Anyone know what the capacitors on an MSI 790GX-G65 are?
  • Agent24
    I see dead caps
    • Oct 2007
    • 4968
    • New Zealand
    http://www.overclockersclub.com/reviews/790gxg65/2.htm
    Probably the best photos I could find.
    I don't own one of these boards but I might.
    They say they are solid capacitors but that doesn't mean they are good, right?
    -David VanHorn
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Anyone know what the capacitors on an MSI 790GX-G65 are?
    No, solid caps are good if they are REALLY name brand solid caps.
    Thing is some lytics look like poly but aren't.
    Looks fine in the pics but that doesn't guarantee anything.
    Manufacturers change caps during production all the time so what you see may not be what you get.
    I know this is going on with this particular board because if you troll the web for pics of it you will see a version with all blue marked caps and other version[s] with a mix of red marked and blue marked caps.
    I suspect it's fine. The blue look like Chemicon and the red like FPCAPs with are both good, but then again I didn't see any close-ups to know for sure.
    Mann-Made Global Warming.
    - Dr Seuss
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      yeah, they could be sacon fz for all we know
      sigpic
      (Insert witty quote here)
      • Agent24
        I see dead caps
        • Oct 2007
        • 4968
        • New Zealand
        I thought Sacon FZ always had FZ on them?
        Those fake solid caps, they look the same but they have a vent stamped in the top...
        There is some kind of brand logo on the red ones, looks like a T or R and L?
        Why must these kind be so hard to ID?!
        Can't they just write the name down the side like a normal electrolytic?
        -David VanHorn
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          I didn't see any close enough to read any of that.
          To be fair Sacon FZ are crap, but they aren't 'fake poly'.
          People that know just enough to get into trouble THINK they are poly but there is nothing illegitimate about lytics with no sleeves.
          No sleeves is the old way to mark them.
          Nichicon has been doing it off-on in some series of lytics for as long as I can remember.
          Yes, FZ have an FZ on them.
          If the Logo is an F with a bar above and below then they are Fujitsu Functional Polymer.
          Fujitsu restructured and they are now branded as FPCAP.
          http://www.fpcap.jp/en/company/history.html
          Same thing happened to Sanyo Lytics with are now branded SUNCON.
          - Dr Seuss
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            the main reason caps are clearcoated and printed is to eliminate pvc from them.
            the ones in the pic are likely fujitsu fpcaps.they used to be yellow/black print.
            • Agent24
              I see dead caps
              • Oct 2007
              • 4968
              • New Zealand
              I mean comparing these two for example.
              The blown graphics card capacitors are electrolytics which just happen to look extremely similar to the real polymer capacitors on the motherboard, right?
              Only real difference I can see is that the electrolytics have the usual vent, which the real polymer capacitors don't have.
              This is what I mean by "fake", unless I am misunderstanding something there....
              To me, it just seems to be a way to trick the buyer into thinking he is getting high quality capacitors because they look almost the same...
              -David VanHorn
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                Yes, they just happen to look like poly but aren't.
                Those shown are indeed Sacon FZ series.
                Thing about Sacon FZ is they -abuse- the fact that they look like Poly.
                - Sacon FZ come with blue marking to -look like- Chemicon Poly.
                - Sacon FZ also come with black markings to -look like- Nichicon Poly.
                True Polymer caps do not have vents.
                Functional Polymer caps may have vents. [Some common sizes do.]
                Electrolytics 8mm and up have vents.
                Electrolytic 6.3mm and down may have vents but often don't.
                Correct.
                - When I discovered that FZ are[were?] available with either blue or black markings any doubt in my mind that the buyer confusion was deliberate was erased. Sacon is[was] doing look-alike on purpose.
                The brand seems to have gone *poof* [again] but there are still zillions of these cap out there already installed and possibly some in supplier stock piles.
                Sacon FZ have also been found on Jetway and Biostar motherboards.
                - Dr Seuss
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  Vents are there to allow gases that may form inside to escape without blowing parts of the cap all over from it exploding.
                  The need for a vent depends on the chemicals used and the size [internal volume] of the capacitor.
                  If there isn't enough 'potential' gas inside [by the kind of chemicals or the volume of chemicals] to pressurize the can enough to push the bung out [which can send the aluminum outer can on a little journey in the vicinity of your LIVE circuits] then they won't have vents.
                  4mm and 5mm electrolytics rarely have vents. Too little volume so not enough pressure can build to push the bung out.
                  With 6mm and 6.3mm electrolytics it's some do some don't.
                  8mm and up nearly always have vent though I have seen some very very short 8mm diameter that don't have a vent, presumably because the internal volume is so small.
                  That 8mm lytic with no vent is a Rubycon ZL 6.3v 220uF 8mm x 7mm which is common on several models of Dell motherboards near the RAM slots.
                  Un-cap-savy people would think it's a Polymer but the ZL Series markings on it give it away as a Lytic.
                  - Dr Seuss
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 4968
                    • New Zealand
                    But cheap brand electrolytics are crap, is it not the same for polymer?
                    I mean, take a Fuhjyyu (if they even make them) and a Rubycon polymer...
                    I have ordered that board today, it should be here today or tomorrow. Then I can post some detailed pictures and we can find out what's what...
                    -David VanHorn
                    • dbs
                      • Feb 2009
                      • 35
                      Agent24 I just got an MSI 790FX-GD70 and every cap in it is United Chemi-Con - the caps in your board look identical to these - you should be ok
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        Not sure but don't think so.
                        Haven't seen anything to indicate that either.[Yet.]
                        What makes cheap lytics crap is the impurities in the aluminum which craps up the liquid electrolyte and breaks it down.
                        Since solid polymer don't have liquid that can't happen.
                        - Dr Seuss
                        • Agent24
                          I see dead caps
                          • Oct 2007
                          • 4968
                          • New Zealand
                          Arrived this afternoon, and they all have the United Chemi-Con logo on them
                          They have to be better than the OST electrolytics in my old board anyway...
                          No idea what series or value they are though. How are you supposed to interpret the markings?
                          -David VanHorn
                          • dbs
                            • Feb 2009
                            • 35
                            That's got to be a relief - it's an interesting board too - apparently you can set up crossfire using the on-board video and some of the 3 and 4 series ATI video cards - good luck with your build
                            • PCBONEZ
                              Grumpy Old Fart
                              • Aug 2005
                              • 10661
                              http://capacitor.web.fc2.com/image4/...on_solid01.jpg
                              - Dr Seuss
                              • amelbye
                                degradation of solid state capacitors in motherboards?
                                by amelbye
                                Hi, I have a question regarding a motherboard with SS capacitors that I'm having trouble with. Every now and again it would give overclock failed at boot even when not overclocking.
                                Recently more often, and the last few weeks at every single boot. It seems like the typical capacitors needing to warm up, then everything is fine.
                                Weird thing is the capacitors are all solid state. Do SS capacitors degrade the same way as normal caps? Is it worth trying to recap the board?
                                I have already replaced the PSU.
                                The board is a gigabyte x79 ud3....
                                11-06-2022, 10:35 AM
                              • dragon3x
                                After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                                by dragon3x
                                Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                                power on.
                                Here are some examples :
                                (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                                switching supply area).
                                (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                                than 6.3 V.)
                                1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                                I replaced capacitors with aluminum-polymer.
                                3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                                03-21-2025, 02:46 PM
                              • slybunda
                                AA and AAA battery charger capacitors?
                                by slybunda
                                hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
                                it has inside:
                                2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
                                2 x 470uf 16v LZ105c branded as G.Luxon
                                not heard of these brands are they any good?
                                iv attached photos of the charger and the board inside for an idea on the type of...
                                12-24-2023, 04:41 AM
                                by sam_sam_sam
                                After all of...
                                07-13-2024, 08:14 PM
                              • Ady2017
                                Are there any datasheets available for Elna RJG capacitors?
                                by Ady2017
                                I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
                                05-25-2025, 02:19 PM
