Oh oh, looks like this Dell PC likely has bad caps!!!
  • RJARRRPCGP
    • Jul 2004
    • 6304
    This user appears to not even bother checking the motherboard.
    http://www.msfn.org/board/index.php?...1&#entry375721
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Oh oh, looks like this Dell PC likely has bad caps!!!
    that model caps bad in psu
    glad i went with hp even though the fans sound like angry hornets
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
      by momaka
      03-12-2025, 03:42 PM
    • huzo
      DELL Latitude 3500 no image, fan max speed, caps lock frozen
      by huzo
      Dell latitude 3500
      Board BOLT-L UMA MB
      17938-1
      FW8G6$LA
      when i press the power, fan goes full speed, power button lights up , and caps lock light is on, the screen polarises, goes dark,no backlight...All voltages present, except PL4701, but that's probably for GPU power later....
      I've tried a few dumps from posts, it always acts the same, so i thin it's not a bios issue...
      No shorts found on the board...
      What should i try next?
      10-06-2024, 02:15 AM
    • Akhlz001
      by Akhlz001
      09-20-2025, 07:15 PM
    • eryjus
      by eryjus
      05-10-2023, 11:21 AM
