yep panasonic.
Zida T810B-SE mainboard, filled with Licon caps
I'm happy to find this forum, have read here many usable informations about caps, etc..
I recently came across a Zida T810B-SE mainboard, filled with Licon caps, which has no visible sign of leaking or bulging, but the mobo doesn't make it to POST. Do you know anything about these caps, are they like the g-luxons?
TIA,
-w- -
As Bushytails wrote, other things can fail, but also caps can be bad but look perfectly normal on the outside. I've had some like that, and a few months ago, one Fuhjyyu brand cap in an Antec PSU bulged but the others looked and tested fine, yet a week later one of those "good" caps bulged and tested bad. These were tested with an ESR meter, which is supposed to be able to detect a lot more cap defects than a multimeter or capacitance meter can.Originally posted by wigyoriI recently came across a Zida T810B-SE mainboard, filled with Licon caps, which has no visible sign of leaking or bulging, but the mobo doesn't make it to POST. Do you know anything about these caps, are they like the g-luxons?Comment
I just recapped 3 badly bulging Licon's on an Atrend mb. I didn't have any caps on hand so I pilfered three rubycon's from another dead one. There's another 5 still on the mb. Prior to the recapping, the computer would lock up after about 15 minutes of usage. I've been using it now for about an hour. Cross my fingers that it'll hold up. They were 1000uf, 6.3vLife is good, go play in it!Comment
Check the buck controller. I have had two of these boards with dead buck controllers (fixed one of them, the other one is still lying in my mobo pile waiting for ummmm... don't know what...).Originally posted by wigyoriI recently came across a Zida T810B-SE mainboard, filled with Licon caps, which has no visible sign of leaking or bulging, but the mobo doesn't make it to POST.
Sry4OT
sComment
(Maybe someone of the moderators could split the thread)
First start with checking the supply voltage of the processor. If it is something like 1.3V instead of 2.0V (like it should be in case of a Celeron Mendocino) and the powergood signal (check the datasheet of Unisem US3004 (IIRC that was the one on these Tomato boards)) stays at 0, then it's probably time to replace it (IMHO no special howto needed for that - just desolder/solder it like any other surface mount component).Comment
wigyori and kc8adu : sorry i messed up the thread split a little and i cant fix it because i am not mod here.Comment
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
by eryjusHello,
by Paxman_SwedeHello!
I have studied the board and...-
by SACRI need Schematic A-Board @ Mainboard for Panasonic Plasma TH-P42X28K. Code : TNPH0842. I want to replace 1 MLCC but I don't know values (capacitance & voltage) & codes. Can someone help me? Thank you...11-20-2023, 11:53 PM
by re-atariI have been using a Denon AVR-X2000 receiver in my living room for several years now, works perfectly, am very pleased with it. Recently I acquired another one, advertised as defective with flashing red led a few seconds after switching on. Picked it up to try repair and use in hobby room. After switching on, the on/off indicator led indeed initially flashes green for about 2 seconds, during which the display is visible, and then starts flashing red (at 2Hz) with a switched off display.
I'm afraid the service manual is too large to upload here (55Mb), it can be found at https:/...-
- Loading...
