DFI PM12-TC recap (but failed)
  • lbwlow
    • May 2015
    • 125
    • Malaysia
    I bought this desktop from a local scrapper in my country with this DFI PM12-TC motherboard in it. It came with Willamatte P4 1.8. Considered a bargain since the HDD that came off this desktop was working and the CPU as well. When I pop the case to have a look inside, i found 2 X 6.3V TAEPO 1800uf was bloated (one already bung from the bottom) and 3 X 6.3V TAEPO 1000uf bloated as well.
    I pop in some RAM, with the CPU that come with it and attempt to turn on the board and it beep and works on 1st start, without recapping or whatever, because i am deciding weather the board worth fixing. Once i done installing Windows XP, all the drivers loaded up just fine. Except it is having some issue with the onboard display, in the device manager it isn't showing any error and the device is working properly. But it was making my display fuzzy, most noticeable when there are CPU activity (stress test) and graphics activity (moving cursor and windows). But when i was using an AGP graphics card, the fuzzy was gone. And by disabling the display adapter from device manager also remove the fuzzy. So i consider it as onboard IGP issue.
    I uploaded a video of it to Youtube :
    https://www.youtube.com/watch?v=1Cxv...ature=youtu.be
    Firstly i recap the 3 X 6.3V 1000uf TAEPO that was bulging with 3 x OST cap (same rating), i know those are terrible cap as well, but that is what i got in hand at the moment. Turn it on, and it was still the same. Then i recap the remaining 2 x 6.3V 1000uf TAEPO (total there are 5, but 3 was bulging) with those OST i use earlier, since those are same TAEPO cap, they might be faulty as well. Still the same, prob remain unfix.
    Next, i recap the 2 x 6.3V TAEPO 1800uf with 2 x Nichicon HN(M) 6.3V 2200uf, but that doesn't solve the fuzzy display either.
    Here is a pic with my board together with the location of bad cap:
    YELLOW is the 3 X bulging 6.3V 1000uf TAEPO
    GREEN is the 2 X good looking 6.3V 1000uf TAEPO
    RED is the 2 X bulging 6.3V 1800uf TAEPO
    Here the badcap :
    The conclusion is, should I just try a reflow with the VIA chipset ? Or replace all the caps, which i might do i later because i already run out of caps.
    • 31065
    Re: DFI PM12-TC recap (but failed)
    is it the psu it came with?
    • lbwlow
      • May 2015
      • 125
      • Malaysia
      Nope, i was using my own known working PSU to test.
        • 31065
        i would replace the other 3 caps on the left under the cpu, and the 2 below the 12v cable
        they are in area's that get hot.
        • lbwlow
          • May 2015
          • 125
          • Malaysia
          Ok, thanks for the tip, will try that tomorrow and see how it goes.
          • Uranium-235
            Comrade Glimmer
            • Aug 2007
            • 5042
            • US
            yeah not all caps bloat when they die
            • UraBahn
              Scrapheap Hound
              • Nov 2004
              • 165
              The capacitors (probably) won't have much of an effect on that, it looks like there's a noise issue (maybe even a grounding loop) on or near the onboard video. It could be that some grounding pins on the VIA BGA went bad and are letting excessive noise into the video output.
              You can try a heat gun to fix that, but be careful. (Sometimes mucking about with heat guns only makes things worse.)
              The ever-amazing (and ever-affordable) KY, Chemi-con's best kept secret.
              I'll probably be the only person going to SteamOS once it gets out of beta (ha ha.)
              • Oldschool297
                • Jun 2023
                • 24
                • Sweden
                I got 2 of these boards for free when i needed psu. I tried one of the board today. All caps were looking just as new. I noticed it only support AGP 4x. What is the newest bios version for this Phoenix bios?
                  no-name Radeon 9600 XT recap and cooler
                  by momaka
                  I've been seeing a lot of cheap-looking (but not always so cheap) no-name AGP video cards on eBay for a while. They started popping up quite a bit when the market for AGP cards became more alive all of a sudden due to interest in “retro” PCs. One thing that struck me about these cheapo cards is that they almost always seem to come with garbage caps - including the abominable Sacon FZ. That aside, though, I've been wondering about the rest of the quality (or lack of?) on these cards. So I decided to satisfy my curiosity yet again.
                  This one was actually suggested to me by ChaosLegionnaire....
                  11-06-2020, 07:54 PM
                • modtool
                  Lenovo Legion 5 15ARH05H, NM-D281 Rev 1.0, "BIInitializeLibrary failed 0xc0000185" and bios freezing
                  by modtool
                  Dear members,
                  I have a problem with this machine that still I can't solve, I hope some of you can suggest me something.
                  I was the first one to open the machine and touch the mainboard, in fact the Lenovo seal was intact the first time that I unscrewed all the internal screws.
                  The ower told me that it was working very good until Windows kicked "something like a firmware update" (owner's words) then the system started acting weird.
                  When you try to start it, some seconds after having pressed the power button, Lenovo splashscreen appears, then after 1 second, in the...
                  01-15-2024, 08:56 PM
                • varunviolin007
                  Looking for someone to recap Dell XPS T450 motherboard (Live in suburbs outside of Philly)
                  by varunviolin007
                  Hi guys,
                  I’m looking for someone in the Northeast to do a full electrolytic capacitor recap on a working Dell Dimension XPS T450 motherboard (it's an Intel 440BX, Slot 1). The board runs mostly fine but is beginning to freeze after warm reboots (turns back on for 30 secs or so and then freezes up but is perfectly fine after 12 hr cool down).
                  I’d be sending just the bare motherboard (CPU, cards, bracket, battery all removed). I’m located in Chadds Ford, PA and happy to ship within the US.
                  Looking for someone experienced with older PC boards who uses...
                  07-29-2025, 11:53 PM
                  by momaka
                  03-15-2023, 10:17 PM
                • gurj1979
                  Surface Laptop 1769 SSD Failed KUS040202M-B000
                  by gurj1979
                  Hey guys,
                  I've got a Surface Laptop 1769 (the nasty cloth type palmrest) which has a failed 512GB Samsung PM971 (KUS040202M-B000).
                  These are on BGA291, but I don't know which is equivalent to KUS040202M-B000.
                  AliExpress has this but it's expensive.
                  Can anyone help me find a reasonably prices equivalent which I can use as a replacement ?
                  Or which NVMe can I remove it from ?
                  02-17-2025, 04:02 PM
