AM2+ and AM3 socket ?
  • bianchi77
    • Jun 2016
    • 1121
    Guys,
    Can I use AM2+ CPU on AM3 socket ?
    Do they have the same pin out ?
  • Spitz
    • Oct 2010
    • 95
    Re: AM2+ and AM3 socket ?
    Originally posted by bianchi77
    Guys,
    No, they support different cpu's and memory.
    • jiroy
      • Jun 2016
      • 2416
      • Lebanon
      Amd Cpus are very tolerant regarding different sockets ..Many Amd Cpus for AM3 socket can be used on AM2+ . The last one i did was a Phenom 2 on Am2+ , but they will show less performance of what are they supposed to show , because they cannot benefit from their equipped special extensions and features .
      Best way usually to confirm this tolerance is to download the board manual and compare what Cpus can usually take..
      • bianchi77
        • Jun 2016
        • 1121
        can I use AM2 CPU on AM3 ? I have Athlon 64 x2 3800 but the motherboard is AM3...
        I don't have AM3 processor for a test...
        • electromaster84
          • Jul 2015
          • 35
          If the motherboard supports DDR2 memory then yes. If the motherboard uses DDR3 then it won't work. AM2 and AM3 processors are pin compatible, but AM2/AM2+ processors only support DDR2 memory because the memory controller is on the cpu.
          For future reference
          AM2/AM2+ = DDR2 only
          AM3 = DDR2/DDR3
          AM3+ = DDR3 only
          • bianchi77
            • Jun 2016
            • 1121
            The motherboard is :
            ASUS M4A89GTD
            may be you guys have more infos ? I tried reading from asus...but may be someone else has a different knowledge...
            • bianchi77
              • Jun 2016
              • 1121
              info :
              https://www.asus.com/Motherboards/M4...pecifications/
              looks like I'm gonna need AM3 and DDR3 only...
              • Isabella91
                Possible to convert eMMC Socket to a micro SD Card socket?
                by Isabella91
                I have seen many posts where the eMMC can be read via a SD card reader, however can the opposite be achieved?
                Read/Write a Micro SD Card from an eMMC Socket.
                I have a Motherboard with a Kingston BGA153 ball socket, using HS400 bus mode, which is 8bit, as Micro SD is usually 1bit or 4bit mode, I accept that a loss of speed in read/write will occur, but I would sill like to convert.
                Theoretically speaking, Im thinking if I hard solder DAT0-3 from eMMC to SD Card Reader, this should force 4-bit mode, or only DAT0 to force 1-bit mode.
                Not to remove...
                01-14-2024, 05:10 PM
              • warsztat
                Acer AN515-57-577G JDIMM1 socket not working.
                by warsztat
                Hello, Acer AN515-57-577G JDIMM1 socket does not work. GH51G LA-L181P, 2x DDR4 RAM, both good, both work well in JDIMM2, neither works in JDIMM1. The laptop displays BIOS, when the JDIMM2 socket is occupied, you can run Linux on USB, then everything seems to work ok, there is internet access and you can browse the contents of the 512 GB SSD in Windows, but starting Windows ends with an eternal spinning circle, maybe there are corrupted files. When the RAM is inserted into the JDIMM1 socket, the laptop starts but there is no image and the downloaded current does not change and the output is ~2.25A....
                11-18-2024, 09:13 AM
              • ugamazing
                Procedural question about BGA rework and removal of CPUs
                by ugamazing
                I have been working to develop a consistent and reliable method/workflow for removing, re-balling, and replacing CPUs on various MacBook Pro models (2015-2020).
                I have done OK so far, but there's one detail I need to sort out. I'm hoping someone much more experienced than myself may be able to shed some light:
                I am noticing the pulled CPUs (to be re-balled) come off fine, and they "look" fine as well, immediately when I pull them. However, within a few minutes, after cooling, the CPU chips develop a very, very slight curve/bend. It's SO SLIGHT, maybe a 1-2%...
                07-12-2022, 03:11 PM
              • limcc
                MSI Tomahawk B550 no beep
                by limcc
                I have a Tomohawk B550 that die suddenly. No BSOD, no weird sign or no POST/boot just a day before it happened. Fans are spinning, BIOS had flashed several times, CMOS cleared, battery removed, etc. CPUs--5600 and 3700X were tested working on 3 other boards--Aorus X570/Auros B550M-Pro-P/TUF X570, so as the PSUs--RM650x/HX650 , as well as the DRAMs, all components are tested working. The only indicator it show was DRAM LED kept lit up, no beep. The same symptom also happen on my 9 years old TUF X99 board but thats another topic, probably due to age.
                Today I bring out the board to check...
                11-16-2024, 12:27 PM
              • Biessea
                ASUS Sabertooth 990FX REV.2 bios chip problems, probably socket shorted?
                by Biessea
                Hi there,
                I'm a technician and a computer/retro computer lover.
                I just bought a great Sabertooth motherboard (I really love the colours and the ASUS military scheme) to install a nice FX-8320 from AMD and make a gaming computer with a Geforce GTX 970.
                For the first time I had problems with the system, but I solved and then correctly booting, I installed Windows 10 and then I started to overclock the system. I reached a stable configuration of 4,8GHZ with 1,475v.
                Then I saved fan configuration, and other parameters, and saved to the overclock profile...
                03-01-2022, 03:57 AM
