I have a dead aorus rx580 8gb. pcie fuse is open above pins 1, 2 and 3, 12V. The other side of the fuse is not shorted to ground. i have 6k ohms on it. resistance from mem controller ~20ohms, GPU phases ~.06ohms. What are the odds that it was blown from a MB surge and not a GPU component? I got this from a friend and dont know the history.
RX580 Fuse blown
Re: RX580 Fuse blown
One way to find out - replace the fuse. I would expect it blew due to excessive current being drawn, not a 'surge'Follow me on YouTube
Learn Electronics Repair
https://www.youtube.com/channel/UCFX...R8UZ2vg/videos -
Since this was your friend's card and since you can get to GPU-Z after replacing the blown fuse... try pulling the BIOS with GPU-Z and also check all the clocks and voltages for all performance levels. It could be that your friend tried to do some overclocking by flashing a new OC BIOS on there, and maybe that's pushing the VRMs too hard.
On the other hand, if you can verify that the BIOS is original stock one that the card is supposed to ship out with, then get MSI Afterburner and lower the maximum power limit of the GPU. After this, stress test and see if the fuse blows again. If it doesn't, increase the power limit slightly, and try again. The idea is to find out where the fuse blows. If it blows way below what this card is rated for, perhaps one of the phases on the GPU V_core may be faulty. Now troubleshooting that can get more complicated.
But do the above checks and let us know what you find. Maybe some new information will come out of that.Comment
Replaced fuse and put that dual amp back. i dont think its working correctly.
Model LM3580
pins
1. output1 - 1.9mV
2. input1(-) - .4V
3. input1(+) - .7V
4. Ground
5. input2(+) - open
6. input(_) - 2.5V
7. output2 - 2mV
8. VCC - 12.26V
Anyways, booted into windows and using AMD memory tweak i disabled phase 4-7 and dropped P3 to 1000mhz and 875mV
Kept memory as is P2 = 2000mhz @950mV
The card runs fine through the benchmark. So i guess the memory circuit is fine and there is in fact an issue with one or more of the vcore phases.Last edited by sdinelli; 02-06-2021, 02:55 PM.Comment
by BabbarI found a project in the electronics trash yesterday. A nice Argon SA1 audio amp with some electrical issue. Took it apart and saw that the 4A250V fuse was blown so started lifting components to find the short. Eventually got to two MOSFETs (model FTA14N50C) that are shorted and when i took them out the short was gone.
Now i didn't have any replacements of the same model of course but i found a couple with pretty similar spec i thought (K10A60D & K12A50D) and put them in. Also replaced the blown fuse with a 3.5A250V one. Checked another time for short circuit and plugged it in.... -
by drscootHP Modelnumber: 14-dh0061nb​
This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
All these 3 batteries are charging...2 Photos -
by beetle1303I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...3 Photos-
by jesteraceHi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
by whc14765Hey,
I have a Gigabyte 980TI Windforce. No shorts on the main 8 pin PCIE power connectors. The 8 phase buck converter inductors are showing 2.5ohms.
The card doesn't power up at all - no lights, no fans, nothing. I noticed that all of the 8 phase inductors are showing 0V. I couldn't find a fuse for the 8pin power connectors.
I did notice that the PCIE x16 connector 12V line has a fuse F3 (10A marked on it) which is blown. It is reading 16ohms on one end.
1st Question: Is there some logic on the board that checks the 12V on the PCIE x16 bus connector... - Loading...
