386SX motherboard - ID
  • tmcw
    • Oct 2010
    • 382
    • Ireland
    Found this 386SX motherboard in the trash at work and trying to find info about it, but just can't seem to pin it down.
    Can't find a manufacturer name on the board, but a sticker on one of the chips suggest it might be a "Yoke"? A serial number on a sticker on the side of one of the ISA slots begins "YK...", so maybe it is made by "Yoke", but you can imagine the irrelevant hits you get when searching for "Yoke" and numbers on the board. I'm getting hits from anything like flight sim controls to moterbikes.
    The sticker on the chip at the middle-top of the board says "Yoke 401-V5".
    There is something silkscreened between a couple of ISA slots that I think says 401 "?"386SX-08, it's partially obscured by some solder spots/thru-holes.
    I've sifted through hundreds of 386SX photos in internet searches, but can't find it.
    The big chips don't seem to be the CPU, would it have been in the socket at the bottom left?
    I've attached a photo of the top-side, nothing of interest on the bottom-side.
  • tmcw
    • Oct 2010
    • 382
    • Ireland
    Re: 386SX motherboard - ID
    I went back to have a better look at the number on the board, but still not sure of a few of the characters.
    Looks like...
    401-C86SX-08
    But I'm still not getting any hits on that string, or slight variations of it.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8703
      U44 I think is the CPU.
      U43 is the optional coprocessor.
      It looks like 2MB RAM installed.
      • brethin
        • Dec 2008
        • 1907
        Give us a shot of the back side.
        • R_J
          • 9602
          This might help. https://stason.org/TULARC/pc/motherb...401-386SX.html
          • tmcw
            • Oct 2010
            • 382
            • Ireland
            Shot of the back attached. Nothing much going on there, just traces and tru-holes. And the number 9034.
            • tmcw
              • Oct 2010
              • 382
              • Ireland
              Originally posted by R_J
              Thanks for digging that out, U44 is indeed the processor. I wonder what the "combo" means?
              https://www.cpu-world.com/CPUs/80386...0386SX-16.html
              • glovecaps
                Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
                by glovecaps
                I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
                My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
                The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
                11-25-2024, 04:23 PM
              • Docus
                Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
                by Docus
                Hi everyone 😀,
                I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
                To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
                Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
                1. I already own the exact same model, but its plastic chassis is badly damaged.
                06-10-2025, 04:24 PM
              • Archimedes
                HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
                by Archimedes
                Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
                Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
                Fans are spinning. Blindly could install windows11 and got the device manager...
                07-30-2024, 05:14 PM
              • dragon3x
                After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                by dragon3x
                Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                power on.
                Here are some examples :
                (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                switching supply area).
                (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                than 6.3 V.)
                1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                I replaced capacitors with aluminum-polymer.
                3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                03-21-2025, 02:46 PM
                ASUS P5GC-MX motherboard recap
                by momaka
                Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                So here is what the motherboard looked like with its original caps:
                CPU VRM area up close…...
                01-27-2021, 11:59 PM
