newbie IBM motherboard
  • enito
    • Jul 2009
    • 25
    Hi, im new in badcap scene, hehe, okey, i try before try to repair a old ibm motherboard with 3 cap bad, i try with a bad motherboard remove capacitors. Its a bit hard, i use a Desoldering Solder Removal Vacuum Sucker Pump Tool, for try to remove solder, but is hard, i try again , and nothing cant still remove all the solder of capacitor. Whats the best technique for remove all solder? i dont wanna damage the board for make a bad thing. I have a bad board for practice, any tip is really welcomed..thx!!
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: newbie IBM motherboard
    There are some good help in this forum section; https://www.badcaps.net/forum/forumdisplay.php?f=24
    I use a stainless needle myself to poke though the board while heating the old solder with the soldering iron
    If you are asking how to remove the capacitor you should not remove the solder, you should add a bit of solder to the old solder, so it helps you to heat it up, then you can wiggle the capacitor out carefully, and after that the needle approach to get a clean hole for the new cap
    • KeriJane
      Mac Enthusiast
      • Sep 2008
      • 681
      Hi Enito
      Welcome to the Forum!
      A multi-layer motherboard is a more difficult project to start with.
      The board probably has many conductors and ground planes that will draw heat away, making desoldering difficult and increasing the chance of damaging it.
      That said, here's some tips:
      1- Make sure the iron or heated sucker is very hot. You will probably need a 40-60 watt iron. If it's adjustable, select the highest heat.
      2- Add some more solder to the connection first. This will accomplish two things: More surface area for the iron to contact and it may lower the melting point of the existing solder.
      3- Don't allow the iron to touch the board. Only make contact with the solder and component lead.
      4- Work fast to reduce chance of damaging the board.
      Using this procedure I often remove enough solder on the first try so that the capacitor is loose and will easily pull out.
      Those motherboard are the hardest that I've done.
      Good Luck,
      Keri
      PS. Make sure that you use an appropriate replacement capacitor. Most motherboard caps are special "Low ESR" or "Ultra-Low ESR" capacitors.
      The More You Learn The Less You Know!
      • enito
        • Jul 2009
        • 25
        thx a lot for replys!!
        i try tonight...greets
        • enito
          • Jul 2009
          • 25
          Hi, finally i removed the capacitors, thx guy...now i have a doubt, i want replace someones from another bad board capacitor. The bad ones is the green ones : 1000uf 6.3v wg(m) -40+105c , want replace with the other ones darkones is like : 1500uf 6.3v GLUXON 5c to 105c, if possible? i attach you some photos with capacitors and showing one bad from board , is a ibm motherboard. thx a lot for your time.
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            g-luxon? blech...
            sigpic
            (Insert witty quote here)
            • enito
              • Jul 2009
              • 25
              i know can be bad, but works?
              greets
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                greets
                why waste the time?
                too many good sources for replacements.
                i bet tc/badcaps.net even has a kit for that board.
                • 370forlife
                  Large Marge
                  • Aug 2008
                  • 3113
                  https://www.badcaps.net/pages.php?vid=23
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    fix it now, not when it burns due to dried up caps. save yourself a board.
                    sigpic
                    • acedogblast
                      by acedogblast
                      11-02-2024, 05:13 PM
                    • Geeker007
                      Friend messed up my laptop motherboard while working on my bench
                      by Geeker007
                      Hi All,
                      So my friend was visiting and he wanted to use my solder bench to solder on some WLED circuit board. My laptop was open on the side for RAM upgrade. I know my mistake.
                      So while soldering he had too much solder on the soldering iron tip and he just shook off the soldering iron on the table itself to remove extra solder on the soldering tip and it landed on the motherboard of laptop. He then out of fear tried to remove it using solder wick and did more damage by removing some components as well. So here I am with weird situation.
                      I have not tried putting...
                      06-16-2025, 01:40 PM
                    • howardc64
                      by howardc64
                      Problem
                      08-04-2024, 10:36 PM
                    • laup
                      Lenovo 330s-ARR-R332200U motherboard remove on board ram
                      by laup
                      ive looked through all the lines for 2311 but cant see a consistant row of them
                      could someone please have a look at my bios and remove the onboard from within, appreciate it
                      Laptop : Lenovo 330s 15 ARR
                      motherboard: 330s-ARR-R332200
                      SN: yd04qytm...
                      10-01-2025, 07:23 AM
                    • liquidzorch
                      862D+ solder station iron out of control when fan on
                      by liquidzorch
                      Hello.
                      I have a soldering station, 862D+, and every time the hot air gun is on, even if it is just cooling off, the soldering iron controller stops controlling. Let me explain what has happened so far, as it took a while to get to this.
                      First, the switch that turns on the hot air gun started to fail, the light came on, but temp never rose, I would have to switch it multiple time to get the gun to start heating, this was due to the contact inside being carbonized. I opened the switch up, clean the contacts, and it would work fin for a while until carbonized again. So, I ordered a switch...
                      06-09-2022, 08:49 PM
