440MX - my first successful recap
  • Oerg866
    • Nov 2009
    • 61
    Hi.
    I noticed for a long time that my noname Geforce 440MX has problems in 3D display, like Trackmania and that the 4 RIFEKING caps are bulging a little. But, it depends of the angle you're looking at it, how it is bulging: not at all, a little, much. If I took a picture it always looks like it's not bulging at all. But I noticed that someone else had problems with RIFEKINGs on Geforce 4s. I got a dead board here and got some SANYO and RUBYCON caps from it and soldered them on the card.
    Original RIFEKINGs were 470uF 6.3V. I asked a friend who is an engineer if it is safe to put on these higher ones (1500uF, 2200uF), he said yes.
    Result 1: POST like normal, still have to test 3D, but so far it's successful
  • c_hegge
    • Sep 2009
    • 5219
    Re: 440MX - my first successful recap
    Nice job!
    I would advise against changing the capacitance, but if it works, it works.
    • Oerg866
      • Nov 2009
      • 61
      DAMN. The RUBYCON cap is bulging and leaks!!
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        You probably have it in backwards or the original cap was bipolar.
        or
        It's overheating because it's touching that heatsink.
        Mann-Made Global Warming.
        - Dr Seuss
        • Oerg866
          • Nov 2009
          • 61
          The card never heats up at all even when playing games
          I went to the bathroom and when I came back I find the screen garbaged (MEMTEST still running fine though) and the cap bulging.
          How do I get off that cap correctly without risking it to blow electrolyte in my eyes??
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            You are doing okay for someone new to this stuff.
            This is meant to be constructive so don't take it the wrong way. - K?
            - c_hegge made a good call about changing uF.
            - Elaborating on that.
            Their is some 'ancient wisdom' that says using more uF makes PC's more stable but as it turns out the 'ancients' were probably wrong.
            When they raised the uF they usually inadvertently lowered the ESR because the new caps were either physically bigger or a better grade or both.
            - Raising the uF didn't do squat for them, it was lowering the ESR that helped.
            Another thing is that if ESR matters in a circuit with lytics then the existing uF is usually already over-kill. More uF than needed [and using a higher voltage caps than needed] are both side effects of trying to get the circuit's ESR lower without using more expensive [better grade] caps.
            Assuming you don't change the grade of cap, caps with lower ESR are physically bigger caps. Physically bigger caps are either for a higher voltage, are more uF, or both.
            There are some circuits on motherboards and in PSUs where we [geeks with soldering irons] know by way of numerous mad scientist experiments [um, I mean experience] that raising the uF doesn't hurt anything, but, extending that ?theme? into other circuits on other parts can get you into trouble.
            If the capacitance [uF] affects a frequency or a circuit's timing [sequencing with other circuits] then changing uF can screw things up pretty bad.
            Most caps on motherboards don't have functions like that but there are some places on motherboards were changing uF is probably a bad idea. An example I can think of is Dell socket 478 and 775 boards for P4 and C2D. Virtually every one I've seen has a 680uF that does something for the north-bridge of the chipset, yet there are several 820uF caps elsewhere on the same boards. It would simplify manufacturing and cut costs to just use another 820uF where that that 680uF is, but they don't. Obviously that 680uF NEEDS to be 680uF. The uF on that one probably affects the chipset's timings. [Sequencing with other circuits.].
            All of that said:
            -Usually- you get lucky when you raise uF - A LITTLE. [But not -always-.]
            The uF tolerance on Lytics is +/- 20%, and uF tends to go down as caps age, so -usually- going up 20% won't hurt anything and as a plus as the cap gets older it gets closer to the original value anyway.
            - If you dunno what the cap does it's best to not change uF. Using a better grade with the same uF but with lower ESR is a much better solution.
            And, 470uF to 1500uF or 2200uF is a heck of a lot more than 20%!
            20% would be from 470uF to a 560uF.
            Now, I have no idea what those caps on that card do so >I< can't say if your mod is okay or not. It's just pushing it way past what I would try.
            - Did that engineer friend actually analyze the circuit and do the math before telling you that raising the uF that far was okay? I could be wrong but it really sounds like he[or she] perpetuated 'ancient wisdom' without actually looking into it on that particular card.
            - Dr Seuss
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              Bloated caps don't usually pop from de-soldering.
              If you are worried about it just face to solder side of the board [only] while you work on it.
              - Dr Seuss
              • Oerg866
                • Nov 2009
                • 61
                Thank you for elaborating Yeah the card run stable until it bulged. I found a perfect replacement cap on a MSI board I had laying around.
                Laters,
                Oerg866
                • kc8adu
                  • Nov 2003
                  • 8832
                  • U.S.A!
                  watch out as the markings are sometimes reversed .
                  that got me a while back as i pulled all the bad ones,got distracted,and later ASSumed the white was -.poof!
                  replaced them again and ok.
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    Using used Lytic caps can also be a problem.
                    Aluminum Electrolytics 'adjust' to the applied voltage within a few hours.
                    [With aluminum electrolytics]
                    If you put a 16v rated cap in a circuit with only 3.3v present then after a few hours it becomes a 3.3v cap.
                    This is because the chemistry inside the cap adjusts the thickness of the aluminum oxide layer [which is the dielectric] according to the applied voltage.
                    More volts, thicker layer.
                    If you then put that cap with 16v written on the side but that has been 're-formed' to 3.3v into say a 12v circuit the oxide layer [dielectric] is too thin. Then what amounts to arcing between the plates can occur right through the dielectric. That can result in a cap that's shorted internally pretty fast.
                    - Doesn't always happen but it can.
                    If the circuit has some resistance that limits current that can save the cap.
                    There is a process to restore caps to their original voltage rating.
                    It's called 're-forming'.
                    It basically amounts to slowly raising the voltage in small steps [to prevent the arcing while the oxide layer re-forms and thickens] until you get to the rated voltage where you hold it for some time period.
                    - Everyone that publishes a procedure to do re-forming has a different idea about what times and voltage steps are needed which is why I'm not being specific.
                    - Most of them work out to between 1 and 2 hours to complete the entire procedure.
                    [Which indirectly tells you how fast that oxide layer changes in response to applied voltages.]
                    So, If you dunno the old and new voltages [actual circuit voltages] then using a used cap is not a great idea.
                    - Dr Seuss
                    • Oerg866
                      • Nov 2009
                      • 61
                      DAMN. The card works fine now but the problems with textures in Trackmania are still there. I hate this cruel world ;_;
                      I have another 440mx here so I'll test if that one works with the game.
                      • howardc64
                        HP Inkjet printer main board bulging cap failure
                        by howardc64
                        Fixed a 10yo HP inkjet with a bulging cap on the digital computer power rails (1 to 5V). Unstable voltages causing these inkjets to not boot properly or crash quickly. Seems like more and more of these are showing up nearing the 10 year mark. Board design seem to look similar for many of these printers.
                        https://h30434.www3.hp.com/t5/Printi...t/true#M997922
                        02-03-2025, 09:50 PM
                        no-name Radeon 9600 XT recap and cooler
                        by momaka
                        I've been seeing a lot of cheap-looking (but not always so cheap) no-name AGP video cards on eBay for a while. They started popping up quite a bit when the market for AGP cards became more alive all of a sudden due to interest in “retro” PCs. One thing that struck me about these cheapo cards is that they almost always seem to come with garbage caps - including the abominable Sacon FZ. That aside, though, I've been wondering about the rest of the quality (or lack of?) on these cards. So I decided to satisfy my curiosity yet again.
                        This one was actually suggested to me by ChaosLegionnaire....
                        11-06-2020, 07:54 PM
                      • varunviolin007
                        Looking for someone to recap Dell XPS T450 motherboard (Live in suburbs outside of Philly)
                        by varunviolin007
                        Hi guys,
                        I’m looking for someone in the Northeast to do a full electrolytic capacitor recap on a working Dell Dimension XPS T450 motherboard (it's an Intel 440BX, Slot 1). The board runs mostly fine but is beginning to freeze after warm reboots (turns back on for 30 secs or so and then freezes up but is perfectly fine after 12 hr cool down).
                        I’d be sending just the bare motherboard (CPU, cards, bracket, battery all removed). I’m located in Chadds Ford, PA and happy to ship within the US.
                        Looking for someone experienced with older PC boards who uses...
                        07-29-2025, 11:53 PM
                      • Foetuss
                        Recap motherboards :: Abit KG7-LITE and Soltek SL-75FRN2-L
                        by Foetuss
                        Hi all
                        Hope this is in the correct place.
                        I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
                        Could use some double checking to see if I'm not doing something stupid .
                        Pictures of the boards are attached.
                        What I will be replacing with what : (planned)
                        Soltek Golden ::
                        4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
                        6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...
                        01-18-2025, 11:44 AM
                      • Hitto
                        Slightly Bulging Capacitors
                        by Hitto
                        Would you consider a slightly bulging capacitor defective if it measures perfectly and it is brand-new? To be honest, they are all equally like this: vent is not totally flat but they have very low E.S.R. and VLOSS is negligible.
                        So, everything seems perfect apart from the vent looking a bit "strange". They are genuine capacitors, BTW.
                        The bad thing is that they are 400V capacitors so testing them just to check how much they last would mean using them on the primary of a power supply, which means the risk of damaging the whole circuit.
                        What do you...
                        12-23-2024, 05:08 PM
