GA-8I915P Duo Pro with bad Sanyo WG
  • ChaosLegionnaire
    HC Overclocker
    • Jul 2012
    • 3266
    • Singapore
    Re: GA-8I915P Duo Pro with bad Sanyo WG
    hmm does this mean early production batches of ultra low esr caps from many manufacturers had issues or is that just an isolated incident? i have some suncon wg too. i had better check mine as well lol
    • pfrcom
      Oldbie
      • Jun 2006
      • 1230
      It wasn't one of the Suncon I put in (my first reaction), but one of the original Sanyo I hadn't replaced
      Advice to replace all similar when one or more goes bad is certainly correct, but given the board is usually in storage I'll take the risk of more bad siblings
      better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
      • ChaosLegionnaire
        HC Overclocker
        • Jul 2012
        • 3266
        • Singapore
        power up and run the board for a few hours every several months or so to reform the caps. that should keep them from bloating or failing in storage.
        • Wester547
          • Nov 2011
          • 1268
          • USA.
          ^ Not really...
          If a liquid electrolytic is prone to generating hydrogen gas just by sitting on the shelf and hasn't been overheated or abused in any form, shape, or manner, it's probably doomed to failure. The issue of reforming electrolytic capacitors has more to do with the anodic dielectric than the electrolyte. The dielectric that separates the conductive plates is not an impeccable insulator, which allows for a small amount of current to "leak" from the electrolyte to and through the dielectric due to the potent electric fields generated by the charge on the plates when you apply bias to them. This small, ever flowing DC current is also known as leakage current, or electrons making their way through and around the dielectric, all the way down to and across the wire leads, fully discharging the capacitor over time.
          When an electrolytic sits in storage, due to the fact that the dielectric is NOT a perfect insulator, small, ionic parts of the electrolyte can readily diffuse into the porous, anodic oxide layer, which can alter the crystal oxide structure and produce potential electrical defects such as ionic charge carriers. This is what causes leakage current to increase as capacitors sit in storage, especially in glycol-base electrolytes (lactone-base electrolytes have the advantage of not being able to penetrate the dielectric as easily), although such electrolytes are very effective at restoring the oxide layer once current is flowing and a voltage has been applied to the plates.
          This is completely seperate, again, from capacitors which will produce excessive amounts of hydrogen gas without ever having been installed in a circuit. And it's also distinct from capacitors that have issues with water-driven corrosion due to ineffective inhibitors, which will allow the electrolyte to actively attack the dielectric until it is no more. Capacitors with a poor pH balance will suffer from similar issues, where the aluminum oxide dissolves into the electrolyte until it is again no more. Without getting any more verbose, it's safe to say that those older 1000uF 6.3V 8mmx11.5mm WG simply suffer from bad electrolyte...
            master hoarder
            • May 2008
            • 12175
            Yup, exactly. ^
            It doesn't matter if you reform caps to rated voltage or not - bad caps are bad caps. I've noticed this with quite a few of the bad brands/series. Reforming some of my "going bad" caps (that haven't failed quite yet) did not seem to improve their leakage current at all, and they still showed abnormally high capacitance.
            All that reforming does is it makes surge currents much smaller when the cap hasn't been used in a long time.
            • televizora
              ghettomodmaster
              • Nov 2016
              • 957
              #26
              Originally posted by goodpsusearch
              I still keep Pentium 4 SDRAM motherboards. I guess I should get the caps and recycle them
              No SD-RAM on this motherboard. SD-RAM slots have 2 notches.
              Useful conversions. I don't "speak" imperial. Please use metric, if you want to address me.
              1km=1000m=100000cm, 1inch=2.54cm, 1mile=1609.344meters, 1ft=30.48cm 1gal(US)=3.785liters, 1lb=453grams, 1oz=28.34grams
              • karatzdi
                Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
                by karatzdi
                I know some might say... just buy another one. Sell it as parts..!
                So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
                Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
                Spent some time downloading the Service...
                06-11-2024, 08:38 AM
              • Pinky Deepak
                Vizio M60-C3 Left Edge problem
                by Pinky Deepak
                I have a M60-C3 where the left edge has started showing issues as seen in the picture attached. Along with this, I also noticed some darkening on the left half of the screen which went away after I left the TV unplugged. i initially thought it was the led backlight that was wearing out but looks like something to do w the TCONN board. I searched this forum but couldn't find anyone else seeing this issue. most of them were LH/RH completely gone. any insights or guidance is appreciated.
                Here's a video of both the issues: https://youtu.be/hMqc760nB3o
                09-27-2024, 05:11 PM
              • armoured_smiler
                Panasonic Tx-40cx400b top left half screen not displaying correct
                by armoured_smiler
                Trying to work out if this is TFT problem or TCon issue.
                The TV powers up but the top half of the screen, from the right it is OK, but as you look across to the left halfway across it starts get duller and duller until it is very dark on the lefthand side, currently I trying to clean the remote as it seems to have something film wise on the pads stopping it from registering buttons pressed.
                Also when changing the screen size of Windows PC display to say to a smaller pixel sizewindow, the original window displayin the top left stays/takes a few seconds to disappear?...
                04-08-2024, 03:40 PM
              • Sik_6ty_Sixx
                HH Scott Model A510 Stereo Integrated Amplifier/ Graphic EQ - Blowing fuses in the LEFT speaker channel only. Any Help???
                by Sik_6ty_Sixx
                So like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...
                02-18-2025, 05:06 AM
              • cj_reha
                Mystery 80s Sanyo cap - perhaps polymer?
                by cj_reha
                Hey all I've been working on a 1984 Sanyo 27" color TV which had a smattering of bad caps in the video switching circuit. I found this oddball little 1uF 25V cap which looks to me like an early polymer, but I can't find concrete info proving it. I know Sanyo was a big player in early polymer cap development and this is the time period where they were just getting on the market, so I'm wondering if anyone has crusty old datasheets that could help identify it and determine if my suspicions are right? It has the same epoxy end seal and font/formatting as some old stock Os-Cons I've got laying...
                01-06-2023, 09:24 AM
