Compact Motherboard & CPU advise
  • Nevillet
    • Sep 2019
    • 272
    Hi All,
    I have a very compact PC that is housed in a 1U 19" rack case. The problem is that it's sluggish. It is running a stripped back version of W7.
    The PC has the following hardware:
    Motherboard = ASRock N3050-ITX
    CPU = Celeron N3050 @1.6 GHz
    Ram = 4Gb DDR3 @ 1600 MHz
    Hard Disk = 120GB KINGSTON SV300S37A120G SATA
    I'm only running low level apps e.g. Chrome, Excel, Word, VLC, etc
    So I'm looking at upgrading the MB, CPU & RAM. It doesn't have to be new.
    But the important thing is the height as in the CPU needs to have a low profile passive heat sink.
    The external height of a 1U rack is 44.45mm
    Many thanks.
  • bigbeark
    • Jan 2010
    • 661
    Re: Compact Motherboard & CPU advise
    How much of your HDD space is already used? Have you defragged recently? Have you done a virus scan? Try Malware Bytes to see, it's free. You could upgrade RAM to 8GB.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8703
      Don't defrag an SSD, it doesn't help.
      I know first hand what an Atom at 1.6GHz runs at. If you really want to run video or heavy duty applications, you need to get another CPU. I don't have a problem with the Atom with simple web pages and general office type applications.
      Though I don't have the exact Atom flavor you have but I suspect it at the speed of a 1.6GHz P3 when turboboosted (if enabled) else near 1.2GHz P3 (at 1.6GHz).
      Now finding another 1U-sized fast ITX board... how much money do you have to spend... and anything faster will be using more power and requiring some sort of heatsink modification, likely involving heat pipes.
      • Nevillet
        • Sep 2019
        • 272
        Many thanks both,
        I was always led to believe that defraging a SSD was not good for their health.
        I'll run Malware Bytes on this (and all my other machines).
        Upgrading the RAM is a good and relatively cheap way forwards.
        The machine lives in my garage and is off at the moment but at a guess I'd say that less than 40% of the SSD is used as all my files live on a server.
        Thanks again.
        • lti
          • May 2011
          • 2557
          Check RAM usage in Task Manager.
          There are faster 1U systems (servers), but you will need really loud fans. Low-power CPUs faster than a Celeron aren't easy to find. Most of them are mobile CPUs, and they're soldered to save space.
          • zunasthegreat
            • Dec 2017
            • 92
            • EU
            The sluggish one is the CPU, current era browsing is a lot harder and those weak cores have a hard time. I don't know the cooler clearance for your case but I think intel boxed cooler might fit, there are low profile ones if it won't. If you plan to update don't buy something weaker than a 4C/8T cpu. For example an 10100/H410 or B460 ITX and 8GB RAM will set you back around 180-200$.
            *34mm tall cooler example
            • glovecaps
              by glovecaps
              11-25-2024, 04:23 PM
            • Docus
              Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
              by Docus
              Hi everyone 😀,
              I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
              To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
              Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
              1. I already own the exact same model, but its plastic chassis is badly damaged.
              06-10-2025, 04:24 PM
            • Archimedes
              HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
              by Archimedes
              Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
              Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
              Fans are spinning. Blindly could install windows11 and got the device manager...
              07-30-2024, 05:14 PM
            • dragon3x
              by dragon3x
              power on.
              Here are some examples :
              switching supply area).
              than 6.3 V.)
              03-21-2025, 02:46 PM
              ASUS P5GC-MX motherboard recap
              by momaka
              Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
              This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
              So here is what the motherboard looked like with its original caps:
              CPU VRM area up close…...
              01-27-2021, 11:59 PM
