Voltage irregularity - Still worth re-capping?
  • ryab
    • Jan 2005
    I have an EPOX 8RDA+ boards and it definately has a bad cap issue. However the Vdd (voltage across the processor I belive) given by the PC health when the computer first boots was low and flucuating. Trying to discover the source of this problem I noticed the caps are LONG gone.
    However, is the damage tothe voltage regulation perminent or a function effected by the failing capacitors? Aka, would it be worthwhile to replace the caps (I have the tools and the soldering skill) or should I just order a new mobo as the V is permantnely gone?
    ~Stone
    My code doesn't have bugs, it develops random features.
  • bushytails
    Moderator
    • Dec 2004
    • 217
    If the board is still functional (which it appears to be, since you can see the pc health), recapping will quite likely fix the voltage problem, assuming Vdd is indeed the cpu core voltage. (and not, say, the 5v line)
    --Randy
    • ryab
      • Jan 2005
      Yeah, that voltage that is low is supposed to be at 1.5V so its definately not the 5 line.
      ~Stone
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        recapping will make the lines rock solid and we wanna see the recapping pics. If you still have low voltage then a new psu is required. If the caps are gone then take it out of service now. permanent damage to the board you can see after the recapping. prolly there is nothing.
        • ryab
          • Jan 2005
          Yeah, I already replaced my PSU as the first guess as what was wrong with it. Guess I should of thought that out some more before I did that :*-(
          ~Stone
          • willawake
            Super Modulator
            • Nov 2003
            • 8457
            • Greece
            what?
            • ryab
              • Jan 2005
              heh, sorry if that was confusing. I was saying that I should trouble shooted the problem more extensively before I went and replaces the Power Supply.
              ~Stone
              • willawake
                Super Modulator
                • Nov 2003
                • 8457
                • Greece
                dont worry next time you see some instability with a comp you will open up the case and check the caps. good luck with your recapping.
                • Fernon@Repair
                  Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
                  by Fernon@Repair
                  i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
                  VCCIO voltage ok
                  VCCSA Voltage OK
                  VCCPLL Voltage OK
                  Ram Voltage ok
                  RamVTT OK
                  VPP 2.5 OK
                  But No Core Voltage
                  and i want to this vrm ic datasheet or pinout (ISL69269)
                  anyone have this ic pinout voltages?...
                  06-25-2025, 07:19 AM
                • electron_jj
                  Panasonic TH-L42D25A checking the PSU output voltage
                  by electron_jj
                  Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
                  I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
                  08-29-2021, 08:13 AM
                  Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
                  I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
                  The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
                  Now...
                  06-09-2024, 10:57 AM
                  ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
                  3+1 Voltage Regulator for IMVP-7/VR12 CPUs
                  Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
                  core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
                  configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
                  serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
                  Based on Intersil's Robust Ripple Regulator...
                  11-05-2024, 03:24 PM
                • ruletero
                  Acer a515-43 low battery charge voltage
                  by ruletero
                  Hi
                  Acer A515-43
                  LA-H801P
                  Fail: Does not charge battery, has low voltaje on connector.
                  Laptop didn't want to turn on, only charge led blinked.
                  I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
                  I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
                  Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
                  10-24-2022, 02:31 PM
