to power up now.
            Also if you have the time to measure the values of the resistors you already know I have missing already that would be helpful
            Thanks again
            • Scotchmist
              • Apr 2019
              • 60
              • United Kingdom
              Will get photos and measurements for you tomorrow, do you need and voltage measurements?
              Originally posted by dicky96
              @R_J
              @scotchmist
              Thanks again
              • dicky96
                Sun Seeker
                • Mar 2017
                • 1825
                • Spain
                @scotchmist
                Why not, any information helps
                • R_J
                  • 9632
                  It could be a 74AUP1G57GM sot886 (XSON6) Marking aC
                  • Scotchmist
                    • Apr 2019
                    • 60
                    • United Kingdom
                    Hi Dicky,
                    The top one is a 10 k and the bottom is 0 ohm.
                    I will get some readings from u100 later for you to compare to.
                    • Scotchmist
                      • Apr 2019
                      • 60
                      • United Kingdom
                      Photo of board, hope they are clear enough
