Motherboard not booting up Issue - ASRock IMB-150
  • Dergal T Stonkerson
    • 8
    • Ireland
    I have an ASRock motherboard (IMB-150) with Mini-Sata Solid State Drive. I have removed the SSD card and re-inserted. After re-inserting the device will not boot up. During boot up error displayed "Reboot and select proper boot device or insert boot media in selected boot device and press any key".
    Connections on motherboard and ssd card look in good condition, no signs of wear or damaged connections.
    During boot up I pressed F2 to select UEFI setup menu and mSATA 3IE is listed as boot device with no other option available.
    Anyone have some advice on how to repair/diagnose/fault find..?
    Thanks in advance for any help..
  • McWhitePink
    • Apr 2023
    • 103
    Might be the UEFI issue. I don't think anything damaged. you can boot with a USB drive and reinstall the OS to your SSD.
    but a BIOS reset may also fix the issue. it's just annoying to mess up with the UEFI.
      • 8
      • Ireland
      How do I reset the BIOS?
      • McWhitePink
        • Apr 2023
        • 103
        Remove the RTC battery and short the two pins for more than 10 seconds. or short the CLRRTC pins for 10 seconds
        • dragon3x
          After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
          by dragon3x
          Hi, I have some 32 bits computer motherboards that need repair, as they fail to
          power on.
          Here are some examples :
          (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
          switching supply area).
          (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
          than 6.3 V.)
          1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
          I replaced capacitors with aluminum-polymer.
          3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
          03-21-2025, 02:46 PM
        • Docus
          Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
          by Docus
          Hi everyone 😀,
          I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
          To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
          Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
          1. I already own the exact same model, but its plastic chassis is badly damaged.
          06-10-2025, 04:24 PM
        • Bonaventure Vigil
          Variable DC Power Supply cannot boot motherboard
          by Bonaventure Vigil
          Hi there,
          Guys anyone here can help me. During troubleshoot the motherboard, my 1st and new psu unable to boot the motherboard. Even though i set the 20V, my old Compaq CQ42 motherboard had the led white light at charging port. When press on button, the led blinking to red and gone back to white state. But i change the oem hp compaq adapter which is i measure 19.45V. Using that can boot the motherboard and fan spinning. Then i reconnect psu and tried set the 19.45V, still blinking red. Anyone know what happen? Is it psu not compatible? All is check and voltage is there....
          10-17-2024, 12:16 AM
        • claws77
          FX553VE-DM318T(FX553v) not POSTING
          by claws77
          Cpu i7-7700hq Ram - 8gb samsung, 32 gb sk hynix
          Gpu - nvidia geforce 1050ti
          Ssd orion o700
          Hdd hgst721010A9e630
          See images
          What's not working right?
          The system does not even POST, display is black,
          LEDs on - power led, aiplane mode, capslock fpr few seconds in the start(when connected to ac power) only.
          When did the problem happen?
          My laptop had dual boot setup, ubuntu and windows 10.
          It already had a moklist error, that would occur when i tried to boot ubuntu.
          05-17-2025, 04:09 PM
        • Exim
          ASRock N100M, no picture no boot, but semi-alive
          by Exim
          Hi guys,
          I managed to semi-kill an ASRock N100M board after updating Bios from 1.10 to 2.01. It's a zombie now, dead, but not dead.
          ASRock N100M special features:
          - CPU soldered to board, small Intel 12th gen
          - iGPU
          - four POST LEDs
          Problem after updating Bios to 2.01 using the in-Bios update tool: no picture, no boot.
          I am not sure anymore if it booted at least once successfully after updating the bios to 2.01, maybe not, I can't remember. I think it did not.
          Symptoms:
          - no picture/signal on any of the display connectors,...
          04-01-2025, 02:36 PM
