Gigabyte K8VM800M - What's causing this video problem?
Re: Gigabyte K8VM800M - What's causing this video problem?
But what about using the SATA HDD and using an PATA (IDE) optical drive? Give that combo a try just to see if the same thing happens or not.
From post #33:
Finally installed XP x64 on SATA drive and couldn't get it to fault while running my checksum app on those two video files that are located on the IDE drive - So it appeard that the SATA ports were OK
i, just now, have only the SATA hard drive and the PATA optical drive connected, and it loads the Windows XP DVD no problem (tested this four times).
Now continue installing windows.Last edited by socketa; 06-11-2016, 09:06 PM.Comment
I thought what you meant in post #33 was that you installed Windows from the DVD drive onto the SATA HDD, but kept the PATA HDD as well for the test video files and it all went bad when you took out the PATA HDD.
But I understand now.
So now that you installed Windows for a second time on the SATA HDD... does is still refuse to boot if you remove/disconnect the PATA optical after installation?Comment
Ok,
After the computer accidentally got switched off after 3 hours of the XP install disk formatting a 10 gig partition, and then at least another 6 hours of formatting (before i went to sleep), i moved it on to the copy files stage, and none of the files would copy, and i got an error message about no hard drive.
So rebooted into BIOS and this was confirmed.
Turned it off and removed cable from SATA1, into SATA0 port
Rebooted, and SATA drive was detected in BIOS.
Rebooted into PATA DVD drive and, this time, ignored the warning about installing XP in a partition that already contains another windows installation.
(So apparently it didn't format the drive after all of that?)
Finally got XP installed, and then installed the checksum app, and plugged in a USB stick with the video files.
Ran the app on those files.
The video faulted in a similar fashion as before.
On 6 successive reboots and running the same test, no fault whatsoever was observed.
Just out of curiosity, (and possibly unrelated) i then turned off the machine and plugged the SATA drive into SATA1, and, after booting, i got the message: "windows cannot start because hal.dll is missing or corrupt"
Then i plugged it back into SATA0 and got the same message.
How can swapping the drive from one SATA port, to the other, cause it to become "corrupted"?
Then i put the XP disk in, ignored the "press any key to boot from CD" prompt, and windows started normally.Last edited by socketa; 06-12-2016, 11:01 PM.Comment
We need to know if the problem is a hardware or software issue.
Reflash the BIOS with a newly downloaded copy for that version of board but do not put the flasher or bios file on any other drive other than a floppy disk. Use drdflash.exe to make a dos bootable disk and then copy the flasher and bios file to the disk.Comment
Ok,
WAS THE DRIVE YOU WERE COPYING TO PATA OR SATA?
CORRECT.
WHAT DRIVE WAS XP INSTALLED ON, PATA OR SATA?
Then i put the XP disk in, ignored the "press any key to boot from CD" prompt, and windows started normally.Comment
Are you using the SATA drive in IDE MODE
Although it was previously successfully flashed before, using @BIOS, and again with a normal startup disk.
What difference would it make using drdflash.exe instead?
WHAT DRIVE WAS XP INSTALLED ON, PATA OR SATA?Last edited by socketa; 06-13-2016, 04:47 PM.Comment
One thing that could cause the HDD sata or pata to not boot right would be the Master Boot Record on the drives. You should wipe the drives clean, zero-fill before reinstalling the OS each time because switching from one port to the other can cause corrupt MBR.Comment
The windows installation was not completing, it would halt, and give message about not being able to copy a file, with the option to ignore it. (and ignoring it, gave the same type of message for all subsequent files)
So i did as you suggested.
i used DOS KillDisk, on a USB stick, to wipe the SATA drive successfully.
When i tried the USB windows version of KillDisk - not long after the app eventually loaded, the video faulted.
So i plugged in a different hard drive, this time a different PATA drive - Same deal as above.Last edited by socketa; 06-15-2016, 05:09 AM.Comment
So i plugged in a different hard drive, this time a different PATA drive - Same deal as above.Comment
Some photos of the bad board would be nice.Comment
Do you have a SATA optical drive to pair up with the SATA HDD? Curious to see what goes on with same types of matched hardware.Comment
Have you recapped the other same model board?
Do you have a SATA optical drive to pair up with the SATA HDD? Curious to see what goes on with same types of matched hardware.Last edited by socketa; 06-18-2016, 01:29 AM.Comment
No - It still has the original caps and is working fine: MBZ on the input, KZG on the output (so that's opposite of the faulty board) and all the 1000uf caps are MBZ, just like on the other motherboard.
Tried that in post #36 and got intermittent problem as described - just tried again and got the same issue. Briefly put, the process can take more than a handful of restarts until it progresses to the "press any key to boot from cd" prompt rather than stalling that "boot from cd" line above and before it.Comment
I think you have a bad switch and should try to replace it
Then i replaced it with a power switch that tested good and put the other (good) K8VM800M board into it, and it ran with no problems.
Then the other K8VM800M that was in another case, started to develop it's video fault, so i swapped these two boards out of their cases, in order to see if the video fault would disappear.
The fault persisted.
Since there is a video AND an IDE/SATA issue, and assuming the these two issues are connected, i'm thinking that the problem is somewhere either in the vicinity of the north bridge or the memory controller.Last edited by socketa; 06-18-2016, 03:04 PM.Comment
I do not know how many or how much experience you have in soldering caps on motherboards but you can try to reflow more solder to the caps that you replaced. Sometimes the top layer does not get completely heated well. Also you are having both Northbridge and Southbridge issues. This suggests a common connection wich could be PSU related such as Under/Over voltages, Ripple (RF Noise), Unsteady varying voltages.Comment
All of the output caps are connected in series - i checked continuity.
Not super awesome at soldering caps, but am OK, and have a hot enough station.
Stable output to CPU at 1.4V
i don't have an oscilloscope to measure ripple
No, i haven't replaced the TIM, and don't see what difference it would make, because it is firmly attached (thermal adhesive?) and gets roughly to the same temp as the one on the good board (which is luke-warm).Comment
The northbridge heatsink should come off it might need some heat to break the bond of the tim. Does it use those press-in pins or wire spring clips to attach to the board? If this is a VIA Chipset board then it will most likely have a recessed surface wich means that it takes a better and more amount of tim that what is put on at the factory. Additional cooling is always better for them.Comment
by alro7779Hello, everyone!
A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,... -
by SpikemanHi, I'll tell you the story of this PC.
The PC was repaired because it had a shorted power supply. What happened was that the plastic covering the buffer battery positioned by the manufacturer on the capacitor melted, thus generating a short.
After the repair, the PC worked, I installed Windows 11 and I may have had some problems with the video drivers, but after a bit of tinkering I think I solved them.
However, the PC later presented the problem in the video shared very frequently.
The problem also occurs at startup, in the bios and when using it as a monitor thanks...-
02-27-2024, 10:17 AM -
by Gibon378PC Specs:
- CPU: Ryzen 5 1600
- GPU: GTX 1080 Palit JetStream
- MOBO: ASRock ab350 PRO4
- RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
- PSU: XFX 650W (don't remember what model)
- OS SSD: ADATA SP920
- OS: Windows 10 21H2
Problem description:
Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders... -
by zimeyhHi guys! I have a problem with macbook pro A1502. This display have a apple video, when launch desktop, this display is off. A connect thunderbolt a monitor, have video and laptop and monitor. Disconnect thunder video power off. Whats problem? 🤦🏻*♂️ thankss
by pkslowkSr. Motherboard Debug Error Code Solution
1 Intel 845 E9 Bios Related Problem
2 Intel 845 D4 CPU Socket Related problem
3 Intel 845 37 Bios Related Problem
4 Intel 845 7C Bios Related Problem
5 Intel 945GCPE 34 Bios Related Problem
6 Gigabyte 845 2 Ram Related Problem
7 IBM Server A6 A7 Ram Mismatch Problem
8 Asus 845 29 CPU Related Problem
9 Lenovo I946 97 C-Mos Jumper related
10 Gigabyte 845 A0 CPU Related Problem
11 Asrock G31M-VS D7 Bios Related Problem
12 Compaq 845 BD-70G B0 CPU Socket Related problem... - Loading...
