lc-90le657u - any experiences?
  • itelite
    • Aug 2016
    • 124
    I am working on a Sharp lc-90le657u at a customer's home.
    It would occasionally click the relay, turn on the backlight for a fraction of a second, turn off, click relay off. More often than not it will do nothing at all.
    On the first trip i replace the power supply, on the second i replaced the main board. Today i spent about an hour testing various things.
    Tested all LED + - wires. all exactly 196v with backlight tester, and could see each strip light up. With ameter in series the current was identical on every strip.
    Primary side voltages appear to check out fine.
    Only voltage present on secondary side is the 5V standby.
    Power button has 3.3v on it and goes to zero when switch is closed as expected.
    with no main board connected power supply does not turn on, but i dont know if it should.
    With PSU_ON tied high the power supply does not turn on / create higher voltages.
    Unplugged TCON cables, nothing changed.
    Either i am completely missing something, or i got bad parts maybe?
    Anyone have an experience at all with this tv? Anything else i can check.
    Coppell lists a repair service for the power supply, that is often an indicator of a known issue, but im not seeing anything anywhere else.
  • f67bird
    Technician
    • Apr 2007
    • 57
    Re: lc-90le657u - any experiences?
    Does the chevron below the sharp badge flash an error code?
    Learner
    • itelite
      • Aug 2016
      • 124
      I dont believe so. I did some more research based on the PSU part number and it looks like there is a repair kit. it looks to just be 4 diodes for a few $. i went ahead and ordered it. Its a huge tv and im working in a guy's house so i didnt start taking components out of the board for individual testing as i would do at the shop.
      If this fixes it, i paid $200 for an equally defective replacement power supply.......fun
        by sam_sam_sam
        03-31-2024, 02:12 PM
      • benareeno
        Adjustable dc power supply and tcl led strip
        by benareeno
        I wonder if i shorted the whole strip...where to put pos and neg to just light up a single diode...or the entire strip. The strip lit for a second...so maybe i fried it? What say you?
        I have an adjustable dc power supply and was trying around 9 volts.
        I have a pic of a single diode...where to put pos and neg terminals to light it up?
        Pic of middle of strip..is this where i light the entire strip?
        And pic of end...or does this light the entire strip?
        Where to put pos and neg for single diode..multiple diodes and the entire...
        07-11-2021, 02:31 PM
      • edugimeno
        Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
        by edugimeno
        Hi There!
        I'm trying to help my friend who owns a restaurant be just bought.
        He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
        It's stuck using, I guess, the 2 sided tape that comes with the strip
        The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
        09-05-2024, 09:34 AM
        by sam_sam_sam
        07-01-2024, 06:34 AM
