K7N2 Delta2 Memory Bugs
  • bgavin
    • Jan 2007
    • 1355
    I acquired this board from an eBay seller. It is populated with all upper quality caps. No craps.
    The installed Sempron 3200/200 FSB runs DDR-266 just fine, but chokes on Corsair XMS, DDR400. Go figure. Memtest runs 24+ hours on the DDR-266, but Test 5 barfs repeatedly with the Corsair.
    I've twiddled voltages between stock 2.6 up to the Corsair recommended 2.75v for this pair. Matched set of 1gb as Dual Channel. Stock clocking. I even slowed down the CAS speeds... no luck.
    These two memory sticks run Memtest86+ for days with zero errors in an Intel D875PBZ board. I don't think the sticks are bad... but the MSI board sure doesn't like them. I'll install the DRR-266 for the client, and run it that way... but it would be nice to use the full DDR-400.
    Thoughts, anybody?
  • zandrax
    Hit and miss
    • Dec 2007
    • 1157
    • Italy
    Re: K7N2 Delta2 Memory Bugs
    Maybe the chipset can't address all memory chips or low level parameters are incompatible: think your Corsair ram may be too advanced for the Via KT266 chipset.
    Zandrax
    Have an happy life.
    • kikkoman
      • Jul 2007
      • 691
      @zandrax: it's a Nforce2-U board.
      Have you checked the latency settings? Higher (slower) values than specified, especially CAS, can cause errors in some combinations (and SPD values aren't always correct).
      What about spread spectrum?
      You might as well disable the dual channel mode, it doesn't make a difference.
      "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
      • stevo1210
        • Oct 2006
        • 4156
        If I remember correctly, fellow forum member, Pentium also had similar issues with his K7N2 Delta 2 regarding the memory installed. I don't know if this is of any help but anyway you can check https://www.badcaps.net/forum/showth...highlight=K7N2 for some more info.
        • bgavin
          • Jan 2007
          • 1355
          All K7N2 are nvidia chipsets (N2..) I refuse to use VIA.
          Yes, as noted above, I have changed the CAS settings. Slowing down the FSB to 100 will let the Corsair run OK. This is unacceptable, but it runs OK. the error is confined to bit 03 being hot, most of the time.
          I have some different DDR400 arriving tonight, so I will give that a test. This is a client machine, so I don't have much free time to spend on diagnostics. I'm buried in work, and this has to get off the bench and out the door. It came in with DDR-266, and will probably go out with DDR-266.
          • bgavin
            • Jan 2007
            • 1355
            Follow-up on the memory problem... I pulled the 2x1gb Corsair XMS DDR400 from the machine, and replaced with a set of Corsair Value Select 2x1gb DDR400. The machine is a happy camper... Memtest86+ runs for days with zero errors.
            Voltages in both cases are 2.7v, auto negotiated by the BIOS from the SPD value. CAS are SPD defaults. At first I thought the XMS was bad, but it performs flawlessly in an Intel D875PBZ board.
            The interesting part of this whole experiment is, there is a definite point of diminishing returns on Dollars vs. Performance. Unless you strike a serious deal with an eBay sale, one is better off buying a Core2 Duo and modest P35 board, than wasting most of that money on socket 462 or P4 boards.
            I paid almost as much for a D875PBZ and P4 3.4 GHz Northwood as I would for a P35 and Conroe. And... DDR2-800 is cheaper than DDR-400. Unless you have a bunch of parts in the bin, there is no reason to tinker with yesterdays hardware.
            • zandrax
              Hit and miss
              • Dec 2007
              • 1157
              • Italy
              Sorry bgavin: I mismatched Via for nVidia.
              @ stevo: bgavin's Corsairs aren't registered modules. Pentium had troubles becuse he put server ram into a desktop motherboard.
              Well, you may need a feature available only on old motherboard, such as Isa or Agp slots. However, I agree that picking a lot of used components may be antieconomical compared to new and improved / more powerful pieces.
              Zandrax
              Have an happy life.
              • h0m3w0rk
                Random Shutdowns/Startup Failure with Corsair SFX 450
                by h0m3w0rk
                I'm encountering a frustrating issue with my Corsair SFX 450 power supply. After an undefined period of operation, my PC will either suddenly restart or, in some cases, it won't start at all until I disconnect the power cable and reconnect it. This erratic behavior occurs intermittently, making it difficult to pinpoint the exact conditions under which it happens.
                For context, I have tested the PSU using an electronic load at 150W, and under those controlled conditions, it functions flawlessly. This leads me to...
                02-09-2025, 03:19 AM
              • zunasthegreat
                Dead corsair VS450 with blown TNY chip (cwt)
                by zunasthegreat
                I have this Corsair VS450 PSU which lies dead and has an exploded TNY chip. Upon removing primary side parts like mosfets, the bulk cap and the bridge rectifier I've found that the primary cap is also a goner. (Photos)
                The mosfets and the diode are fine and survived the collapse it seems. The TNY chip is shattered and from the online review/sources it was probably a TNY176~177....
                08-30-2025, 03:11 AM
                Corsair CX750M [Model 75-002019] - burned output toroid inductor
                by momaka
                Looks like I may need a little help from the PSU experts (or anyone really! ) I have a Corsair CX750M (Model 75-002019) that I picked up for free about 4 years ago. This is the PSU:
                So here’s what’s strange about this one: it appears to work normally (normal output voltages) and any PC is stable with it. However, after a while (typically 10-20 minutes, but time can vary depending on the load), there is a sweetish smell of burned magnet wire insulation emanating from the PSU. Upon opening the PSU after this happened (many times), I was able to confirm...
                09-19-2021, 08:44 PM
              • hobostove
                Corsair RM1000e - Help identify 5VSB Zener diode
                by hobostove
                Hey there guys. I've got a Corsair power supply that's come across my bench dead. I usually don't mess with power supplies, but it's a slow week so I'm giving it a whirl.
                Taking it apart I heard a screw rattling around inside, and when I got it apart I found a couple blown components near what I think is the 5VSB area.
                There's a 22ohm resistor that's melted and open, but it still has the bands.
                The other part is a zener diode and it's top went to jesus, so I can't read the marking.
                It looks like the diode connects the source and drain of a TNY284...
                03-27-2025, 02:25 PM
              • W1ngl3t
                Corsair RM850x (synchronous ATX) need help troubleshooting
                by W1ngl3t
                I have a Corsair RM850x that refuses to turn on. I have 5v stby but as soon as I try to power it up it goes 'click' and does not deliver any voltages.
                I have not been able to find any blown or shorted components and there are no bulging capacitors. I have replaced the APFC controller and for a brief period (2 or 3 on/off cycles) the PSU worked but then the fault returned. Perhaps heating the PFC area is what resulted in the temporary fix?
                The only option I see now is to start pulling components one by one, but before I proceed, perhaps someone more knowledgeable...
                03-15-2025, 04:43 PM
