Gainward something-or-other with bad caps
  • bushytails
    Moderator
    • Dec 2004
    • 217
    A relative showed up with this board this evening, so I didn't get a chance to take many pics of it... I snapped a couple quick before pics, but forgot to get one of the whole board, so I can't say what model it was. blah. no after pics; he was very, very anxious to get it back in his computer... it's a 233mhz AMD chip IIRC. don't recall which socket. Most notable features is the board is pretty small, and has both AT and ATX power sockets, to be used with either type of power supply.
    Board had been partially recapped a couple years ago, when only two caps were buldging... this time every other cap except those two was replaced.
    Caps present:
    2 replacements, 16v 1000uf. don't know what the board came with, as this was the first time I'd seen it.
    5 Tayeh caps, 6.3v 1000uf. Four vented, two out the bottom and two out the top, and one very close to venting.
    Nope, no others. board only had a total of 7 caps, except for teeny tiny electrolytics 100uf and less.
    Replaced the 5 caps with nichicon 1200uf 6.3v ones.
    Board was HARD to solder. never had one that was this much work. Must have frigging thick traces. I gave up on my 45W pencil tip iron and got out my 140W gun (the one I've soldered 6awg wire with), and STILL couldn't melt through the vias in under 30 seconds. Vacuum desolder couldn't get them clean, had to use the 140W gun and a needle pushed through, and even then I couldn't keep the needle hot once it touched the traces.
    Symptoms:
    IDE corruption, windows refusing to boot due to being unable to read files, occasional random reboot.
    After recap:
    Windows boots and works perfectly.
    Photos:
    By the CPU: (the blue one is one of the previous replacements)
    The caps themselves: (taken from the above image, but cropped instead of shrunk)
    Off on the corner of the board:
    Between the agp and onboard IO:
    I didn't get a pic of the 5th cap or the whole board, as he really wanted me to get to work fixing it...
    Lesson learned: Some boards absorb heat remarkably quickly. I barely got this one with my 140 watt gun. I don't want to get out my 275 watt gun for a motherboard! Other boards I've done, my 45W iron was plenty, and my desoldering station was able to clean through the holes...
    --Randy
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    great post and excellent photos (i was thinking damn they look as good as an olympus...but it is one.) it is interesting to know the boards can take so much heat.
    • bushytails
      Moderator
      • Dec 2004
      • 217
      Yep, it's an olympus... d-550 to be exact.
      I've never had to use that much heat on leads that small... I've soldered major power components (transformers, etc) that needed a lot of heat, but never tiny pads.
      My 45W gun couldn't melt through the vias... you could heat the back of the leads all you wanted, and the solder simply wouldn't melt through. And trying to clean out the holes afterwards... on the other boards, my desoldering station (think it's 60 watts) melts all the solder through the via then sucks it all out... but on this one, it was next to useless. Ended up having to use a needle, pushing it against the sealed-off hole with the 140W gun touching both the pad and the needle until it poked through, then heating from the opposite side while pushing further, then pulling it out leaving a clean hole (the second or third time).
      Took 5 minutes to remove 10 caps from my fic ka-11. took 2 hours to remove 5 caps and clean the holes on this one. Ouch.
      --Randy
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        when i find a stubborn board like that i assist with a heat gun.
        just watch out for those little spring loaded plastic clips on the chipset cooler.
        they can melt and shoot across the room.
        i take them off till i am done with the heat.
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          kc8adu : what is your new avatar it is very curious
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            its a pile of tubes.
            • willawake
              Super Modulator
              • Nov 2003
              • 8457
              • Greece
              ok but what is the device. lets see a big pic.
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                its a jackson 648s tube tester.
                • Tynan Dill
                  by Tynan Dill
                  Assuming...
                  11-22-2024, 01:46 PM
                • m1ch43lzm
                  by m1ch43lzm
                  05-12-2025, 08:37 PM
                • Dani_2024
                  by Dani_2024
                  10-28-2024, 05:06 PM
                • black6host
                  Replacement caps for Samson Resolv studio monitor 65A Amp board.
                  by black6host
                  Good day!
                  I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
                  I'm going to replace the caps and I'll be the first...
                  02-06-2024, 08:22 PM
                • Noodneek
                  Replacing all the caps on the BenQ SW2700pt's power board didn't help...
                  by Noodneek
                  My 3.5 years old monitor (BenQ SW2700pt) started to black out for 1-2 sec every minute or so, it was doing this even with PC disconnected from it. I searched online and read that it's probably aging capacitors and there's a workaround to lower the brightness.
                  I lowered it from 100 to 65% and it indeed helped, but after a couple of months the issue returned... I continued to lower the brightness, but it helped only for a couple of hours at most, then I needed to lower it further... Turning the monitor off and waiting for it to cool down also helped for a short time, after which it...
                  08-30-2024, 12:52 PM
