3.2V on Northbrigde ?
  • bianchi77
    • Jun 2016
    • 1121
    Guys,
    I got 3.2V on Northbridge, it's Intel JG82865G SL99Y, could be this northbridge is faulty ?
    Normally I got 1.8V for it ...and when I checked with my thermocouple it reached nearly 100 degree with heatsink...
    Any experiences ?
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: 3.2V on Northbrigde ?
    its possible it survived.but you need to fix the regulator issue asap.
    dont power it up till you do.
    • bianchi77
      • Jun 2016
      • 1121
      I reckon it's faulty, I got no VGA output anymore from it....
      • kotel studios
        Asrock 970 PRO3 - missing 1.1V on NorthBridge
        by kotel studios
        Recently I got this Asrock 970 PRO3 board from scrap. It had a few missing caps under the NB which I've replaced. Sadly, one of them went short (NC597 from boardview file). I did replace it and there doesn't seem to be any shorts left, but the board is not executing POST nor beep codes. I once got it to POST after I was slightly bending it, but that was only once. I tried to redo the same steps but to no avail. All caps on the backside of NB have 22-ish ohms.
        I have traced the problem to an dead Northbridge VRM. There's no voltage on Phase (pin 8), FB (pin 6), UGATE...
        Today, 02:34 AM
      • rakonja
        PHILIPS 42PFL7008k/12 HARDWARE UPGRADE(REQUIRED HARDWARE/EXPERIENCES)!!
        by rakonja
        Hello everyone! I am the owner of a Philips 42PFL7008k/12 TV! It served me well all the years. Sometimes it used to get "stuck", after which I used to disconnect it from the voltage, hold the power button on the device for about 30 seconds, and after turning it on again, it worked like new!Only once it threw something like no software!Now it happened that it won't turn on anymore, the red LED blinks twice!Do you have any suggestions? They are probably not cost effective to repair, but I am sorry to get rid of it, it has served me well and looks like new!The only downside is the slow...
        09-07-2023, 09:50 AM
      • dcapper
        Bad Experiences with repairs
        by dcapper
        So who's had bad experiences with tv repairs? I was given a nice LG 50" Smart TV with burnt out led's and I replaced them all. Put it back together and thought I had the screen in the right position. Clicked the case on and crack. Ugh. Garbage now.
        03-15-2020, 06:00 PM
      • capwizard
        Fix Thermocouple
        by capwizard
        I have 3 thermocouples which I bought from Aliexpress has 2 meters long, very inconvenience to use. my question is thermocouple is two metal welded together. can I cut it then weld to make multi thermocouple?
        I cut open the one is not working, the wires are separated can I weld it and fix it?...
        03-13-2019, 11:17 AM
      • itelite
        lc-90le657u - any experiences?
        by itelite
        I am working on a Sharp lc-90le657u at a customer's home.
        It would occasionally click the relay, turn on the backlight for a fraction of a second, turn off, click relay off. More often than not it will do nothing at all.
        On the first trip i replace the power supply, on the second i replaced the main board. Today i spent about an hour testing various things.
        Tested all LED + - wires. all exactly 196v with backlight tester, and could see each strip light up. With ameter in series the current was identical on every strip.
        Primary side voltages...
        05-06-2021, 08:07 PM
