AsRock H87M bootloop issue
  • DS-1
    • Jun 2015
    • 82
    • Italy
    Hi guys!
    I've bought an AsRock H87M used. I already knew that it had this issue: when you press the power button, fans start spinning for a second, then the system reboots endlessly, until you don't shut off the psu.
    I've checked the pins on the socket and they are all ok.
    What could it be?
    Thanks in advance for the reply!
    • 21845
    Re: AsRock H87M bootloop issue
    Have you tried another PSU, RAM ,CPU.Is the CMOS battery good
    • DS-1
      • Jun 2015
      • 82
      • Italy
      Tried 2 PSUs, with and without RAM, with and without CMOS battery (2.95v). Cpu is the only thing I can't change because I have only one of them (1150), but the previous owner also has the same issue, so I believe it can't be the CPU.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8340
        A memory battery under 3V is considered "spent". Check the pins on the CPU socket and see if some are bent, check and clean the ram slots with 99% IPA, take a white eraser and clean the contacts on the ram. Try using only one stick of ram.
        • DS-1
          • Jun 2015
          • 82
          • Italy
          Thanks for the tips! 2.9v is spent for sure, but can it be a good volts value to make the motherboard works correctly?
          I have to try to clean the ram slots, because is the only things I haven't done.
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8340
            that and maybe the ram is bad
            • DS-1
              • Jun 2015
              • 82
              • Italy
              The issue is present also with no ram stick on, so I believe the ram is not the problem, in this case.
              • DS-1
                • Jun 2015
                • 82
                • Italy
                The strange thing is that, if I jumper clrcmos for a lot of time (around one hour) and I remove the battery too and then I reassembly all and start the system, it starts and I have no reboot, but with black screen. When I turn it off and then turn it on again, the bootloop starts again!
                • Aliencomputres
                  • Aug 2019
                  • 217
                  • România
                  helo,
                  rewrite bios chip!
                  • DS-1
                    • Jun 2015
                    • 82
                    • Italy
                    Originally posted by Aliencomputres
                    helo,
                    rewrite bios chip!
                    I've already tried to rewrite it, but unfortunately it doesn't work.
                    BTW, I took the BIOS ROM from AsRock official page (the .cap file).
                    • Maximilian
                      Need help for Asrock H87M boardview
                      by Maximilian
                      Hi guyzzz.
                      dealing with asrock h87m motherboard, the vcc is not present on pwm and vrrdy is strange! I looked deeply into the board and it seems some components Res/cap missing !
                      if any one has boardview for this model I would be appreciated
                      03-31-2023, 03:06 AM
                    • Dergal T Stonkerson
                      Motherboard not booting up Issue - ASRock IMB-150
                      by Dergal T Stonkerson
                      I have an ASRock motherboard (IMB-150) with Mini-Sata Solid State Drive. I have removed the SSD card and re-inserted. After re-inserting the device will not boot up. During boot up error displayed "Reboot and select proper boot device or insert boot media in selected boot device and press any key".
                      Connections on motherboard and ssd card look in good condition, no signs of wear or damaged connections.
                      During boot up I pressed F2 to select UEFI setup menu and mSATA 3IE is listed as boot device with no other option available.
                      Anyone have some advice...
                      02-14-2024, 10:42 AM
                    • rounin
                      MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                      by rounin
                      I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
                      🛠 Original Issue
                      The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
                      ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                      04-19-2025, 01:18 AM
                    • ugamazing
                      Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
                      by ugamazing
                      I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
                      We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
                      12-17-2024, 07:05 PM
                    • gabrieljma1
                      Request: Full BIOS dump for ASRock Z790-CX (DDR5)
                      by gabrieljma1
                      I’m looking for a full raw 16 MB BIOS dump for an ASRock Z790-CX (DDR5) motherboard.
                      The board powers on (fans spin, RGB lights on, RAM LEDs active), but there is no display output and the VGA and BOOT LEDs stay lit.
                      I’m using an Intel i9-14900KF CPU (14th gen), and it seems the BIOS version on my board doesn’t support it yet. I tried to flash the official ASRock BIOS file (renamed .ROM → .BIN) directly using my RT809H programmer, but it didn’t work — monitor stays on but with black screen, so I believe the ASRock update file is not a complete...
                      10-08-2025, 03:32 PM
