Ecs K7som
  • Snowflake
    • Sep 2005
    Ecs K7som
    Hi people,
    I just bought a used ECS K7SOM MB.
    But there are some capacitors missing...
    here is the list :
    C138
    C129
    C95
    C43
    C30
    C88
    C450
    all are electrolytics one but I need their respective specs.
  • Syseng
    Lenovo P14s Gen 5 SVP unlock
    by Syseng
    This sums up discussion related to Lenovo P14s Gen5 in this thread. Credits go to Sbaro and especially Maxpower3. The locked dump is attached.
    The device is based on NM-F871 motherboard with Nuvoton NPCK397 series controller. The motherboard also contains three BIOS chips: two different Winbond chips for main BIOS and external EC flash, and also a Gigadevice chip which purpose I do not know. The password information is contained directly in controller and thus can be manipulated by reprogramming it, so reprogramming BIOS chips is technically not required, however you may wish to make...
    06-22-2025, 07:44 AM
  • Gjackson
    50PUS7555/12 Backlight no picture
    by Gjackson
    bit of a weird one today,
    Got this set with just backlight no picture, sound etc.. works fine so mainboard and PSU are likely good. I think it's a bad panel but don't know if it's fixable, here's why:
    T-CON voltages all present when both LCD ribbons are disconnected but if both are connected then most of the rails are gone (ex. VGH, VGL, HVDD)
    If only one of the ribbons is connected, I do get a hazy picture from the respective side but there is a loud hum coming from the T-CON board due to what I suspect is overcurrent and the circuitry that generates...
    11-04-2024, 02:48 PM
  • alpersen
    Siemens Washing Machine WM12T581TR/67 Touch Panel not working correctly
    by alpersen
    On the right bottom side it has a start/stop button (normally it is illuminated, when I took the picture it was blinking I took at the wrong time ). and the touch area there is not working, maybe if I am able to touch the most right bottom in a maybe 1 square millimeter area it works. also generally if I touch the normal place where the start stop icon is, the weight + and - areas register so there is a touch calibration problem in that area. All icons maybe 60% of the left side register correctly in their respective size. Siemens service recommends replacing the control pcb and screen (nearly...
    10-24-2025, 01:55 AM
  • FixItBill
    Acer Aspire Vero N20C5 Motherboard FH5AT LA-K092P No Boot
    by FixItBill
    Going over the pictures attached. I have an open circuit between ground and 19V at charger port. I have 5V and 3.3V at their respective inductors. The other three inductors near the CPU measure 1.8V except PLG1 which measures 0V. When the battery is plugged in I get around 9V on pins 7 and 8 at PJP201 but I believe it should be closer to 12~13V. I have the motherboard fully removed and disconnected from peripherals. Please let me know if you need additional information/next steps guidance. Thanks!
    Here's the link to the schematic: https://www.badcaps.net/forum/troubleshooting-har...
    07-21-2025, 12:26 PM
  • grimacelord
    by grimacelord
    07-10-2025, 02:52 PM
