imac 21 2011 109-C29557-00 vga common issue
  • rookieme
    • Oct 2014
    • 403
    • Greece
    So I've noticed that some imac 21" 2011 vga has a common issue that make the system reboot of just shut down.
    This is not a gpu chipset issue, cannot be fixed by replacing chipset and sometimes it appears after replacing chipset [due to usually faulty 216-0810005].
    So far I have tried reballing vrams, replacing Q601,Q611 & C838.
    Has anyone faced and fixed this issue?
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: imac 21 2011 109-C29557-00 vga common issue
    Did you confirm it is indeed caused by the graphics card?
    https://logi.wiki/index.php/iMac_A13..._Graphics_card
    • rookieme
      • Oct 2014
      • 403
      • Greece
      Yes as I've seen the issue to follow the card to a second imac
      • thodoris10
        • Mar 2014
        • 17
        • Greece
        Did you manage to fix the problem ?
        I 'm just facing the same issue for a second time with this specific card
        • rookieme
          • Oct 2014
          • 403
          • Greece
          this kind fix is waste of time, no hope when issue occurs
          after so much time no progress with figuring out the issue
          • Stephen
            iMac 27” 2020 Boot issue
            by Stephen
            Customer came in for data recovery, came to find out data is soldered on to this iMac (learn something new everyday) this is a 2020 T2 iMac so I was surprised because the iMac Pro has a T2 chip and it isn’t soldered on. Anyways, the iMac boots to Apple logo and then restarts, before it turns off you hear a quarter fan spin then it repeats itself. I decided to do a DFU revive to restore any hardware firmware issues and it was successful in reviving the device however the issue persists in boot looping. It shows the Apple logo for like 40 seconds then turns off and fan spin rinse repeat. I...
            08-16-2024, 09:32 AM
          • Stephen
            iMac M1 DFU restore issue
            by Stephen
            iMac turns on no drops no cracks, tried to DFU Restore the iMac, logo turns on great! however iMac turns itself off and then restarts to the (!) icon and won't post the restore. Tried thunderbolt 3 cable, tried regular USB C cable and nothing.
            this is the message it gives me with the error
            Unexpected device state 'DFU' expected 'RestoreOS' (Probably forced into DFU mode externally) [com.apple.MobileDevice.MobileRestore – 0xFAE (4014)].
            Any thoughts what this could be? I will open it up and repair it but I am not 100% sure since this iMac doesn't...
            03-07-2025, 12:19 PM
          • reformatt
            Intel iMacs, 3rd party SSD failures and Fusion setups
            by reformatt
            I thought I'd throw out some of my personal experiences in the last 12 months with Intel iMacs, 2.5" SATA SSD drives and Fusion drive data recoveries.
            As a backgrounder, Apple never fitted a 2.5" SSD's to these iMacs. Apple's SSD option was a system of 32GB NVMe blade drive (NGFF connector) and Seagate 1TB 2.5" HDD, married together in software to become a Fusion drive. Non Fusion systems have just the 1TB Seagate HDD.
            So, the most common reason an iMac comes across my bench is because it's either ridiculously slow, or it fails to boot at all. The most...
            12-18-2024, 10:34 PM
          • howardc64
            by howardc64
            Problem
            08-04-2024, 10:36 PM
          • roman728
            iMAC A1418 Backlight issue
            by roman728
            Hello friends,
            I have this unit with no backlight on screen. After inspection i determined there is a shorted capacitor on BKL_BOOST circuit. I removed the capacitor, short is gone but backlight still not working. I found that Q9702 is not open and R9721 is only around 70kOhms but according to schematics it should be 301k. I removed the resistor and connected the gate of Q9702 directly to GND. Now i have 12v passing by the mosfet to turn on backlight IC LP8561 (U9700) but BKL_BOOST circuit is not working. I can measure only 12V there but it should be around 60V.
            Can you...
            04-10-2025, 11:48 AM
