A7V-VM Rev.304 doesn't completely POST
  • Solder Boy
    • Nov 2006
    • 178
    This is an ASUS or HP motherboard, no bad capacitors on the board, confirmed by ESR meter. Motherboard boots to a degree, I get the HP Invent Splash Screen and that's as far as I get. If I hit F1, it takes me to the CMOS no problems, but doesn't fully boot.
    I lifted the battery out and noticed it had leaked out, cleaned inside of the terminal with contact spray. Installed new battery.
    I did notice in CMOS someone must have flashed this thing I'm thinking because it said the Rev number was 3.08 instead of 3.04.
    So just looking for other's opinions.. would this board be toast because of an incorrect BIOS flashing?
    The board does turn and stays on... good board to cannibalize?
    www.bcrelectronics.ca
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    Re: A7V-VM Rev.304 doesn't completely POST
    Asus support doesn't list A7V-VM, perhaps because it's an OEM board they made for HP
    You get a HP splash screen, so no-one's tried an Asus BIOS instead of the HP one
    In CMOS there's probably an item which shows system specification, which should include model number or name that HP call it
    Once you know this, you should be able to find a download of a suitable BIOS from HP
    Try leaving the battery out overnight to ensure CMOS is cleared, then see if it'll boot with a diskette drive only
    If it does, you have an opportunity to reflash with a suitable BIOS
    I think Rev. 3.04 is hardware revision, whereas Rev. 3.08 is firmware (BIOS) revision
    They're not necessarily the same, although hardware revision can limit which firmware revision you're able to use (maybe that's the problem)
    better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
    • Toasty
      • Jul 2007
      • 4171
      Can you get to BIOS screen where you are offered something like "Default Setup" or "Safe Default" or "Factory Default Settings"?
      From HP's page-
      Clearing the CMOS settings
      The Clear RTC RAM (CLRTC solder points) allows you to clear the Real Time Clock (RTC) RAM in CMOS. It also allows clearing of date, time, and system setup parameter memories in CMOS, by erasing the RTC RAM data. The onboard button cell battery powers the RAM data in CMOS, including system setup information.
      CAUTION: Do not change any jumper setting while the computer is on. Damage to the motherboard can result.
      1. Turn off the PC and unplug the power cord.
      2. Use a small screwdriver to cross the CLRTC solder point pins 2-3.
      Remove screwdriver before powering up. - Toast
      3. Start the PC and press F1 to enter the BIOS setup and change the BIOS settings.
      "HP Montana" - http://h10025.www1.hp.com/ewfrf/wc/d...bph07422#N1206
      "HP Mocha" - http://h10025.www1.hp.com/ewfrf/wc/d...bph07227#N1133
      veritas odium parit
      • Solder Boy
        • Nov 2006
        • 178
        Thanks for the info Toasty.. just looked at the board.. there are no pins where the CLRTC should be, just the solder holes. I will give that a try and see what happens.
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          You can't test caps mounted in parallel without removing them from the circuit.
          Mann-Made Global Warming.
          - Dr Seuss
          • Solder Boy
            • Nov 2006
            • 178
            I don't understand why you say that.. I have come across bad caps in the VRM section using the ESR meter before without having to take them out. If you could please enlighten me
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              If the caps are in parallel the you are measuring all of them together because they are connected through circuit board.
              VRM caps are always in parallel.
              - Dr Seuss
              • Toasty
                • Jul 2007
                • 4171
                Yet he says that he has found them. Verrrry interesting...
                On the other hand, if you find a bad one, you're gonna change them all anyway, aren't you?
                veritas odium parit
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  Actually he said:
                  >>> no bad capacitors on the board, confirmed by ESR meter. <<<
                  You could have 9 bad ones in parallel with one good one and ESR meter would read all 10 as good.
                  - Dr Seuss
                  • Harvey
                    • Apr 2007
                    • 264
                    How long are you waiting for it to complete the POST? If there's an IDE issue it can take a couple of minutes or more for each attempt at finding a drive to time out, so you want to be waiting 10 minutes or more to see if anything happens.
                    Also have a look for a 'Reset Configuration Data' option in the BIOS (normally in the PNP or PCI sections) and set it to Enable if its there, as if the ESCD data is scrambled it can cause POST failure.
                    • Toasty
                      • Jul 2007
                      • 4171
                      @PCBONEZ
                      I was responding to his statement-
                      >>I have come across bad caps in the VRM section using the ESR meter before without having to take them out. <<
                      -and not disputing yours.
                      veritas odium parit
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        Originally posted by Toasty
                        @PCBONEZ
                        Well, yeah, is ALL of them are bad the ESR meter -might- read bad.
                        I'm trying to teach him the right way here.
                        Don't confuse him any more than he is.
                        - Dr Seuss
                        • RJARRRPCGP
                          • Jul 2004
                          • 6304
                          Likely a bad HDD or wrong jumper setting for a PATA drive.
                          ASRock B550 PG Velocita
                          Ryzen 9 "Vermeer" 5900X
                          Arc A770 16 GB
                          eVGA Supernova G3 750W
                          Alienware AW3423DWF OLED
                          • DynaxSC
                            by DynaxSC
                            11-17-2023, 10:56 AM
                          • Tynan Dill
                            by Tynan Dill
                            Assuming...
                            11-22-2024, 01:46 PM
                          • edward card
                            BIOS Request: MSI Raider GE68 HX 14VGG-287US (Board: MS-15M2) - No POST
                            by edward card
                            I'm requesting a working BIOS dump for my MSI laptop, which I plan to provide to a repair technician.
                            Make/Model: MSI Raider GE68 HX 14VGG-287US Board Model: MS-15M2 (Note: I have the serial number ready to be provided to the technician for DMI transfer)
                            Problem Description: The laptop fails to POST. The only sign of life is the GPU fan spinning up after a couple of minutes. The screen remains black.
                            Background / Fault Event: The system was working perfectly. The issue occurred immediately after entering the BIOS advanced menu and exiting with "Discard...
                            10-06-2025, 05:41 AM
                          • pirati
                            by pirati
                            Today, 04:20 PM
                            by Vesko356
                            08-11-2023, 03:27 AM
