Gigabyte GA-Z270P-D3 Boot Loop
  • pelolu
    • Jul 2021
    • 22
    • España
    Bought this second hand motherboard.
    Seller told me was working fine.
    Boot loop happens
    24 pin + 8 pin power connectors without any processor, ram, mouse, keyboard installed. Loops inmediately, lasts half a second
    Power with only CPU installed, the loop lasts 2-3 seconds.
    No post, no beeps.
    Motherboard looks fine, nothing rusty or burnt.
    I´ve flashed official Gigabyte BIOS with CH341a usb programmer, both main & backup BIOS chip. Procedure finishes correctly.
    PCH gets warm even loop is very short. CPU keeps cold.
    Digital multimeter measurements:
    Inductors near PCH show 12v & 1v
    Inductors near cpu socket shows 1,02v & 0,86v
    Inductor near RAM socket shows 1,2v
    In continuity mode all solid capacitor seem good, even smd caps tested.
    There are other many smd chips i haven´t tested, dont know how.
    Bios chip is a Macronix 25L6473F, 8 pin is missing voltage.
    Two PSU´s & processors tested with the motherboard.
    Sorry for my horrible explanation, i am not a native english speaker.
  • taxxin
    • Mar 2021
    • 132
    • thailand
    Re: Gigabyte GA-Z270P-D3 Boot Loop
    Check out some of the discussions on here by DICKY69 I only read briefly about how there is bios and also the TPU firmware which is like a pre-bios bios thing, Im not exactly sure if this applies to your board but a z270 is for sure a high end board.
    Sorry i cant be of much help
    Successfully completed Repairs:
    Current repairs:
    • dicky96
      Sun Seeker
      • Mar 2017
      • 1825
      • Spain
      @taxxin
      Actually it is SMDFlea that knows about the TPU firmware, I'm a beginner on that same as you. Apparently it does apply to all Zx70 motherboards
      Unfortunately so far we couldn't identify the TPU ROM on my board but I'll get back to it and have a good look tomorrow
      Follow me on YouTube
      Learn Electronics Repair
      • pelolu
        • Jul 2021
        • 22
        • España
        Thanks for the answer.
        As far as i know my motherboard does not have the tpu module, or either i can´t find it.
        Thought it was a feature implemented in Asus motherboards.
        • dicky96
          Sun Seeker
          • Mar 2017
          • 1825
          • Spain
          I think I located the TPU ROM on my board
          https://www.badcaps.net/forum/showthread.php?t=83211
          • pelolu
            • Jul 2021
            • 22
            • España
            What about buying a new BIOS chip, and replace it with the M_BIOS one?.
            Is it possible that the main BIOS chip is defective somehow?
            • pelolu
              • Jul 2021
              • 22
              • España
              Main Bios
              • dicky96
                Sun Seeker
                • Mar 2017
                • 1825
                • Spain
                Just reprogram the BIOS_M and BIOS_B with a known good file
                • pelolu
                  • Jul 2021
                  • 22
                  • España
                  It´s useless, tried with Asprogrammer, Neoprogrammer, Colibri & a bunch of BIOS files downloaded from Gigabyte official web site and also the original dump file that came with the motherboard.
                  Must be a motherboard power issue, as the loop happens with no cpu installed.
                  • pelolu
                    • Jul 2021
                    • 22
                    • España
                    Tested the 12 Vcore mosfets with DMM.
                    4C010N (N channel 30v, 46A) Diode mode, drain-source voltage 0,496v
                    4C06N (N channel 30v, 69A) Diode mode, drain-source voltage 0,116v
                    High mosfets are low from specification 0,4-0,9v
                      • 20643
                      Test in ohms mode, 2k on the meter if you have that. one way should be 250-500 the other OL/1
                      • pelolu
                        • Jul 2021
                        • 22
                        • España
                        Made further measurements in diode mode
                        4C010N reversing probes 0L
                        4C06N reversing probes 0.116v. Same as positive source & negative drain
                        4C06N resistance mode 100 ohms (caps after inductors have the same value)
                        4C010N resistance mode 9,26 kohms
                        Are all in circuit measurements.
                        I can´t activate the mosfets by putting positive probe in Gate & negative in Source.
                          • 20643
                          Test in ohms mode
                          • pelolu
                            • Jul 2021
                            • 22
                            • España
                            Test in ohms mode
                            I call it resistance mode, I think we are talking about the same, right?
                              • 20643
                              Yes. The 600 setting is ok.
                              • pelolu
                                • Jul 2021
                                • 22
                                • España
                                100 ohms mosfet OFF drain to source
                                The other way is mosfet ON?, can´t activate
                                • pelolu
                                  • Jul 2021
                                  • 22
                                  • España
                                  Tested all solid capacitors with ESR meter, all below the worst reference value.
                                  • NolesFan
                                    Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
                                    by NolesFan
                                    Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
                                    10-24-2024, 06:36 PM
                                  • Takeatry
                                    Yet another Samsung QLED Boot Loop
                                    by Takeatry
                                    Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
                                    10-04-2024, 02:57 PM
                                  • blaster_
                                    Samsung UE49MU6105K - boot loop, horizontal lines
                                    by blaster_
                                    Less than a year out of warranty, samsung UE49MU6105K craps out, they've got this designed obsolescence down to an exact science of self destruct when out of warranty...
                                    Screen started to show horizontal lines and ghosted image at the bottom, then turned off by itself. Did software update, to no avail of the line problem, and got a boot loop after some minutes of watching TV. This boot loop will turn on the backlights for some seconds the sound comes on, the image will turn dark very fast and then it reboots again. Pressing power button will not put it on standby. Disconnecting...
                                    06-22-2022, 05:19 PM
                                  • torchzack
                                    Samsung 55" TV - Boot loop but sometimes works fine - UE55MU6470U
                                    by torchzack
                                    Hi Team - just joined to see if anyone can offer some expertise in diagnosing an issue with a TV.
                                    I've done a few hours googling and youtubing but just seeing if anyone has any insight here. I got a 55" Samsung UE55MU6470U which seems to boot loop and then after 10 mins will boot, work for a few minutes, then turn off and repeat.
                                    Whilst it's on into the normal Samsung menu/boot screen it looks perfect - so I can't see there being any screen issues. I've seen lots of videos with taping across clock lines to diagnose which particular one may be an issue but i don't...
                                    08-28-2023, 07:42 AM
                                  • vallllliiii
                                    Gigabyte motherboard GA-H110M-S2PH (rev. 1.0) DDR3 | Boot loop and 5 beeps
                                    by vallllliiii
                                    Hi, last month i bought a broken pc that i tought i can fix for myself but it turned out to be time consuming. The pc turn on and shows no display and beeps 5 times and restarts again and again, i think it s the motherboard because i tested/replaced all the parts except the motherboard. The pc was used mostly for light gaming and i think it wasnt overclocked or something. I tried all the basic fixes(cleaning the ram slots, removing the cmos battery, reseat the GPU/CPU/RAM). I think the last thing to do is to replace or repair the mobo but i prefer to try to repair because i don t want to spent...
                                    08-18-2024, 09:21 AM
