Asus B85-E boot time is too long
  • Aliencomputres
    • Aug 2019
    • 200
    • România
    Hy all,
    Asus B85-E Too long bios post time-aprox.15-20 sec, but booting every time.Change ram,cpu,psu.
    Bios is up to date and cell battery is brand new.
    Thx in advance.
    • 20659
    Re: Asus B85-E boot time is too long
    Do you mean the B85M-E
    • piernov
      • Jan 2016
      • 4435
      • France
      You mean 15-20 seconds before showing any image? Or when showing BIOS image? Is it everytime you shut it down/turn back on (without disconnecting from the mains) or reboot?
      Tried reset CMOS?
      Tried with nothing except PSU/RAM/CPU connected to the board, outside the chassis?
      Tried to update BIOS again even if it's up to date?
      • Aliencomputres
        • Aug 2019
        • 200
        • România
        15-20 sec before showing bios image.It is everytime when shut down or restarting.
        Reset cmos ,rewrite bios with ez flash with B85M-E BIOS 3602.
        Mainboard its on thre table and have one stick of 4gb/1600 mhz and the cpu.
        Thx.
          • 20659
          Flash this bios with your programmer, not easy flash.
          • Aliencomputres
            • Aug 2019
            • 200
            • România
            Solved.
            Flash bios with programmer.
            Thx.
            • Arnoldso
              • Nov 2020
              • México
              Anyone has the schematic for B85M-E ?
              • robante15
                • Nov 2020
                • 58
                • El Salvador
                Thanks this BIOS helped me to solve the problem of
                "USB Device Over Current Status Detected !!"
                I know that would be more of a physical problem than BIOS, but the truth is that the ports did not have any problem, they were in good condition, also clear the CMOS and nothing, but flashing the BIOS worked and already revived the Motherboard with that.
                • throwaway327
                  by throwaway327
                  Model No: RC72LA
                  Serial No: SBNVKD001014459
                  06-18-2025, 05:52 PM
                • razor_amd
                  by razor_amd
                  12-15-2020, 07:07 PM
                • futadmytro
                  Asus g713qm-es94 stuck on boot bios problem
                  by futadmytro
                  sn^M4NRKD02753616E
                  MB- g533-6050a3250201-MB-A03
                  Stuck on boot after ROG logo, did not enter to bios
                  In flash bios , laprop boot but have video issue
                  orig bios...
                  06-25-2025, 08:07 AM
                • oragano
                  ASUS ex-b250-V7 motherboard bios corrupted - by me
                  by oragano
                  hey all, i did a silly thing and flashed bios to perfectly working board. None of the asus official download bios would work with ez flash. They all gave error saying not supported bios file. I tried using uefi tool to extract it to a bin file but then ez flash wouldnt even recognise it.
                  So, i used freedos and afudos with the aforementioned bin file i extracted and forced the issue. After bios reprogram, reboot and it was dead. Fans spinning but no post.
                  i have a bios writer and none of the .cap files from the official site work either. I just get one spin, then off, then all fans...
                  10-17-2024, 02:53 AM
                • chudofermer
                  Asus Ally rc71l bios
                  by chudofermer
                  Hello!
                  Received Asus Ally rc71l with the wrong bios.
                  Have the original package and all serial numbers.
                  Can anyone help me understand what is wrong?
                  Condition:
                  Received with an original box with all serial numbers
                  Due to the bios updating, something went wrong and I can not check in the bios. The recovery mode sometimes appears, usually was stopped on the logo.
                  Got the flash dump, nothing found on DMI section
                  No Windows key, just key ID on the box
                  What is done:
                  1. Flash the latest bios version with serial numbers...
                  03-05-2025, 05:42 AM
