Asus P6T won t boot in Bios!
  • Shipmaker
    • Feb 2014
    • 36
    My Asus P6T do not start into the bios, first at all I got the Board from a friend tand he mean it works.
    But if got no headsink from 1366 and used on from 775 first time it starts outside the case into Bios, than after a view minutes there was a massage that the cpu is overheated, so I unfortunatly take of the power!
    But now if tried an nother 775 Headsink with more power an the board do not start into the bios again, the cpu fan run everthing seams to work but it wont boot into damned bios!
    couldt it be that i7 920 died at 188,6 °F (87 Celius)
    Or is there be a chance to awake the system again?
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: Asus P6T won t boot in Bios!
    87 C should kill anything unless that was with a CPU core OC and a CPU core overvolt.
    IIRC, OC'ing and overvolting the Vcore, can change the characteristics of the CPU and make it less tolerant of high temps and in some cases, may result in 60 C making it crash.
    But those characteristics are possibly reversible, just by returning it back to stock core voltage and stock core frequency specs.
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • piernov
      • Jan 2016
      • 4439
      • France
      I think you meant "should *not* kill anything".
      87°C won't do anything to those CPU, except maybe making them unstable if overclocked indeed.
      First try a clear CMOS.
      Also I'm not sure how you mounted the 775 heatsink as it doesn't fit on a 1366 socket.
      • ChaosLegionnaire
        HC Overclocker
        • Jul 2012
        • 3266
        • Singapore
        yupp... get a proper heatsink for lga1366, apply thermal paste and mount it properly on the cpu and make sure the heatsink makes good contact on the cpu.
        and lastly, never ever run something that comes with a heatsink, without the proper heatsink, gpu or cpu!! thats just asking for trouble!
        • Shipmaker
          • Feb 2014
          • 36
          thank you for your answers, yes I bought an i7 950 and the origin 1366 cooler
          but again the board wont boot into bios! I do an cmos reset but the same problem as before, so now i will replace the bios cheap with a new one maybe that couldt be the solution?
          • throwaway327
            by throwaway327
            Model No: RC72LA
            Serial No: SBNVKD001014459
            06-18-2025, 05:52 PM
          • razor_amd
            by razor_amd
            12-15-2020, 07:07 PM
          • futadmytro
            Asus g713qm-es94 stuck on boot bios problem
            by futadmytro
            sn^M4NRKD02753616E
            MB- g533-6050a3250201-MB-A03
            Stuck on boot after ROG logo, did not enter to bios
            In flash bios , laprop boot but have video issue
            orig bios...
            06-25-2025, 08:07 AM
          • kenkaniff
            HP Pro x360 Fortis 11 inch G9 Doesnt boot after flashing bios
            by kenkaniff
            Product Name: HP Pro x360 Fortis 11-inch G9
            System BIOS: U94 Ver.01.08.00 10/06/2023
            Serial Number: 5CG31946F5
            SKU Number: 85W05EC#AK8
            Motherboard: ANOLE10-MV-TRIPOD / 6050A3332901-MB-A01 / 2021-11-09
            This motherboard has 2 similar chips. One is on the front marked with BIOS SKT "Winbond 25Q256JVEN" and one on the back marked with U351 "Gigadevice 25B256EYIG". I ignored the one on the back and only desoldered front chip. Made a backup, made sure the reading was the same with another 3 backups.
            I needed to remove bios password...
            10-01-2025, 04:32 AM
          • lrouw84
            Asus vivobook s510ua bios changed to x510un
            by lrouw84
            Hi there,
            I know there is somebody who can tell me what is happening with my laptop. For start, it is an asus vivobook s510ua with an asustek x510ua motherboard with an intel i5 7200u cpu and 16gb ram.. i have a screenshot from speccy before strange things started.. as you can see the laptop type and bios version x510ua.302.I don’t manually update the bios because i don’t like to having a bricked bios, i know what troubles that gives..
            I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....
            01-28-2023, 01:31 PM
