Re: MSI K8 Neo4
good! shows that u know your stuff now. that is the best psu to get currently. its based on the superflower leadex platform and has 100% all japcaps. its ultra low ripple will ensure that your mobo and hard drive will last a very long time!
lol errr i already warned u in my previous post about that chipped/cracked smd mlcc. doesnt mean that its been like that for years, it will continue to remain that way forever. that is why u NEVER ignore bad caps!
u are quite lucky it didnt make a huge crater in your mobo. if it melts a trace and/or makes a crater in the board, its a goner. just ask momaka, he has personally witnessed cracked/chipped smd mlccs making large craters on boards with the copper completely exposed!
i think credit can be given for the new evga g2 psu for having *fairly* fast and quick short circuit detection. it tripped when the smd mlcc shorted out, saving a huge crater from being made in the motherboard! thats a good psu at work there, saving someone's butt!
hopefully, its not too badly charred around there and its still fine. u *must* now remove the smd mlcc from the board before applying power again. its shorted out and powering on the mobo is just pointless now and it will just keep shorting and frying the board in that area further, resulting in further damage.
seeing as how the smd mlcc is near the atx 12v connector, its probably a redundant power line noise filtering cap. there is usually an overkill number of those scattered on pcbs so its actually okay to remove it first, *then* power on without adding back a replacement just to see if the mobo is still alive. its only an issue if u intend to overclock where absolute stability and cleanliness of the power supplied to the board is a must.
where we are coming from is that we dont want other new members reading this and thinking it is okay to get away with using a junk psu. that is simply misleading to other new members who are also learning this stuff.
the real reason why that mobo lasted so long with that junk psu was most probably because of the branded japcaps on the mobo. the japcaps on the mobo held their own against a junk psu and gave u 6 years of service until something else crapped out. thats the real reason to give credit for the system lasting 6 years. we are strongly against giving credit to "a junk psu lasting for 6 years". that is simply not true here...
what im curious is, what hard drive did u use with that system? im surprised a hard drive can last 6 years without failing on that junk crapful of ac ripple psu.
now, be careful about that. dont *assume* anything. there are apparently two versions of the fx-55 according to this cpu list from wikipedia. one is the clawhammer version, the other is the san diego version.
the only way to identify them apart is to look at the last 6 characters of the model number. check the model number sticker on the cpu box. if it ends with "DEI5AS", its the clawhammer 1.5v version; if its "DAA5BN", its the san diego 1.35v-1.4v version. dont wanna be getting the voltage wrong and possibly ending up with fried hardware or ending up redfaced and wondering why the computer wont post...
Originally posted by ml2
View Post
View Post
View Post
View Post
