Power supply board from a ventilation unit - burnt out something
  • cjard
    • May 2014
    • 14
    • US
    This vent axia ventilation unit stopped working and I pulled the power supply board hoping it was the internal fuse. Seems this other component might be to blame but what is it? It looks like a capacitor to me but next to it on the board is printed RV1 whereas a physically similar component at the other side of the board is labelled C15...
    Any ideas guys?
    • 31070
    Re: Power supply board from a ventilation unit - burnt out something
    the big cap in the picture looks bulged.
    the device may be a resistor to limit inrush - have you checked for shorts?
    • petehall347
      • Jan 2015
      • 4427
      • United Kingdom
      looks like a stand in for lack of a fuse . guessing there is a short after it
      • R_J
        • 9552
        Check if RV1 is inline with the a/c line or is across the a/c between line and neutral, It could be a inrush ntc thermistor if in line or a MOV if it is across the line, clean it off, you might see a number on it.
        • cjard
          • May 2014
          • 14
          • US
          My neighbor has the same device as I pulled this board from, so I'm gonna take a look at the components and see if I can see anything on them, writing wise
            by sam_sam_sam
            After all of...
            07-13-2024, 08:14 PM
          • Soulzink
            Samsug washing machine. Power supply DC41-00189a board issue
            by Soulzink
            I am trying to fix a samsung washinmachine power supply main board.
            I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
            Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
            The power supply board reference is the following: DC41-00189a
            I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
            04-19-2025, 06:26 AM
          • Nicktronic
            Samsung Power Supply Board BN44-00874F
            by Nicktronic
            Hey everyone,
            This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
            Anybody...
            03-17-2025, 06:20 AM
          • penangit
            Hp v193 monitor power supply board
            by penangit
            Hey everyone,hope everyone is fine, I got an issue hoping you guys can help me,
            I got a HP V193 monitor it has a E59670 now i got a few of these, been using them for long time now, however this particular monitor was blacking out for a few times then after unplugging and plugging it back in it gets back to normal until now its dead.
            I tried switching the power supply board with another similar monitor and it works,so I'm trying to fix this power supply board I got some basic in electronics as a hobbyist.
            Steps taken so far:
            Checked all...
            02-21-2023, 04:00 AM
