1155,H61,IO check points_emadarion
  • emadarion
    • Jun 2017
    • 43
    • Cairo
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: 1155,H61,IO check points_emadarion
    Thanks!
    • sgysgy
      • Dec 2018
      • china
      thank you very much
      • faik26
        • Sep 2015
        • 10
        • TÜRKİYE
        thanks
        • dreico33
          TL866 II Plus Check ID Error on various IC
          by dreico33
          Hellow guys , i really need your help here.
          Lately i have a problem with My TL 866 II Plus programmer, and to be more specific many times on various IC ( Winbond, Gigadevice Mx) i get Check ID Error while i am trying to read the IC. Has already been detected without any kind of problem, but the only to read them is to uncheck every time the "Check ID " option. After that i can read it erase it and re-program it only to get another error at then end saying that can not verify the programing went well so i have program failed. So i am trying to find out what is going on? I...
          11-04-2024, 03:13 PM
        • hasel17
          CH341a can erase and read but can't write and blank check
          by hasel17
          So I am trying to repair broken thunderbolt FW on X1 Yoga Gen 2. The EEPROM chip is WINBOND 25Q80DVNIG. I already do a back-up and erase. But when I try to wrote new FW, it was successfull, but when I tried to read it, it still blank. when I try to do a blank check, it gave me instant error in address 0. I already tried two CH341A, already did the 3.3v fix mod, using AsProgrammer, NeoProgrammer, Colibri, and CH341A 1.29. But the problem still occurred. What I did wrong here? Can anyone help me? Thanks in advance. Here is the log in Colibri :
          Code:
          Checking for blank...
          (Press
          10-26-2023, 06:20 AM
        • Bogdan Kolybaba
          Dell AC adapter - 1 wire protocol. How to initiate to check if adapter works.
          by Bogdan Kolybaba
          Hi all. Trying to troubleshoot issues with the Dell Laptop power supply (a lot of info here). Now I am waiting for a DC power Jack, as there is a loose contact. Want to check if the ID line of the adapter works - I have given abt 3.2 V to this line through the voltage divider, but can't see any signal on the oscilloscope. Same with the 100500% working AC adapter as well. How to initiate 1-Wire protocol transmission? As I understand, the circuit in the AC adapter should send a package for a while as soon as the supply comes to the SPID line. How to initiate this transmission correctly without...
          02-20-2024, 07:41 PM
        • Kinshir
          How to check Dell BIOS dump integrity after downloading from chip
          by Kinshir
          Is there any known way to check Dell BIOS dumps integrity after downloading from the chip?
          I ask this to make sure that I don't get a corrupted dump.
          Thank you very much!
          09-11-2025, 10:24 AM
        • ktmmotocross
          how to check if xtal is working?
          by ktmmotocross
          Hello.
          I try to check some xtals wit my cheap osciloscope but i never get any good readings even when i measure working board.
          with my osciloscope i generated 32kh signal and can be easily check. but on xtals measure only some voltage
          How u measure it?
          01-04-2024, 03:58 AM
