Dell Dimension 4800
  • Oerg866
    • Nov 2009
    • 61
    Dell Dimension 4800
    I made a vacation to the USA to visit my aunt and uncle and their kids. It was a wonderful vacation, as I had quite a lot of hardware stuff to play around there with! My uncle uses an old Dell Dimension 4800 (if I remember the model number correctly) as home computer. Now that PC should never die, as there is confidential data on it and stuff. But it ran soooo slow, and sometimes windows wouldn't even boot!
    OK, I came to the conclusion that 68 processes in the BG when idling isn't too good of a windows configuration for a PC like this (P4 2.8GHz, 512MB DDR2-667), but why would Windows refuse to boot sometimes?
    I opened the case and apart from everything being dusty over there, guess what?
    Two, no THREE (One hidden below that green fan thingy) dead capacitors, two nichicons and one KZG or something like that (1000uF, 820uF and 1800uF). Two were buling and the third one hidden under the green plastic was leaking too.
    Now I had to get new capacitors. I've never been to any place in the US that sell caps before, but I heard that RadioShack sells them. I didn't take a soldering iron with me, so I bought one there for, I think, 22 dollars, that had to do.
    I bought 2x 1000uF (Crossing fingers that they would work) because they didn't have 820uF ones, and one assorted pack with a lot of caps in it, where one 1800uF was in. The capacitors they sold seemed to be either old or just extremely big for their kind. I know I'm risking near death again soon because these aren't competition for Rubycons, Sanyos or so, but, I guess it'll do for now.
    It was difficult to get the big caps in there, but with a bit of bending here and there, it eventually worked.
    I booted it up and oops. No picture?! Yellow LED?! ---- Ooooops, forgot to plug in the 4-pin CPU power plug. Meh, let's pretend that didn't happen - So it worked, and I hope that it won't die soon
  • cheese007
    • May 2009
    • 85
    Re: Dell Dimension 4800
    Hate to break it to you, but those Radioshack caps are probably just as bad as what was replaced.
    • c_hegge
      • Sep 2009
      • 5219
      Cheese007 is right. NEVER use general purpose caps (which as all RadioShack sells) on motherboards. Get them from badcaps.net or mouser.
        master hoarder
        • May 2008
        • 12175
        • Bulgaria
        Radio Shack caps are not that bad, they're just not made for that application so they probably won't last very long (if at all).
        On the other hand, badcaps.net and mouser.com will actually have the right caps for a lower price and they will likely arrive in only a few days so I would highly suggest you replace the caps from either one of those places.
        As far as caps, you can get Rubycon MCZ and MBZ from here (badcaps.net), or you can go to mouser and get Nichicon HM, HN, or HZ. Rubycon is probably the best quality cap you can get, though.
        • cheese007
          • May 2009
          • 85
          It would be wise to just recap the entire board as well, instead of just the bulging ones, assuming the rest are the same brand.
          • geforcefly
            • Jul 2006
            • 33
            In addition to the Dimension 4700 having the bad Nichicons, other Dells I've seen (outside of the GX270 and 280) with them are the Dimension 8300, 8400 (and its Precision 370 cousin) and the 4700C (with Teapos).
            • Bowline
              by Bowline
              06-11-2025, 10:13 AM
            • SwedishDiesel
              Dell Dimension PSU Compatibility - B110 PSU in 4550
              by SwedishDiesel
              Howdy folks,
              I've risen from the grave to ask more questions about old obsolete Dells.
              I've acquired a Dell Dimension 4550 which is in need of a PSU - I've several PSUs from Dell Dimension B110s, and I'm wondering if one of them could be used. The PSUs and the 4550 use a 20-pin connector and a 4-pin connector.
              The issue is, I've been told that Dell really likes using proprietary hardware, and there were concerns about damage being caused by an incompatible supply. Because of this I'm assuming it's not just a simple plug-and-play and that there's more...
              12-18-2022, 06:58 PM
              Dell Dimension 8200 Schematic
              LA-1221...
              10-04-2024, 07:48 AM
            • Akhlz001
              by Akhlz001
              09-20-2025, 07:15 PM
            • master3112
              by master3112
              07-29-2025, 01:55 PM
