ASus A7N8X-LA - Powers on, but no boot (solved)
  • socketa
    Asbelowsoabove
    • Jun 2014
    • 660
    • samsara
    After replacing the battery i got this board to boot.
    Went back to it a week later and only the cpu fan spun after powering it up
    So i changed RAM, and blew out the slots to no avail.
    So then changed the psu and noticed that the keyboard lights blinked briefly (which they didn't do before)
    Tried again a few times and no keyboard lights.
    The fan would occasionally stop a few seconds after turning it on.
    So felt like that it was doing what it was supposed to do, so i took the heatsink off, and it was dry underneath.
    Put new paste on, and it booted first pop.
    It seems that the CPU 'shuts down' but the fan keeps going - which can be quite misleading, because i thought that when the CPU 'stops' due to overheating that the fan would stop as well.
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: ASus A7N8X-LA - Powers on, but no boot (solved)
    Repasting was just a coincidence I think. Or there may be a bad contact in the CPU socket and taking off/putting back on the heatsink did something.
    No sign of bulging capacitors? (they could still be bad though)
    • socketa
      Asbelowsoabove
      • Jun 2014
      • 660
      • samsara
      OK - yes, i did also remove the CPU and give it a scrub with a toothbrush and dishwashing liquid. So maybe that was the problem - there was a small area of whitish mould(?) on one corner. Now i'll never know
      No bulging caps - that's one thing that i like about it - zl and mbz.
      Coincidentally, it did start playing up (turning on and off by itself)- but that was due to a faulty power button, that i fixed with a wd40 type aerosol).
      • socketa
        Asbelowsoabove
        • Jun 2014
        • 660
        • samsara
        This was going good, up untill now
        But it started to make crackling noises from the small onboard speaker, and there was a series of BIOS beeping also - (forgot take note of the sequence though).
        Couldn't get it to boot again, although the power light and cpu fan turned on.
        I probed around on the coils and vacant cap spots and all were giving, what looked like to me, reasonable voltages
        So tried three other CPUs only one got hot, the others didn't.
        After a few tries with that CPU (not booting) it now boots again, with no crackling.
        What was a probable the likely cause of the cracking
        Dirty contacts in the CPU socket, as previouly suggested?
        Would it be a good idea to spray the socket with mould killer, and then detergent and then rinse it out and dry?
        Also Windows in not detecting the Realteak ALC650 chip - can i test if it's faulty? There is 2.4V on the Line out L and Line out R pins of the chip, so it at least has some life
        • socketa
          Asbelowsoabove
          • Jun 2014
          • 660
          • samsara
          It started cracking again and windows restarted a couple of times - then the board failed to boot.
          It was still crackling after i powered it up, and also when i reinserted the cpu a dozen times or so.
          Then it stopped crackling and still wont boot - so i'm assuming that whatever weak connection there was, is no longer making contact.
          Am going to wash the socket, starting with dishwashing liquid, then mould cleaner, then, if no luck, something like wd40 or engine degreaser. Although i'm still not sure that it's the socket.
            master hoarder
            • May 2008
            • 12170
            If I am not mistaken, this board has an nVidia nForce 2 chipset. Although fairly reliable, I do remember reading some posts on here that said even nForce 2 chipsets can fail in a similar way that the nForce 3, 4, and onwards chipsets failed from the bumpgate issue.
            I suppose washing the board is a good first start, though. I don't suggest spraying anything corrosive in the socket. Wash with hot water and dish detergent is OK, as long as you get all of the detergent well washed and the board dried quicker (i.e. don't leave it in some dark corner where it takes the moisture many days to dry, as that can cause corrosion on the contacts.)
            If this doesn't work, then perhaps the NB chipset may be going bad. In which case, try applying some pressure on the NB heatsink first while trying to boot the board. Try this several times at different pressures (but don't go overboard.) If that doesn't do anything, try the same on the SB too.
            Finally, if this was a used board you bought/got from somewhere (i.e. not original owner), then make sure to do a thorough inspection for scratched traces and damaged SMD components. I repaired a Soyo socket 370 motherboard last week that had damaged SMD array resistor by the CPU socket. I don't know if the board worked before fixing this (I don't like to test equipment that I can see has bad components that may be critical to the operation), but the board was given to me in "as is, for repair" condition. So after fixing that SMD resistor, the board worked perfectly fine. Chances are high that it didn't before... or perhaps it could have been very intermittent like yours.
            • socketa
              Asbelowsoabove
              • Jun 2014
              • 660
              • samsara
              Since my diagnostic card wasn't showing any readout, i figured that the BIOS wasn't being read.
              Flashed it, but the board still doesn't POST
              There is a hard short to ground on the BIOS Vdd power supply pin,
              Which could mean that the chip is faulty (which is unlikely since i had no problem flashing it), or there is some shorted component.
              I checked a couple of schematics of similar boards, and the BIOS chips are powered directly from the 3V or 5V rails...hmmm,
              But the 3V or 5V rails are not shorted to ground on this board
              • socketa
                Asbelowsoabove
                • Jun 2014
                • 660
                • samsara
                That was probably because i put the chip back on the wrong way around
                ... to be continued
                  • 30953
                  lol
                  btw - never use wd40 on electronics.
                  it's only for keeping water out of mechanical stuff outdoors.
                  if you need a lube then use 3in1
                  if your cleaning contacts use contact-cleaner
                  wd40 can destroy pcb's slowly.
                  • socketa
                    Asbelowsoabove
                    • Jun 2014
                    • 660
                    • samsara
                    Well, it wasn't the bios.
                    Pulled of the bios and reprogrammed it
                    And eventually (after winding up pulling off 5 pads and 2 traces after trying more than ten times to install common plcc32 sockets with hot air, got lucky with obtaining some better plcc32 sockets, and this time putting solder paste on the pads before placing the socket on the pads and using a fine tipped iron and a microscope - which worked out very well
                    To secure the pads i used some chinese locteft 272, which is supposed to resist temperatures less than the melting point of leaded solder, and sets in the absence of oxygen,
                    cleaned up around the pads, and used uv solder mask the next day
                    Then put the bios chip back in and it went right into the bios screen, but froze, IIRCC, not long after subsequent attempts just got less through the POST sequence, until 0000 was just displayed on the PCI analyser card
                    So decided to inspect the board and nothing seemed to be visually detached or area of discoloration due to overheating.
                    Then tried powering it on while moving a couple of VRM caps, and some digits appeared on the analyzer card
                    After lots of pushing around on the surrounding area occasionally some digits would be displayed
                    So moved to near the southbridge area, which was on the opposite corner of the board, and started pressing down on the south bridge and the i/o chip, and now eventually the board boots (for the meantime at least)
                    So now it's looking more and more like the nForce2 southbridge. as pusing down on it can get the board to go through the post sequence by pushing down on it quite hard
                    If i release the pressure when it goes into bios screen i can still move from one bios screen to another, and see that the hardware monitor is still active, but sometimes can't shut down with the power button
                    Also it won't even turn on sometimes on without pushing down on the southbridge
                    Which would it more likely be? - The chip itself, or a BGA spot not contacting one of the the pads?
                      master hoarder
                      • May 2008
                      • 12170
                      socketa,
                      I must say, I'm really impressed by your dedication, both in terms of troubleshooting and keeping your threads updated
                      So it looks like it's boiling down to a bad solder joint, possibly.
                      I don't think (or at least I would hope so) that the nForce 2 Southbrdige chip is the issue here. It's a wirebonded chip, and these won't (or should not) have the same issues like flip-chip technology chips can... unless the chip was somehow severely overheated and for a long time. So I think it's either a BGA under the Southbridge... *OR* could also be a bad connection on the SuperIO/LPC chip. FWIW, just because there are not BGA does not mean their solder joints can't fail. Actually, if I have learned anything from the VooDoo 2 cards (and some Yamaha YMF7x4 close audio cards), the SMD soldering on chips like that can fail quite often. And seeing how close the SIO/LPC chip is to your Southbridge, I would suggest to start with that first. Take a small needle and gently shove it slightly between the pins on the SIO/LCP chip, then wiggle a bit and see if a pin moves on the bottom where it is supposed to be soldered. If it does, then that pin is not soldered properly. If all of the pins on the SIO/LPC pass, only then it might be a BGA on the southbridge. I suppose an alternative approach would be to reflow both and at the same time (well, one after another, while the board is hot.)
                      • throwaway327
                        by throwaway327
                        Model No: RC72LA
                        Serial No: SBNVKD001014459
                        06-18-2025, 05:52 PM
                      • Belushi
                        Asus M5A97 LE R2.0 powers on but does not boot
                        by Belushi
                        My 7 year old AM3+ motherboard has broken overnight. It powers on, but does not boot (no picture, no beeps). I checked RAM, CPU (with another AM3+ board), PSU - all components works properly so it is a motherboard fault.
                        What I've already checked:
                        • no short on main power rails
                        • no shorted mosfets
                        • BIOS chip works (I could read its content with a programmer)
                        • RTC running (it consumes ~4µA from the battery)
                        • CPU and chipsets (NB / SB) are getting warm after power on motherboard
                        • CPU voltage (vCore) is ~0.84V and motherboard does not adjust voltage
                        • chipsets (NB / SB)
                        11-17-2023, 05:04 PM
                      • jrodefeld
                        Asus laptop won't boot (no power) - possible bad caps?
                        by jrodefeld
                        I would like to see if anyone could help me salvage a very expensive laptop that is no longer working.
                        The model:
                        Asus Zenbook Pro Duo UX582L
                        I have used this laptop lightly since I purchased it new in 2022. I have always taken precautions to take care of it the best I could, and have never done anything that would risk causing damage to it or shorten it's life.
                        However, around six months ago, the laptop stopped working on battery power. It continued to work fine when plugged in, but as soon as power was disconnected,...
                        09-02-2024, 04:55 PM
                      • acata
                        Asus X450LC REV 2.2 can't boot to anything
                        by acata
                        I get this Asus X450LC REV 2.2 can't boot from SATA, ODD or USB flash drive.
                        Power on normally. Boot to bios ok.
                        But I can't normal boot from HDD (windows 7) just freeze on the animation. I can't boot from pre-installed SSD windows 10, bsod: driver pnp watchdog. I can't boot USB flash drive Hiren boot CD or linux mint.
                        10-10-2023, 05:15 AM
                      • futadmytro
                        Asus g713qm-es94 stuck on boot bios problem
                        by futadmytro
                        sn^M4NRKD02753616E
                        MB- g533-6050a3250201-MB-A03
                        Stuck on boot after ROG logo, did not enter to bios
                        In flash bios , laprop boot but have video issue
                        orig bios...
                        06-25-2025, 08:07 AM
