Shuttle FX41 Motherboard
  • dracobuild
    • May 2005
    This board has the following capacitors:
    6 x 3300uf 10V 10mm
    6 x 1500uf 10V 10mm
    9 x 1000uf 10V 8mm
    4 x 1500uf 16V 10mm
    I have been able to locate quality replacement caps for everyone except the 3300uf 10V in 10mm size.
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    you wont find less than 12.5mm on the 3300 10v
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      use 6.3v caps
      they used 10v probably because they were cheap.
      the 16v ones are on the +12 input to the vrm so they must be 16v caps
      all the others can be 6.3
      • Neo2_000
        • Apr 2005
        • 180
        On many boards I often see smaller value caps rated at 16 or even 25 volts in other areas of the board beyond the CPU. Is this because those values just happen to be manufactured in those particular voltages for reasons of versatility or is there a real need for these higher voltage caps on the motherboard?
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          often its due to savings by buying a large quantity of one value vs several different voltages.
          not to mention simplifying insertion machine setup.
          • willawake
            Super Modulator
            • Nov 2003
            • 8457
            • Greece
            use 6.3v caps
            is it possible to use 10V but with higher uf than previously used on the +12 input for the vrm....or not recommended?
            • Neo2_000
              • Apr 2005
              • 180
              So the motherboard voltages in these low value cap positions are considerably less than the rated cap voltage under all conceivable operating conditions?
              • AK0R
                • Mar 2005
                • 204
                I certainly wouldn't recommend it. The capacitance is important for voltage smoothing, but the voltage rating is important to prevent perforation of the capacitor film (paper, mylar, foil, etc.) due to internal arcing. Capacitors should *NEVER* be installed that have a lower voltage rating than what is actually present in the circuit. That doesn't mean you can't, or shouldn't, install a lower-rated capacitor than what was there originally. There have been several threads posted here that indicate 10V capacitors were replaced with 6.3V units, but that was on Vcore, which never gets above a couple of volts. A good rule of thumb in the radio world has been twice the actual power dissipation for resistors, and twice the actual voltage for capacitors. Motherboard manufacturers have reduced these margins of safety in the interests of cost savings and board space to almost nothing. Capacitor manufacturer curves show substantial de-rating as actual voltage exceeds capacitor rated voltage.
                • willawake
                  Super Modulator
                  • Nov 2003
                  • 8457
                  • Greece
                  good info, thanks AK0R
                  • AK0R
                    • Mar 2005
                    • 204
                    Not necessarily "considerably less", but for low-value capacitors, it comes down to making a package that is large enough for a human to handle, and the consequential voltage rating for such low capacitance. An easy way to lower the capacitance (in the manufacturing process) is to increase the spacing between the layers of film, which also raises its voltage rating. Typical of most capacitor manufacturers, Rubycon doesn't make a 1μF radial lead aluminum electroytic capacitor lower than 50V. It also may be that a "proper" voltage capacitor doesn't have the desired properties. And as has been mentioned elsewhere, economy plays a tremendous part. If one rating fits several different requirements, a manufacturer isn't going to stock several different voltage ratings of a particular capacitance value.
                    • MD Willington
                      • Sep 2004
                      • 702
                      Bingo...they don't have to load up reels of a different value and it simplifies the masking used in the chip shooter...
                      but it's not like a chipshooter is a slow device anyway...
                      Ya'll think us folk from the country's real funny-like, dontcha?
                      The opinions expressed above do not represent those of BADCAPS.NET or any of their affiliates.
                      • Neo2_000
                        • Apr 2005
                        • 180
                        Interesting stuff. Thanks Akor.
                        What is your opinion then on the wisdom of replacing for example a 470uF x 25V or 470uF x 16V with a lesser rated cap on the motherboard.
                        Maybe I should ark up a board and do some measurements but I would be concerned that I might make a mistake by taking measurements when the particular circuit involved is not under full load.
                        Neo.
                        • kc8adu
                          • Nov 2003
                          • 8832
                          • U.S.A!
                          i wouldnt try it unless you know for sure what the cap will see in circut.
                          like the vrm caps at 10v when there should never be more than 2v.
                          thats why i say use 6.3v rated caps there.
                          if that section sees more than 6.3v the caps blowing their tops its the least of your worries ;-)
                          • glovecaps
                            Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
                            by glovecaps
                            I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
                            My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
                            The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
                            11-25-2024, 04:23 PM
                          • barrymoats
                            Issue with Shuttle SS56G Motherboard KTS24.5G1e
                            by barrymoats
                            I have a Shuttle XPC SS56G1 that I suspect has some faulty capacitors. Additionally, there's a missing component at location X5. This part is a small silver can, positioned horizontally, with the number KTS24.5G1e stamped on it. Before I replace the capacitors, I need to identify this part and find out where I can purchase one. Any assistance would be greatly appreciated.
                            06-11-2025, 03:41 AM
                          • keeper5511
                            Shuttle AS45GT Motherboard problem
                            by keeper5511
                            Hello everyone. I have just aquire an old motherboard from a friend (Shuttle AS45GT). I 've tried to boot the modo with no result as aupply lights are flashing when there is power supply but i get no picture and beep sound. CPU is heating very slowly without a heatsink and i realise that reset switch is not working. When i used a PCi diagnostic card i get different messages every time like 08 or 0C or 0d and i noticed that RESET light remains steady on the card. When i measure reset pin with polimeter i got 0V on it. I also have 12v light NOT flashing on diagnostic card. Can anyone help me result...
                            05-22-2024, 01:10 PM
                          • Docus
                            Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
                            by Docus
                            Hi everyone 😀,
                            I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
                            To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
                            Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
                            1. I already own the exact same model, but its plastic chassis is badly damaged.
                            06-10-2025, 04:24 PM
                          • Archimedes
                            HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
                            by Archimedes
                            Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
                            Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
                            Fans are spinning. Blindly could install windows11 and got the device manager...
                            07-30-2024, 05:14 PM
