PSU recap that ended badly, ideas?
  • chud
    • Jan 2010
    • 20
    Re: PSU recap that ended badly, ideas?
    370: the larger heatsink on the output side sticks out of the back of the case and has a metal guard around it - I haven't touched that at all solder wise (and it isn't live).
    I only removed the primary side one (small with no guard as it sticks inside the case) to get to some caps that were between it and other one.
    I am pretty sure in the past I have touched that when pc was on, moving cables about inside the case and not got zapped and cant believe you could exposed live metal and it pass any basic safety test.
    Why do you say heatsinks are usually live? surely the elastomer pads and little plastic screw insulator things are there to electrically insulate as much as conduct heat?
    • chud
      • Jan 2010
      • 20
      Can hopefully see I have hot glued plastic film to anything that I thought may be possible to cone into contact with the heatsink
      To the left is the bridge wire that was exposed under the sink which joins two legs of the fet's but not the middle legs that are backing onto the sink. ..and you can also see the track I lifted along with the holes little copper tube (oops!) which goes to a little ceramic disc cap, but its joined underneath too, so its ok
      These are the fet's using the zalman paste and some elastomer i removed from another old psu (that had no paste on it to begin with)
      • chud
        • Jan 2010
        • 20
        ok, i blew more money on it and bought some new aerospace grade Bergquist sil-pad 2000 thermal pads, the best Farnell had.
        This time I used no paste whatsoever, everything was cleaned in degreaser just for good measure too.
        And what is the outcome? well I now get *just* 150-160V between the primary heatsink and earth. These pads are brand new, clean and have 4kV breakdown resistance so there is absolutely no way at all anything is conducting to it - anything remotely able to touch it has plastic hot glued to it.
        I took more measurements this time.
        #between heatsink and earth with psu on and running a test pc 100% ok;
        - uA setting on multimeter says ~3406 uA AC, in mA setting its 1.19mA AC
        - varies about 154v to 161v AC and Hz setting says 290Hz although dont really understand that.
        - Hz on 5v is 300-320Hz and 12v 140-170Hz, relevant??
        - 12v and 5v lines were about exactly that give or take 0.1v
        #between heatsink and earth with pc plugged in but not attached to pc;
        -current at mA setting is 0.02mA
        -sometimes its about 26v AC and can be as much as 95V AC, if i touch negative probe to something else (say other heatsink) and back it changes value sometimes,but not often.
        -unlike before and more like other psu's the 3.3, 5 and 12v lines on the ATX connector measure between only 0.1mv and 0.0mv.
        The voltage in either case rises almost straight away, say within about a second, to drop off to 0 takes a good few seconds, about in line with the pilot light on the switch going out.
        Can anyone understand what on earth is going on, its like its somehow getting statically charged ?
        1 mA can be felt;
        5 mA is painful.
        Above 15 mA, a person loses muscle control, and 70 mA can be fatal."
        I mean if its really got 1mA across it and its at 190V you will get a shock so it cannot be right at all?? It certainly felt like i got zapped with 5mA previously!!
          • 31248
          the sink is held down by solder tabs, do the tracks they solder too go anywhere?
          • chud
            • Jan 2010
            • 20
            sink is only attached by the FETS legs, it doesnt make contact with anything else.
            • Toasty
              • Jul 2007
              • 4171
              #26
              Ah-ha! That's the problem. There are 3 elongated holes in the board that match indentations in the heatsink where mounting lugs are to be mounted. Are you saying that those lugs never did or do not exist?
              The one near the single transistor looks to have been formed (stamped) to hold the leg, but it's missing. That is most likely why you are seeing a voltage on the heatsink. No ground connection. As I said way back ^^, many manufacturers use the heatsinks to complete a connection across the board. All 3 of those lugs interconnect the circuit.
              Toast
              veritas odium parit
                master hoarder
                • May 2008
                • 12175
                • Bulgaria
                #27
                Out of curiosity, I just tested a Bestec PSU that has its primary heatsink soldered to the negative side of the bridge rectifier. And the result: -165 VDC between primary heatsink and ground with the PSU plugged in. It seems to me that this is exactly how chud's PSU would have been if the mounting lugs were installed. If they weren't installed, that's actually a good thing because the negative side of the bridge rectifier is not a ground (not at 115VAC line input anyways... but I'm guessing it's probably the same thing even with 230VAC line).
                chud: with the PSU off and unplugged, try measuring the resistance between the primary heatsink and the negative on the bridge rectifier. If you get very low resistance, like 1 or 2 ohms, then that's definitely where the voltage is coming from. If you don't get any resistance, try measuring the DC voltage between the primary heatsink and ground with the PSU plugged in (keep one hand behind your back and be careful here!). Have the negative probe on the ground/case of the PSU and the positive going to the primary heatsink. Is the voltage positive, negative, or zero?
                • Toasty
                  • Jul 2007
                  • 4171
                  #28
                  I agree that the mains side heatsinks are typically hot, but from his statement that the heatsink is only attached by the FET legs, something is amiss. I went back to the underside shot on the first page and as chud stated, the heatsink is not connected to the board by the mounting lugs.
                  So that leaves only the probability that there is a connection being formed by one of the 3 FET mountings. An insulator may be missing somewhere. Either that, or the heatsink is coming in contact with an exposed conductor.
                  Pull it out and do a resistance check from all of the FET legs to the heatsink.
                  veritas odium parit
                    • 31248
                    if there is no reading for resistance it could be capacitively coupled,
                    in this case you may be able to fit an earth-bond between the heatsink & case.
                    but *only* if the heatsink is 100% isolated from all the fet pins.
                    • chud
                      • Jan 2010
                      • 20
                      #30
                      Toasty, no lugs on the heatsink, it was stamped to take some but none there, just the 3 fet's legs connect it to the board. (The small hole next to the fet thing on its own was created by me desoldering the wrong hole - looking at the board side it appears it was to take a diode although I dont think that is relevant to this)
                      On the front of the psu where the copper fins come out,there are bits of rubber as if to stop any chance the copper fins get bent back abit to make contact with the case and the exit hole in the case has a plastic surround/grommit. Again I dont know if this is relevant.
                      momaka, will have a go at what you suggest in next day or so, need a few days off from the damn thing!
                      There is definately no continuity between any fet legs and heatsink,at least with multimeter, I presume the 4kv thermal pads aren't breaking down at 230v. Indeed appart from the very first silver thermal paste and no insulators 'mistake' there has never been continuity between heatsink and legs.
                      As you can see I have covered most everything vaguely able to touch the heatsink with plastic and hot glue - anyone see anything i couldn't? [caps either side of r17 & r17 itself now also have plastic on them since taking pic]
                      The wierd part is that the voltage is lower (~160 down from 230v AC) since using these new thermal pads and no white paste. Also there is less mV on the outputs, now it seems to be normal levels when off.
                      stj; has me replacing the caps somehow created this? i recapped the entire psu with same uF rated caps, just used next voltage up where possible. Because most of them are physically bigger (even same uF & V ones, Panasonic equivalents all larger (often taller) are they too close to other things causing problems? Th two main input caps are same diameter but about 10mm higher (hence had to Dremel sone of heatsink away).
                      • ahmedtou
                        HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
                        by ahmedtou
                        help me please
                        I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
                        When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
                        I will share all the details with you, including the disc information.
                        Code:
                        HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
                        Current Profile: BD-R
                        Disc Information:
                        Status: Empty
                        State of Last Session: Empty
                        Erasable: No
                        Free Sectors: 12,219,392
                        Free Space: 25,025,314,816 bytes
                        Free Time: 2715:27:17 (MM:SS:FF)
                        Next
                        08-27-2025, 08:49 AM
                      • Stefan Steff
                        HP Elitebook 840 G5 strange behaviour, need ideas...
                        by Stefan Steff
                        I finished my work for this year, so I'm free until January 6th.
                        My last task it's unresolved and I'm looking for ideas for the return in January.
                        So what's about...
                        This laptop is booting in 3-4 seconds has no password and every voltage is present. So far so good.
                        My problem is that it doesn't boot from anything. !...just stays with a blank screen(backlight only)
                        No USB boot (in fact partially no boot...), no PXE boot nor boot from M2.SATA or NVME...crazy...
                        The Ventoy USB (EFI) boots in the menu system but after selecting one of the ISO (like a simple...
                        12-24-2024, 05:50 AM
                      • madan1
                        Cisco catalyst 2960c POE
                        by madan1
                        Hello everyone.
                        Got a catalyst 2960 from the usual scrapyard - ebay.
                        It is stuck in bootloop and the power supply is missing the 3.3v rail. (+12V, -53V, +3.3V)
                        Some green moisture crystallization on mainboard, which cleared very well with IPA and visually there is nothing rusted or gone.
                        Still working on the PSU to get the 3.3v rail back (waiting for parts), but for now I'm using an external buck converter board hooked up to the 12V rail ( by the way, the switch seems to be working with only 12V ).
                        The switch fails to boot due to the following POST error:...
                        12-19-2024, 09:34 AM
                        no-name Radeon 9600 XT recap and cooler
                        by momaka
                        I've been seeing a lot of cheap-looking (but not always so cheap) no-name AGP video cards on eBay for a while. They started popping up quite a bit when the market for AGP cards became more alive all of a sudden due to interest in “retro” PCs. One thing that struck me about these cheapo cards is that they almost always seem to come with garbage caps - including the abominable Sacon FZ. That aside, though, I've been wondering about the rest of the quality (or lack of?) on these cards. So I decided to satisfy my curiosity yet again.
                        This one was actually suggested to me by ChaosLegionnaire....
                        11-06-2020, 07:54 PM
                      • Lostdotfish
                        KZG caps failed on a NOS motherboard - never been used...
                        by Lostdotfish
                        This is a new one on me. I picked up a new old stock DFI 865PE Infinity board recently. It's completely new, never used. While inspecting it I noticed some unexpected bulging caps...
                        All of the 6.3v 1500uf caps had failed in place, despite the board never seeing use and being stored sensibly. I pulled the 16v caps that are the same series as a precaution and will replace them all.
                        10-15-2025, 04:29 AM
