Imac G5 Isight woes.
  • deckart
    • Sep 2009
    • 67
    Hello chaps,I'm stumped and need your help!.I have the above courtesy of Ebay,which had a shutdown and woul not reboot.It will power on,solid front light,fans spin up and HDD and Optical make the usual noises.
    Diagnostic light 1 and 2 light up fine.The PSU had already been swapped out with known good and same scenario.
    Caps on inspection all ok.Obviously didn't rely on that and pulled each one and tested with my ESR meter,all well within tolerance.So what the hell,I replaced all.
    You gueesed it,same results.Done all usual checks,pulled pushed caps for bad joints,all fine,cables are good,no shorting on EMS side,so now I'm in head scratching mode.
    I think it could be a bad IC or something,any advise how to find the faulty bugger would make my day and night.
    deckart.
  • Player2
    • Aug 2009
    • 98
    Re: Imac G5 Isight woes.
    When it powers on, how long does it stay on? What do the fans sound like -> Do they run full blast the whole time it is on, or do they slow down after a second? Do you get any display on the screen?
    I've never seen bad caps on the iSight G5s, but they do have a tendency for video problems, and the GPU is BGA (ball-grid array) so they are not very practical to repair if that is the problem. Go check Google to see how much a BGA rework station costs
    • deckart
      • Sep 2009
      • 67
      Hi,power stays on,2 leds are lit,fans ramp up to max.
      • Player2
        • Aug 2009
        • 98
        Hmm, sounds like it's probably the GPU problem. The third LED is the one that indicates successful communication with the LCD. Do you have a display dongle and an external monitor you can try? If it still doesn't work on an external monitor, I'd say you're out of luck.
        I have seen some iSight G5s that overheat and just need the thermal compound replaced, but they will typically power on, ramp the fans up to 100%, and then turn off after about 5 seconds. If yours is staying on, I'd say that's probably not the issue.
        • deckart
          • Sep 2009
          • 67
          Sorry to bump this but I still can't figure this out.History,user suffered spontaneous shut down(imac,not him!).Took to some Mac repair place,they tested PSU,which is fine,I've a few spare good ones and did the same just in case.LED 1 & 2 light up,fans start,white light comes on,and HDD?optical make the right noises,it then does the usual fan ramp up.
          I replaced all caps,same result.Checked for cold shoulders,all ok.For the heck of it I took out a small filter cap,the flipping thing still powered up as above!.
          If I connect a KB,it doesn't power it,but if I put a mouse in the same USB port the laser lights up.
          I've looked at all components with a loupe and can't see anything remotely suspicious.
          I need HELP!.
          deckart.
          • Player2
            • Aug 2009
            • 98
            Is the issue with the USB keyboard happening before or after you removed the small cap? First thing's first, put that guy back in!
            Do you have an external monitor and the necessary display port adapter? See if you can get anything that way. The third diagnostic LED indicates that the connection to the LCD has been established, so let's try to get to the bottom of the video problem.
            • deckart
              • Sep 2009
              • 67
              Arghhh!,USB issue happens irrespective of whether the cap is in or not.I have the panel discconnected at the moment,but have tried with it in,still same result.If the original user had a power spike,this could,maybe,have fried the CPU,be the first one I've encountered though.The thing is,with all peripherals discconected,it still does not chime,even with the little fella soldered back in.
              I've resoldered dozens of these and know them quite intimately,LEDS diags,console warnings,ASD errors,but usually I can trace it back,not with this little bleeder!.
              • ryogadan78
                iMac A1418 - No LED, no power after overvoltage on Ethernet port
                by ryogadan78
                Hi guys, I need your help again.
                I have this iMac from a customer that shut down during a storm along with all the other devices in the house. In particular, the router, connected via Ethernet to the iMac, caught fire.
                When I removed the screen from the iMac to check the status of the LEDs, I noticed that none of them were lit. I had a perfectly compatible and working power supply, so I tried it right away, but the problem remained the same (no LEDs). With the thermal camera, I noticed only a slight warming (32 degrees) of the NCP1605BG chip on the power supply. The rest was completely...
                06-10-2025, 03:49 AM
              • Stephen
                iMac M1 DFU restore issue
                by Stephen
                iMac turns on no drops no cracks, tried to DFU Restore the iMac, logo turns on great! however iMac turns itself off and then restarts to the (!) icon and won't post the restore. Tried thunderbolt 3 cable, tried regular USB C cable and nothing.
                this is the message it gives me with the error
                Unexpected device state 'DFU' expected 'RestoreOS' (Probably forced into DFU mode externally) [com.apple.MobileDevice.MobileRestore – 0xFAE (4014)].
                Any thoughts what this could be? I will open it up and repair it but I am not 100% sure since this iMac doesn't...
                03-07-2025, 12:19 PM
              • Stephen
                iMac 27” 2020 Boot issue
                by Stephen
                Customer came in for data recovery, came to find out data is soldered on to this iMac (learn something new everyday) this is a 2020 T2 iMac so I was surprised because the iMac Pro has a T2 chip and it isn’t soldered on. Anyways, the iMac boots to Apple logo and then restarts, before it turns off you hear a quarter fan spin then it repeats itself. I decided to do a DFU revive to restore any hardware firmware issues and it was successful in reviving the device however the issue persists in boot looping. It shows the Apple logo for like 40 seconds then turns off and fan spin rinse repeat. I...
                08-16-2024, 09:32 AM
              • tommy97
                iMac Pro 2017 A1862 SSD Upgrade & Recovery mode
                by tommy97
                we've got iMac Pro 2017 which having a problem with SSD, iMac come with 2 SSD's 1TB, it was having a problem with the SSD so we get the replacement, installed in and iMac is stuck in recovery mode, tried to restore it & revive, nothing worked - error 4010. After installing old drives now we're having the same problem that the device is in recovery mode. Previously after swap of the SSD iMac worked on the old SSD however after attempt of revive on the new SSD machine stuck in recovery mode, I can go to DFU but the same result with error 4010.
                Any ideas what might've...
                04-20-2024, 04:48 AM
              • howardc64
                by howardc64
                Problem
                08-04-2024, 10:36 PM
